Question about Cheviot 5115 tub faucet with all metal hand shower and diverter
Cheviot 7565 doesn't divert properly AND water runs for about 8 seconds after turning supply off. Cheviot says this is normal for gooseneck faucets. I've never seen water run that long after shut of
This is a free standing tub filler with a gooseneck faucet. We've changed cartridges and flushed out the aerator. When those steps failed, Cheviot changed the message to "this is normal." We sent video showing the amount of water that continues to run after shut off and also showed that water continues to run from the faucet when we divert to the wand. Other than this unit being defective, is there any possible solution?
I get water out of my spigot and bathtub but nothing out of my faucets
Your aerators are probably clogged. The reason you still get water out of your tub and your spigot is because they have no screens to clog.
Have you had your water main shut recently or have the hydrants in your area been flushed? Both of these conditions can cause screens to clog. Remove the aerators, flush the lines and clean the aerators. If you still have no water, your stems and cartridges may also be clogged. They must be removed, cleaned and/or replaced, and the faucets flushed. If you have well water, your well may not be developed enough and is sucking up sand. This is usually not a concern if it's not a new well, or if your well hasn't been worked on lately.
Mar 09, 2017 | Plumbing
Installed a new faucet and no water comes out
Since your question is so vague (is it a shower, tub/shower, lavatory, kit. sink or laundry tub faucet) I'd have to say that the flow restrictor in the aerators or showerhead is clogged up. Just unscrew and remove and either clean aerator or sh.head out and/or remove flow restrictor permanently. If that doesn't work turn off water and disconnect supply tubes from faucet and run them into a bucket and turn water back on to check for volume. If you have plenty of water at supplies then remove faucet and take defective faucet back to where it was bought and get another one!
Jun 08, 2014 | Moen & Replacement Cartridge
Cheviot 7565
I have just fitted new faucet half turn , the ceramic washers do this for a minute .
Feb 07, 2014 | Home
We flushed our hot water tank and after that we have very little pressure our 122-426 b&K kitchen faucet. Changed the cartridge and cleaned the aerator
There's a little filter in faucet head and it may have got backed up with calcium from old water heater when changed.. U can just pop it out with lil knife and then run faucet with hot water to get any build up.. U can pick up more screen filters at local hardware store for cheap..
Jul 27, 2013 | Plumbing
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to
Oct 16, 2012 | Price Pfister Plumbing
Spray and single flow both running at same time on Moen single-handle kitchen faucet. How do I correct the problem ?
there is a diverter inside the faucet that works with water pressure possibly has some debris or calcium build up.turn off water supply and take out cartridge. you should see the diverter
Apr 21, 2012 | Moen Plumbing
I have low hot water pressure on new Roman tub faucets. The cold has lots of pressure. I removed the aerator. before turning on the water so I would not get crud in the screen. The pressure is better when...
There are two possible problems:
1) The crud you don't want in aerator can get stuck in elbows and shut-off valves.
Open following link for steps
2) Crossover. If single-handled faucet has bad cartridge, or check valve is bad, these things can cause hot water not to flow.
Generally however if the pressure is still good, the issue is most likely #1 above.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 19, 2011 | Opella OMEGA ROMAN TUB SPOUT - 500.658.120...
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
Cheviot 5115 tub faucet with all metal hand shower and diverter Logo
Top Cheviot Home Experts
john h
Tom Chichester
Are you a Cheviot Home Expert? Answer questions, earn points and help others
