Question about Panasonic KX-TG5632 Phone
Check tel line message on panasonic kx-tg6841
The manual says to ensure that the telephone cord is properly connected into the unit and into the wall. I have confirmed both, but the error message remains and I can't get a dial tone. It sounds like there is a phone off the hook somewhere but I can't find one of the handsets.
4 Suggested Answers
Vit Avaya BP
  • 211 Answers
SOURCE: suddenly have voice mail messages on handset
vonage gives you a personal voicemail. You should contact them and find out how to retrieve it first. If you have your companys voicemail on the panasonic you should also make sure that vonage voicemail get longer waiting time.
Posted on Jun 15, 2009
Phonesmith
  • 113 Answers
SOURCE: Panasonic KX-T7433
These phones are digital proprietary telephones which means that they only work on panasonic telephone systems and not on normal analog lines. If you have a panasonic system the correct way is to plug the line into the " To Main Unit ", the handset into " Handset/Headset" and a normal analog phone into " To Tel ". If the wiring on the line jack was not done digitally the phone will also not work
Posted on Mar 19, 2010
Testimonial: "Thanks Heaps Buddy"
  • 1417 Answers
SOURCE: message displays "check tel line". All
What you need to do first of all , put of the phone then disconnect it from the power supply allow he phone for about five minute ,then put it on again check the phone respond on your command if the problem remain same or solve.
Note if the problem remain then you will need to send me the name and the mode /serial number of the phone to guide you further.
Thanks.
Posted on Sep 06, 2011
Changing voice mail message panasonic kxt7731
The KX-T7731 isn't an answering machine.
If the voicemail is on an answering machine connected to your phone line, consult its manual/
If the voicemail is on the phone company's server, look up the instructions in the phone book, or conrtact the phone company.
Oct 27, 2016 | Panasonic KX-T7731 Corded Telephone
Communication error 43 message every time and with every number.Panasonic fax kx-fhd332
COMMUNICATION ERROR (Code: 43, 44) means that "A line problem occurred". There might be a problem with the phone jack where your fax machine is connected to. Try to connect the telephone line cord to a different jack and try again.
Mar 21, 2011 | Panasonic KX-FHD331 Plain Paper Thermal...
I have fax problem in my multi-function panasonic printer machine, all the power and rest functions are working other than fax, I am not getting the line dial tone when pressing monitor even the faxline is...
See Page 72 of the User Manual available here:
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Fax-Printers/Multifunction-Printers/How-To-Guides/model.KX-FLB801.H#ts
I cannot hear a dial tone.
The telephone line cord is connected to the [EXT] jack on the unit. Connect to the [LINE] jack (page 21).
L If you use a splitter/coupler to connect the unit, remove the splitter/coupler and connect the unit to the wall jack directly. If the unit operates properly, check the splitter/coupler.
L Disconnect the unit from the telephone line and connect a known working telephone. If the working telephone operates properly, contact our service personnel to have the unit repaired. If the
working telephone does not operate properly, contact your telephone company.
L The power cord or telephone line cord is not connected. Check the connections.
L If you connected the unit through a computer modem, connect the unit directly to a telephone line jack.
I cannot make calls. L The dialing mode setting may be wrong. Change the setting (feature #120 on page 22).
The unit does not ring. L The ringer volume is turned OFF. Adjust it (page 23).
Hope this is helpful. ;)
Dec 10, 2010 | Panasonic KX-FLB801 All-In-One Laser...
Panasonic KX-T7433
Feb 16, 2010 | Panasonic KX-T7736 Corded Phone (KXT7736)
What is wrong when the phone says Check tel line?
The telephone cord may not be connected correctly.
  1. Unplug both ends of the cord connecting the wall jack to the telephone base.
  2. Insert one end of the cord to the TEL LINE jack on the base.
  3. Make sure that the cord is inserted correctly in the TEL LINE jack on the phone.
  4. When you insert the cord you should hear a click.
  5. Insert the other end of the cord to the wall jack.
  6. Make sure cord is inserted correctly.
  7. You should hear a click.
Feb 02, 2010 | Uniden DECT 6.0 Cordless Phone ID
My KX-T7730 can't display, no tone.
KX-T7730 Phone must be connected with a 4wire line cord. you may be tested it with a 2 wire line connector.because other normal phones only needed 2wire line cords.Just connect a new 4w cord to under socket located to main unit & other end connect directly to the tel;system & see is the phone confirmed OK.
& let me know .Good luck.
rishanranatunga@gmail.com
May 25, 2009 | Panasonic KX-T7730 Corded Phone
Message reads: "Check tel line"
You can remove your telephone line from the base unit and fix it to stranded telephone unit and hear the dial tone.If it heard then some inductor or else part may be broken inside the base unit due high current surge.If the dial tone didn't heard from the other phone also check for the corroded line cord or modular box fault with the tel line.There should be 30 Volt-50Volt D.C.Voltage at your wire ends.
Rana.rishanranatunga@gmail.com
May 18, 2009 | Panasonic KX-TG1033S Cordless Phone
Panasonic KX-FPG371
Can you fax out? if not, look at the ports where the tel cord comes in from the wall. There are probably 2 ports. One labeled "line" or "wall" and the other labeled "tel" or "acc". MAKE SURE the cord in plugged into the "line" or "wall" port. If it is plugged into the other, you will still get a dialtone, but you will not be connected to the faxes modem. Hope that's all it was. If not let me know Ed
May 17, 2007 | Panasonic KX-FPG371 Plain Paper Thermal...
Panasonic KX-TG5632 Phone Logo
42 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
