Question about Welding Tools
Frost free faucet B & k 1019 needs anti siphon replacement part
    Problem Solver:
  • 5 Answers
I would search on line, if you already havn't. Otherwise a replacement faucet is $20-$30. turn the water off inside the house, drain the line, and use two wrenches to remove the faucet, (one to hold the pipe and one to turn the faucet).
Posted on Oct 31, 2014
Anti siphon valve
Hi, Yeah it's clogged.It may be harder than you think to find a replacement part. You may have to replace to entire fixture.
Sep 11, 2013 | B&K Plumbing
I have a Mueller sillcock quarter turn anti siphon frost free faucet I picked up from Home Depot last Fall. It worked through the Fall and the Spring up until a few days ago. It no longer turns on. It
The seals are probably stuck inside causing it not to open. Turn the water off to the spigot. Unscrew the head of the faucet, behind handle. The whole inside assembly comes out. You can then replace the gaskets and reinstall the assembly.
RJH2O
May 11, 2013 | Plumbing
Water leak ge clothes washer
Replace the anti-siphon valve
Anti-siphon valves prevent water from siphoning back into the water supply. Also known as vacuum breakers, anti-siphon valves are used on washing machines, faucets, toilets, sprinklers and other water sources. A leak on an anti-siphon valve can cause deterioration of the appliance's external components and damage the flooring material underneath the washing machine. Therefore, a leaking anti-siphon valve should be attended to as soon as possible.
Jun 08, 2012 | GE WBSR3140DW Top Load Washer
The faucet makes a constant noise when it is on, hot or cold.
The noise is most likely originating from the anti siphon valves in the supply lines. If you remove them, the noise will clear.
Jun 28, 2011 | Danze D221116BN Opulence Centerset...
Faucet leaks through anti siphon valve
They make a repair kit for the anti siphon valve.Pop cap off (be careful not to break clips on anti siphon cap) remove old anti siphon valve and put in new replace cap problem solved.It screws out.
Jun 04, 2011 | B&K Plumbing
We have a fluidmaster 200a fill value and the water is just trickling into the tank. should we replace the whole unit?
Yes the 200a is not a anti siphon ballcock and you should have a 400a to keep you water from possibly back flowing into your water system.
Feb 20, 2011 | Plumbing
How to replace a cold only outdoor sill faucet
You will have to go below on the inside of the house rather it be a crawl space or a basement and cut the copper pipe and then splice the pipe with new line, All of the parts would be at local Home Depo store.
Mar 31, 2010 | Moen Plumbing
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
Have b & K frost free antisiphon hose bib that leaks out of seal
You can replace with any brand frost free faucet.Parts are impossible to get.
Jun 14, 2009 | B&K Plumbing
Leaking outside frost free hose bib
take it apart and put some trflon tape on the threads
Jun 01, 2009 | B&K Mueller/B & K 450-032 90 Red Brass...
Welding Tools Logo
398 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
