Question about Canon PIXMA iP4000 InkJet Photo Printer
Printing blurry how to fix it to stop printing blurry
JUST CHANGED TONER CARTRIDGE AND NOW THE PRINTER IS PRINTING BLURRY. HOW DO I FIX THIS
Put back the original cartridge and print a page. If it is not blurry, you bought a bad cartridge. Take it back for exchange.
Jan 25, 2011 | HP LaserJet 3055 All-In-One Printer
Prints letters blurry as if you pass the brush.
How blurry? Like toner can be wiped of or like the letters are verry light?
Did you check pressure between fixing and pressure roller, it could be the bad bushing that causes the problem.
If they are very light, clean optics.
Jun 30, 2010 | Canon PC170 Copier
How do i align my printer, it's printing blurry but copies fine
the problem is with the main board. I fixed two of the exact same problem before.
May 28, 2009 | Brother Multi-Function Center MFC-240C...
BLURRY PRINT OUTPUT
The head probably needs aligning.
An interum fix is to turn off bi directional printing in the preferences.
This could possibly solve the problem.
Jun 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Laser Printer Copies Blurry
are copies blurry? from the glass or printing? clean the glass, and optics. and the machine could probably use a calibration..
May 16, 2008 | Office Equipment & Supplies
Fuzzy page continious.
Yeah I just read a tip. There seems to be a problem with the wave amp board, I will send you the engineering note. Sometimes though that encoder needs replaced and cleaning is not the total fix. The encoder may need replaced, but I found this also.
I just received this, this morning.
Failed Wave Amp
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Historically blurry print was caused by oil on the drum encoder wheel. This can be caused by the wave amp board. A cracked capacitor on the board causes the wave amp to produce a malformed amplified wave signal to the printhead. This in turn causes the printhead to eject ink at the wrong times, so the prints look blurry.
You can generally distinguish a wave amp problem from an oily drum encoder. The wave amp problem will usually be an infant failure. The printer will start producing blurry prints soon after it is installed and running. With a failed wave amp all prints will be blurry with no improvement. The drum encoder, on the other hand, may produce good prints and then bad prints and then good prints. Blurriness changes depending on how the oil is interfering with the encoder.
May 05, 2008 | Xerox Phaser 8500/DN Printer
Printer is printing blurry
Clean or replace the ink cartridges and select a better print quality from the front panel of the printer.
Jan 03, 2008 | HP Photosmart 2710 All-In-One InkJet...
My printer prints blurry lines!
Try this: make a copy and stop it when it reaches the cartridge ( has to have image on paper) take out paper and look at it, does it have blurry copies? if yes, then the problem is with the cartidge or (worse) the laser printing device ( expensive).
Take a chance and replace the cartridge.  if still there you need to replace the laser unit.
If it does not have blurry copies when you stop it at the drum then check the fuser unit( doubt it ) to see it it has any writing or toner on it.
Good Luck.
Oct 31, 2007 | Office Equipment & Supplies
Canon PIXMA iP4000 InkJet Photo Printer Logo
15 people viewed this question
old marine
old marine
