Question about Sony Kdl-32l504
Vertical picture Picture rolls vertically in bottom 3/4 of screen. Top 1/4 has stable picture.
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
mistersony
  • 320 Answers
SOURCE: Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
Posted on Oct 18, 2008
mistersony
  • 320 Answers
SOURCE: Cannot view the full picture
First, you have to tell me how the cable box is connected to the TV, by HDMI or component. If it is connected by HDMI, the cable box settings will override the picture size settings on the TV. It may be as simple as resetting the picture size on the cable box, but I am not familiar with the type of cable boxes that Comcast uses.
Posted on Oct 19, 2008
budmrtn
  • 11361 Answers
SOURCE: tv has vertical lines accross display picture
It can be either the LCD controller board, or worst case the LCD panel, symptom of bad panel is vertical lines from the top to the bottom of screen, and it will get more lines as time goes by.
http://www.shopjimmy.com/catalogsearch/result/?q=Sony+BRAVIA+XBR+KDL-V32XBR1+
Posted on Nov 24, 2009
SOURCE: LCD Displaying Red instead of Black, Vertical Lines in Display
I had a similar problem where the screen went to a pink shade periodically. Sony sent me a memory stick, with download instructions, that fit into one of the back ports. The problem has gone away. It was a software correction.
Posted on Feb 26, 2011
Picture is rolling
In the old days there was a control at the back of every tv labelled "vertical hold" that needed adjustment when the picture rolled. As tv sets became better that control was at first moved inside the cabinet and then finally deleted.
The vertical hold controlled the amount of synchronising signal (that is extracted from the signal received from the antenna) reached the frame oscillator. Today's electronics are so stable the vertical and horizontal synchronisation is automatic so while sometimes a rolling picture can be caused by a bad signal it almost invariably caused by an internal electronic fault needing the attention of an engineer.
Oct 19, 2017 | Televison & Video
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Sometimes the picture rolls for 30 minutes to one hour and then the picture is perfect. A few times when we turn it on, the picture is okay and then after a few hours, the rolling picture starts. Where is...
The rolling is a bad filter capacitor on the signal board in the set---Any Mitsubishi dealer can look the model up and see known faults including this one---some of the sets when cold---vertical jitter in picture or just menu---If the menu is stable you have a tiny bad cap= weak caps when cold act up and when get hot regain capacitance and start to work.
Aug 28, 2012 | Mitsubishi WS-55807 TV
Sony trinitron KV-32HS510 has vertical hold problem
It could just be a resistor or two ,
check for Vert Oscillator Circuit & AGC
Jul 27, 2012 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Panasonic TX-68PS12A Picture shrinks in vertical direction at top and bottom over period of 15 minutes until vertically compressed picture occupies approx 1/3 of the screen in a central band
Ur Vertical/Horizontal ic is cold solders,U know how to solders?Take the tv aparts use a back handle of the screw driver tabs around find out where V/H the cause resolder that.
Oct 22, 2009 | Televison & Video
Top of creeen rolls over and back down from the top about 3"
There is a capacitor in the vertical circuit that has significantly changed value causing this. If you are familiar with these units, look for a capacitor with the value of around 100ufd that is part of the vertical circuit and change it. That should resolve it. If you bring this to a shop, expect a parts cost up to $10.
Dan
Mar 17, 2009 | JVC AV-27920 27" TV
1/4 of screen is black (right side)
It is the light tunnel. The tunnel is four small pieces of glass in a aluminum tube the size of tootsie roll. in the center of the light engine.
Mar 15, 2009 | Televison & Video
Video tapes played through VCR experience vertical 'rolling'
unfortunatly no. the vert hold is set by black bars at the top/bottom of the video signal (outside of the viewable area). it sounds like your VCR or tape is damaged.
Dec 04, 2008 | Sony KDF-42WE655 Television
Vertical collapse of picture then no picture
You most likely don't need to replace a board. You should solder the bottom of the vertical output, it probably has bad connections. If you don't know where the vertical output is, give me a model number and i will give you a location, or take a picture of the deflection board and i will circle it.
Tim Nolan
Sep 16, 2008 | Hitachi 53SBX59B 53" Rear Projection...
Can only see half the picture
Locate Vertical Output device--replace w/OEM equiv.or better.
Oct 10, 2007 | RCA TruFlat 27F520T 27" TV
Sony Kdl-32l504 Logo
18 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
