Question about Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer
Canon mx340 paper output tray sensor not working
The tray is open but the display is saying to open it and press ok. what do I do??
SOURCE: wont print
The problem occurs when the paper tray is pushed down too far and 2 flimsy stop tangs on the backside of the tray hinge break off. The one on the left side contacts a microswitch, pushing it forward , signaling the printer tray is open. When the left tang breaks off, there is nothing to press the switch. You can try bending a paper clip in a fashion that hold the switch forward.
OR (the following will probably void your warranty)
Unplug the printer
Pull out the envelope tray on the bottom.
Set the printer on its back
Look just behind the bottom of the tray door from the underside
There are 2 wells on the underside. The front most wells are more square-shaped.
The 2 wells behind the are irregular-shaped. These 2 have the cover release tangs. Take a long, thin #1 flat blade screwdriver and push them outward toward the sides of the printer to release the 2 inside catches.
Next, push the screwdriver into the 2 rectangular release holes on the bottom sides of printer (beneath little arrows) to release the side tangs.
Next, release the rear tangs in similar slots in the back of the printer.
Gently lift up the cover. Lift up the electronic module on the left side.
The output tray wicroswitch is the black one on the bottom of the electronics module fix it in the upper position with either a small zip-tie or good electrical tape (the top one signals that the top cover is open to expose the ink cartridges, leave it alone).
Carefully reassemble the printer, hopefully it will work.
Remember to open the tray when you print as the preventing switch is no longer functional.
Good Luck.
Posted on Nov 05, 2007
SOURCE: printer door open message
Further to this, the sensors can give way. Try soldering or pushing the two connections together. If you need to test, you will have to put the lid back on but you can leave the sensor out of the rinter by draping between the cover and the frame of the putput tray (be careful not to pinch it. AAMOF I leave my sensor out as even though I've pinched it together it has a habit of coming undone.
Posted on Jul 13, 2008
SOURCE: Paper output tray is open but message says it is closed
I solved this problem by putting a shim between the door & switch lever.
The shim is just a piece of cardboard/plastic/whatever about the thickness of a credit card & about 1/4 inch wide.
At the lower right corner of the paper outlet is an opening about 1/4 inch square. On the right side deep in this opening is a lever (rather hard to see). When the door is opened it lifts the lever up (presumably telling the printer the door is open). I took a small screwdriver, inserted it into the left side of the opening, turned it counterclockwise until it caught the edge of the lever & lifted it up, inserted the shim below the lever, & withdrew the screwdriver. This solved the problem (it has only recurred once since the shim was put in).
If the shim falls out just reinsert it. Of course, if you ever want to close the door you need to remove the shim first.
Posted on Sep 28, 2008
SOURCE: The ip4500 will not print - says the paper output tray is open!
Just fixed this problem on mine. Need to remove the covers, watch these 2 vids to see how..
http://www.youtube.com/profile?user=martop49#p/u/1/iQdHDR6po80
Then on the right side where the on switch is, near the hinge is a little switch with 2 yellow wires, it's probably broke. Pull the 2 wires out and solder or twist them together, then put everything back together. It will now assume the door is always open. Jobs a good'n :)
Posted on Jan 07, 2010
ic0729
  • 212 Answers
SOURCE: canon ip4300 printer says paper output tray is closed. wont prin
Its a defective printer you have that cant get out of paper output tray is close or that the paper output tray is not properly placed into the printer.
Try to reseat the output tray and let me know. If it does not work, you may need to send printer to repairs.
Posted on Mar 19, 2010
Need to clear In Use/Memory light on Canon MX340 printer
Step 1 Press the "Menu" button on the MX340 until "Device Settings" appears on the LCD display.
2.
Press the left or right arrow keys to select "Reset Settings," and then press "OK" to load the Reset Settings menu.
3.
Press the left or right arrow keys to select "All data," and then press "OK" to reset data on the MX340 to factory default settings.
Apr 14, 2015 | Canon PIXMA MX340 Wireless Office...
Canon printer mx328 is when i scan it display ''the paper output tray'' what mean and how to clean it. Please help.
Hi
If the Paper Output Tray is closed, open it. The machine resumes scanning.If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
Cheer
Jul 12, 2011 | Canon PIXMA MX310 All-In-One Printer
My Canon Pixma MX340 printer keeps telling me that there is a document in the ADF and won't print. There is no paper anywhere and none has been stuck in the ADF but the message remains. I have tried...
Solution: Setting the MX340 back to default settings
Instructions to change the machine back to its default settings.
  1. Make sure that the machine is turned on.
  2. Press the Menu button repeatedly until Device settings appears.
  3. Use the l_mark_s.gifr_mark_s.gif button to select Reset setting , then press the OK button.
  4. Use the l_mark_s.gifr_mark_s.gif button to select one of the following, then press the OK button.
    Telephone no. data: Reverts the telephone number settings to default. Setting data: Reverts the machine settings other than the telephone number settings, such as the page size, media type, and other settings, to default. All data: Reverts both the machine and telephone number settings to default.
  5. Use the l_mark_s.gifr_mark_s.gif button to select Yes on the confirmation screen, then press the OK button.
Jul 10, 2011 | Canon PIXMA MX340 Wireless Office...
My conon printer mx340 says ducuments in adf error
Hi guys,
This error occurs when paper sensor in ADF = Automatic Document Feeder detects some paper inside paper path. Firs, open ADF access cover and check if some broken paper present inside paper path. If no broken paper found in paper path means paper sensor is faulty and you need got new ADF replacement. Thanks
Source:
MX340 Series Service Manual
Jun 27, 2011 | Canon MX340 AllInOne InkJet Printer
How do I align the head on my Model-PIXMA MP 970 Canon Printer?
In short, while the printer is On, press the Home button on the printer, use the up-down button to scroll down the menu and locate "Settings", again scroll down and locate "Maintenance", press "Ok" and locate "Auto Head Align" and press "Ok", again press "yes" when you see a confirmation message on the screen. The alignment page will print out. Make sure there's paper in the tray (not in the adf) before performing this.
The long procedure is given below (if in case you need it):
Press and release the On/Off to turn the power on. Open the sheet feed cover on the rear paper tray. Pull out the paper support until it stops at its fully extended position.
  1. Open the paper output tray. Flip the paper output tray extension out. Load a sheet of letter-sized plain paper in the rear tray. Slide the paper guide to the right until it is snug against the left side of the paper.
  2. Press and release the Home button on the control panel. The Home screen will be displayed on the LCD panel. Press the Up or Down Arrow button to scroll through the menu. Select the Settings option. Press and release the OK button. Select the Maintenance option. Press and release the OK button. Select the Auto head align option. Press and release the OK button.
  3. Wait for the confirmation screen to be displayed on the LCD panel. Select the Yes option. Press and release the OK button. Wait for the printer to automatically align the print head and print the alignment sheet. This process should take approximately 4 minutes.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Apr 10, 2011 | Canon Office Equipment & Supplies
NO BLACK PRINTING on my Canon mx310 printer. in case of misprint please align head
Follow the steps below to align the printer
  1. Press and release the On/Off button located in the upper left-hand corner of the operations panel to turn the power on. Open the sheet feed cover on the rear paper tray. Pull out the paper support until it stops at its fully extended position.
  2. 2 Open the paper output tray. Flip the paper output tray extension out. Load a sheet of letter-sized plain paper in the rear tray. Slide the paper guide to the right until it is snug against the left side of the paper.
  3. 3 Press and release the Home button on the control panel. The Home screen will be displayed on the LCD panel. Press the Up or Down Arrow button to scroll through the menu. Select the Settings option. Press and release the OK button. Select the Maintenance option. Press and release the OK button. Select the Auto head align option. Press and release the OK button.
  4. 4 Wait for the confirmation screen to be displayed on the LCD panel. Select the Yes option. Press and release the OK button. Wait for the printer to automatically align the print head and print the alignment sheet. This process should take approximately 4 minutes.
Regards,
Shawn
Feb 03, 2011 | Canon PIXMA MX310 All-In-One Printer
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Nov 03, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
MP970 Photo All-In-One InkJet Printer: The printer head alignment is off. I have tried to...
  1. Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Rear Tray or Cassette.
  2. Open the Paper Output Tray, and then open the Output Tray Extension. (1) Put your finger in the center of the top of the Paper Output Tray and open it gently. (2) Open the Output Tray Extension.
  3. Press the Paper Feed Switch to select the paper source where you have loaded paper.
  4. Print the print head alignment pattern. (A) Press the HOME button. (B) Select Settings , then press the OK button. (C) Select Maintenance , then press the OK button. (D) Select Manual head align , then press the OK button. (E) Select Yes , then press the OK button. (F) When " Did the patterns print correctly? " is displayed, confirm that the pattern is printed correctly, select Yes , then press the OK button.The input screen for the head position adjustment values is displayed.
  5. Note:If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
  6. Look at the first printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column A that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish i nputting the pattern number for columns B to F, then press the OK button. (C) Confirm the displayed message and press the OK button.
  7. Note: If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
  8. Look at the second printout, and then adjust the print head position. (A) Check the printed patterns, and use the or button to input the number of the pattern in column G that has the least noticeable vertical streaks. (B) Repeat the same procedure until you finish inputting the pattern number for columns H to K, then press the OK button. For column K, the best pattern will be smooth and have no streaks in the border indicated by the arrow. (C) Confirm the displayed message and press the OK button.
  9. Look at the third printout, and then adjust the print head position. Check the printed patterns, and use the or button to input the number of the pattern in columns L and M that has the least noticeable horizontal streaks, then press the OK button.
Source
May 16, 2010 | Canon MP970 Photo All-In-One InkJet...
We have a Canon Pixma MP600R-how do we perform a self clean?
Hello if you are talking about print head cleaning ,first you have to Make sure that the machine is turned on, then load a sheet of A4
plain paper in the Feeder or the Cassette.After that open the Paper Output Tray, and then open the Output Tray Extension.
(Put your finger in the rounded indent of the Paper Output Tray and open it gently).Press the Paper Feed Switch to select the paper source where you have loaded paper.You are now ready to start Print Head Cleaning.
(1) Select Settings on the HOME screen.
(2) Select Maintenance, then press the OK button.
(3) Select Cleaning, then press the OK button.
(4) Select Yes, then press the OK button.
Print Head Cleaning starts.
Leave it alone for a minute or two.Another window should be open.
(5) Select Yes, then press the OK button.
The cleaning is now complete and you can check the print head condition with the printed nozzle check pattern.
Good luck:)
Jan 31, 2010 | Canon Office Equipment & Supplies
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MX340 Wireless Office All-in-One InkJet Printer Logo
215 people viewed this question
old marine
old marine
