Question about Microwave Ovens
Microwave makes crackling sounds and smells like burning wires
MicrowaveSvc
  • 9098 Answers
SOURCE: Crackling sound in microwave vent when power is off
By "powered off" can I assume you mean that it is plugged in and at idle, not cooking, just showing the clock?
If so, I'd say your control board is failing.
If my assumption is wrong, please write back with more details.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Nov 09, 2008
rickzilla
  • 706 Answers
SOURCE: burning wire smell
Hello jvtmad1,
All of the previous comments are relatively good ideas but let me offer some additional advice,
First off, You need to determine if the burning smell is coming from the Microwave itself or from the receptacle that provides power to it. Most wall receptacles are rated for 15 amps and should easily handle your microwave ovens power requirements. A simple check might be to run a hair dryer on the same receptacle without the microwave plugged into it. They draw comparable power so that should eliminate the recptacle as the culpret, On the assumption that the burnt wire smell is coming from the microwave itself, then your best bet is to return it to the store for a repair or replacement. Unless you are properly trained on how to sservice that, you probably shouldn't attempt it. As stated in previous comments, it should still be under warranty. If you have a bad filament transformer, magnetron or the wiring between them, that is not something you want to fiddle with yourself.
In summary, eliminate the receptacle on the wall as being the problem first.
If you find tha your receptacle is the problem, then you may be able to remove or disable power to it by switching off teh appropriate circuit breaker or fuse.. then take off the face plate and check the integrity of the wires going to that receptacle and making sure they are tightly secured to the terminals of the receptacle. I would assume that if that were the problem, you would notice a burnt smell as soon as you took off the face plate. Hope some of thes ideas help you resolve your problem...
Regards,
Rick
Posted on Nov 22, 2008
  • 70 Answers
SOURCE: JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Posted on Aug 18, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE JVM1660BB Microwave makes loud noise when
With the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
To remove it from the wall, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Posted on May 31, 2010
heatman101
  • 43501 Answers
SOURCE: microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
Microwave smell like burning rubber
Good Afternoon Friend,
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Microwave Ovens
WHEN I USED MICROWAVE HAD BURNING SMELL & BLACK SOOT APPEARED. STILL HAVE POWER BUT DOESN'T COOK
Just had the same problem. It was an electrical short and the repairman said that it could have burned the kitchen wall and been a catastrophy. Get rid of it immediately!
Mar 02, 2013 | Microwave Ovens
The microwave looks like it is shorting out where the light inside the microwave is. Also it sounds like something is crackling when you turn it on. Sometimes it would smell like it was burning. Help, ...
sounds like the magnetron tube is starting to draw excessive current and arcing over to ground, or the high voltage cap is starting to leak thru and short-out.608-214-5632 or e-mail:applianceservice24_7@yahoo.com
Jul 05, 2010 | GE EMO3000 Microwave Oven
After a few seconds my microwave makes a crackling
check for scraps of foil, wire ties any type of metal or tin,or aluminumif not any of that, ur looking at a componet problem
May 23, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave started making a crackling sound, I saw some sparks and there was a burning smell. I looked in the unit and the smell was coming from the circular cap, which I removed and then metal disk has...
You burned up the magnetron. It is not a hard replacement but requires a few checks first. I have a tip at http://www.fixya.com/support/r4265491-replace_bad_magnetron which explains the process in detail and lists where to buy the parts you will need. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Mar 04, 2010 | GE Microwave Ovens
Smells like burnt wires
It is very possible it may have burnt wire or burnt capacitor. Remove unit, remove top cover and look inside to see if you see any burn marks or burnt wires. Also check fuse to see if it is good or not.
Aug 07, 2009 | Whirlpool MH1141XM Microwave Oven
Burn at bottom of microwave
First try cleaning the burned mark off. Dip a scrubber in lemon juice and sprinkle salt on it; this is also great for burned coffee pots. The smell can be gotten rid of this way: Boil lemon peel in water, then put the water in a spray bottle. Not only will it make your microwave smell fresh but the lemon oil will make it easier to clean. If it still smells of burning rubber, take the back off and inspect the wiring. IF you see burned wiring, please do yourself a favor and replace the microwave!
Microwaves work by making the molecules in food get "excited"-they move more-meaning, if there IS rubber burning, then there will be minute molecules of rubber in your food, which is BAD for your immune system. If it's just burned chocolate, though, it is harmless unless you are allergic.
Apr 03, 2008 | Danby DMW1400 Microwave Oven
Microwave Ovens Logo
208 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
