Question about Technics SL-1200MK5 Turntable
My mk5's lights blink when I press the start button?
The lights flicker as the platter starts to spin.
    Sergeant:
  • 432 Answers
May i ask which lights you mean, also the pitch? And does after that everything works fine?... then i don't see a problem to be honest. But i'll check my mk5(refurbished really everything only i'm busy with the tone arm wire rewiring, so i can't move it.But now is the time to replace your capacitors for better then standard ones, if you see how old they are and replacing the potentiometres and main wires etc. almost 15 years old. The so calles refurbushing by the often one person stores is a waste of monet, just do it yourself.
Greetings richard and i'll come back on the subject, when the table is ready.
Posted on Sep 29, 2014
5 Suggested Answers
djproaudio
  • 515 Answers
SOURCE: platter will not spin....
Um, why did you clean off the magnet with rubbing alcohol? Is this other DJ a service technician? Please be cautious when taking advice from friends or colleagues. Consult a professional, otherwise, you might cause more damage to your unit. Now, on to the problem at hand... This is a common problem with the MK2's, and not a power issue. This is a drive issue, and you will need to get it professionally serviced by an authorized Pansonic/Technics service center. There are various components which control the drive of the MK2's, so it's not easy to determine which is the culprit. 95% of the time it's one of the IC's (integrated circuits) or a few, or all. Which is why you will need to take to a service tech to get it looked at... Now, I know that's easier said then done, as many service centers do not provide support for turntables, especially the 1200s. So make sure you ask if they are knowledgeable with the Technics SL1200MK2 series. A lot of times, many of these places will be factory authorized to repair Technics/Panasonic items, but none have ever seen a Technics SL1200MK2 turntable, or worked on a direct drive unit. Many work on CD Players, Cassette Decks, etc. Our company offers free return shipping for all Nationwide service, and if your in NYC, we offer free pick up. Oh, and we are masters with the 1200s. Unfortunately, I don't think we can post our company information here, as I do not want to violate any agreements. So, with that said, do a search using the REPAIR SERVICE search option in FIXYA.com and go to the following section-> HOME AUDIO -> Audio Shelf Systems - we are listed.
Posted on Sep 01, 2007
darren1975
SOURCE: 1200 platter drag
the platter should have two holes on it,my 1210 does. put your thumb on the spindle and a finger in each hole and prize the platter off. theres no screws holding the platter on just a tapered spindle shaft. it is quite heavy so a good pull will do it. as for the scraping it might be as simple as packaging placed under the platter to secure it for shipping, technics are built really well so i cant imagine it could be anything major. i hope this helps you out, if you need any more help let us know. please also let us know how you get on. darren
Posted on Oct 07, 2007
  • 6 Answers
SOURCE: technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
Posted on Jun 03, 2008
  • 298 Answers
SOURCE: when i press Start/Stop button, the platter is not
The chances are the rubber drive belt has either broken or stretched so that it has fallen off the drive pulleys.
You will need to gain access to the underside of the turntable to replace it.
With most turntables the process will be to secure the tone arm (a rubber band will do the trick) before turning the whole thing upside down and unscrewing the base.
Replacement drive belts are easily available on the internet. Search by make and model number of your turntable
Posted on Feb 02, 2011
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
Hi having a problem !!
If it has a belt drive, the belt has to be replaced.
Mar 22, 2015 | Technics SL-1210 Turntable
I recently took my turntable out of the box after being in there for years because someone wanted to buy it, but it dose not work.
If the turntable is a belt drive, most likely the belt has probably disintegrated due to ozone contamination over time and must be replaced if this is the case. Once you have the platter off you can see the spindle that drives the platter to see if it is moving.
Nov 22, 2014 | Audio Players & Recorders
Technics 1200 fault where both the 33 & 45 buttons remain lit, the platter spins at super speed,start stop button doesn't work and the red light is not on
Did you try to de-assemble and clean the contact of this button with contact cleaner, take care to not shoot on rubber parts if you have near the contact, it would blown up !
Apr 28, 2014 | Technics Audio Players & Recorders
Arm not working. Stop/start light flashes red instead of staying solid
Don't try and force anything that won't move. Try this. With the power unplugged, place the tonearm over the record, if it will move freely, while rotating the platter by hand. Move the tonearm slowly over the surface of the platter until the end. Continue turning the platter by hand and see if the tonearm picks up and returns to the rest. See if that fixes your issue. For more information or further questions, please visit my website at audioserviceclinic.com. Thank you.
Dec 09, 2013 | Technics Audio Players & Recorders
Logitech m 705 mouse pointer flickering
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens.
Type "Cursor blink" in the "Search programs and file" text box.
A list opens.
Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens.
Click the "Speed" tab. A list of options appears.
The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast."
Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale.
Click "Apply."
Click "OK." The cursor stops flickering on the screen.
hope this helps
Sep 12, 2012 | Logitech M705 Wireless Marathon Mouse,...
B & O Beocenter 4600: The record player won't spin
the turntable wont spin unless a record is on the platter,the centre 45 adapter weighs the record to determine 33/45.try pressing 33 and turning the platter by hand(remove expensive cartridge first!),if it starts to spin the motor leaf switch is at fault.is the belt in position.the motor pulley can become unglued.
Jan 08, 2010 | Bang and Olufsen Beocenter 9300 Shelf...
Start/stop button doesn't move platter
nakered switch then needs replacing
Aug 07, 2009 | Numark Pro TT-2 Turntable
Numark ttx wont spin
some tables require the tonearm to be over the record area before the patter starts to spin. If thats not it, have you tried "jump starting" the platter with your finger? the direct drive "stepper" motor might be confused as to where it is at the moment. and finally remove power from the wall for a few minutes then retry.
Feb 09, 2009 | Numark TTX Turntable
Technics sl 1210 will not start up
May 24, 2008 | Technics SL-1210 Turntable
Technics SL-1200MK5 Turntable Logo
95 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
