Question about Exercise & Fitness
Power first treadmill
Hi,my t950 over the last month has had the mat crease along the middle.Now it has got to the stag where the mat has actually doubled over. I have released the tension on the left and right roller bolts flattened the mat and re tightened both sides again.Only to have the mat double over again.Is it because I have not aligned it correctly or is that I need a new mat,and why has it doubled over. Kind regards Jim
SOURCE: belt shifting/crooked and frayed on Proform 725 TL
in the back of the manual, it describes the adjustment for this. on the end of the platform (near where your belt is crooked) there is a hex nut. the manual says to turn the machine off before adjusting, i find it is much easier to do while the tread is still moving. turn it about a quarter or half turn one way or the other until the tread is aligned.
Posted on Jun 29, 2009
SOURCE: clickling noise when running on treadmill
raise the incline and look under where motor is and spray some silicone lubricant on all the piston like things.
Posted on Apr 13, 2010
bwinton
  • 83 Answers
SOURCE: slipping mat
This is caused by one of three problems. First and most likely, the walking belt is loose. To tighten the belt, start by locating the two bolts that adjust the rear roller (one on each side of the unit in the back). Run the unit at about 3 mph. Tighten the bolts a 1/4 turn at a time. Make sure that what you do to one side, you MUST do to the other side or the belt will get off center. After you tighten it 1/4 turn, check the belt to see if it is still slipping. If it is then tighten the belt 1/4 turn again. Continue until the belt does not slip, but do not tighten the bolts more than 2 full turns. If it takes more than 2 turns then something else is the problem. The second problem that it could be is the drive belt might be loose. To tighten the drive belt, start by removing the front cover. loosen the bolts around the motor then tighten the drive belt by tightening the motor adjuster bolt. Once the drive belt is tight, tighten the motor back down. The third problem that it could be is the walking belt could be worn and need to be replaced. Let me know if you have any questions.
Posted on Apr 30, 2010
maxtreadmill
  • 832 Answers
SOURCE: Proform 995 Sel treadmill
Go to iconservice.com click on manual input manufacturer & mode lname
Posted on May 20, 2010
maxtreadmill
  • 832 Answers
SOURCE: How do adjust tension on treadmill belt
If the walking belt slips when walked on. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Posted on May 31, 2010
Unscramble letters to create a word. letters: scsgtlaae
Alga Sects
Gala Sects
Galas Sect
Cage Slats
Cage Lasts
Cage Salts
Glaces Sat
Cages Last
Cages Salt
Cages Slat
Lace Stags
Scale Stag
Scale Tags
Laces Stag
Laces Tags
Scales Tag
Eclats Sag
Eclats Gas
Cleats Sag
Cleats Gas
Castle Sag
Castle Gas
Eclat Sags
Cleat Sags
Castes Gal
Castes Lag
Caste Slag
Caste Gals
Caste Lags
Lac Sagest
Lac Stages
Lacs Stage
Lacs Gates
Class Gate
Talcs Sage
Talcs Ages
Talc Gases
Talc Sages
Casts Gale
Scats Gale
Acts Gales
Scat Gales
Cast Gales
Cats Gales
A Lacs Gets
A Class Get
A Sacs Gelt
A Casts Leg
A Casts Gel
A Scats Leg
A Scats Gel
A Acts Legs
A Acts Gels
A Scat Legs
A Scat Gels
A Cast Legs
A Cast Gels
A Cats Legs
A Cats Gels
A Gal Sects
A Lag Sects
A Slag Sect
A Gals Sect
A Lags Sect
Lac Sag Set
Lac Gas Set
Lac As Gets
Lacs As Get
Sac Gal Set
Sac Lag Set
Sac Sag Let
Sac Gas Let
Sac Stag El
Sac Tags El
Sac La Gets
Sac Las Get
Sac As Gelt
Sac Sat Leg
Sac Sat Gel
Sac At Legs
Sac At Gels
Sacs Tag El
Sacs La Get
Sacs At Leg
Sacs At Gel
Acts Sag El
Acts Gas El
Acts As Leg
Acts As Gel
Scat Sag El
Scat Gas El
Scat As Leg
Scat As Gel
Cast Sag El
Cast Gas El
Cast As Leg
Cast As Gel
Cats Sag El
Cats Gas El
Cats As Leg
Cats As Gel
Cat Sags El
Cat As Legs
Cat As Gels
Act Sags El
Act As Legs
Act As Gels
Gal As Sect
Gal Sat Sec
Gal At Secs
Lag As Sect
Lag Sat Sec
Lag At Secs
Slag At Sec
Gals At Sec
Lags At Sec
Sag La Sect
Gas La Sect
Stag La Sec
Tags La Sec
Tag La Secs
Tag Las Sec
Oct 27, 2016 | Computers & Internet
How do I assemble a Stag Minstrel wardrobe from its component parts?
These are the instructions for a Stag Minstrel S150 double door wardrobe which I hope helps figuring out what goes where etc..
I've just noticed the photo isn't very clear on line, so here is a transcript of what it says.
Instructions for dismantling Stag Minstrel double wardrobe S150.
1. Remove shelf by sliding forward.
2. Remove hanging rods and shoe rail by sliding their end ferrules ( the circular bits the rods pass through) inwards and sliding the rods clear.
3. Remove the screws that pass through the lower wings of the top gussets into the end panel.
4. Close both doors, bolting the left hand door at the bottom only.
5. Remove the screws that pass through the carcase back into the top panel
6. Remove the screws which pass down through the top of the wardrobe into the end panels, and lift the top, complete with gussets and shelf supports, clear of the wardrobe.
7. Lay the wardrobe on its back, and remove the screws which pass upward through the front and back rails into the bottom panel.
Pull the plinth clear. The wardrobe will now divide into two halves.
NOTE : When reassembling the wardrobe make sure that
(a) the two halves of the wardrobe are located correctly together before fitting the plinth over the bottom location blocks ;
(b) all screws enter the holes bored for them.
Jun 13, 2015 | Home
Paper printing with creases
Simple, get it replaced as it is obviously faulty and the "engineers" can't fix it. Go back to your supplier and if you paid by card, claim your money back, if they won't help, as it is faulty.
Mar 19, 2014 | Ricoh Office Equipment & Supplies
How do I fill my Whoozit water mat with water? The valve appears sealed closed.
The valve has a small, barely noticeable diagonal crease on the bottom. It took me a while to find it. If you push the bottom of the valve down with your thumb, the crease will open and you can fill it up.
Aug 07, 2011 | Toys
Lost instructions for building 6 man white stag tent how do poles go up
I have a second hand white stag tent whith the tent # 28242 white stag six man tent. I need set up instructions and my be missing some pole for set up
Sep 01, 2010 | Rock & Ice Climbing
Hit the bottom of tv color still there the pic is double
In middle of cassis up above is a small board it will have STK730-010 on this board, replace it Mats has them 1-800-628-1118
May 11, 2010 | RCA P52939 52" Rear Projection Television
How to make program of finfing the determinant of m*n matrix in C coding
I solve your problem but there is a little mistake that I can't find but maybe you can so here what I wrote:
#include <graphics.h>
#include <stdlib.h>
#include <stdio.h>
#include <conio.h>
#include <dos.h>
#include <math.h>
#define n 3
typedef struct
double A[n][n];
int size;
}Matrix;
double det(Matrix mat);
Matrix cut(Matrix mat, int x);
int main(void)
clrscr();
double d;
Matrix mat;
mat.size=n;
mat.A[0][0]=1;
mat.A[0][1]=2;
mat.A[0][2]=3;
mat.A[1][0]=4;
mat.A[1][1]=4;
mat.A[1][2]=6;
mat.A[2][0]=7;
mat.A[2][1]=8;
mat.A[2][2]=9;
d=det(mat);
printf("%d",d);
getch();
return 0;
double d=0;
if(mat.size>2)
for(int i=0;i<mat.size;i++)
d+=pow(-1,i)*mat.A[0][i]*det(cut(mat,i));
else
d=mat.A[0][0]*mat.A[1][1]-mat.A[0][1]*mat.A[1][0];
return d;
Matrix cutmat;
cutmat.size=mat.size-1;
for(int i=0;i<cutmat.size;i++)
for(int j=0;j<cutmat.size;j++)
if(j<x)
cutmat.A[i][j]=mat.A[i+1][j];
else
cutmat.A[i][j]=mat.A[i+1][j+1];
return cutmat;
Rate me if it helped!
And if you find the mistake please tell me where thanks.
Mar 06, 2009 | Intel Computers & Internet
Distorted picture
On the middle circuit board towards rear is a metal wavy plate.On the back side(actually towards screen when looking from rear of unit),the middle screw has a ground wire(light brown) that is loose.
Apr 08, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Exercise & Fitness Logo
41 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
