Question about Lexmark OfficeEdge Pro4000c - multifunction fax / copier / printer / scanner color
Officeedge pro4000 181.514 service error
With new Windows 10, I'm getting error msgs when I scan docs, what can I do other than turn the Lexmark OFF and then ON, to get it to communicate without error messages ?
did you update the driver for the printer
see http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_UK&productCode=LEXMARK_PRO4000#2
Which o/s as not mentioned by you if 32 bit or 64 bit version guessing 64 bit version on link above as there was a windows 10 32 bit version available also
Oct 12, 2015 | Lexmark OfficeEdge Pro4000 Inkjet...
How do I fix Service Engine Error 181.514. INK Sense BPD Prine Error.
Have you removed the plastic covering the ink jets on a new cartridge?
Feb 21, 2015 | Lexmark OfficeEdge Pro 5500T Multifunction...
Service engine error 181.514
Service Engine Error 181.2049 Maint failed to prime back pressure
This error most frequently happens during the initial printer setup. Another reason for this error to occur is when using malfunctioning cartridges or cartridges that do not have enough ink to complete the initial setup of the printer.
Inserting a new set of setup cartridges or by using the setup cartridges provided with the machine would resolve this issue. To identify whether you are using the setup cartridges.
If you are already using the new setup cartridges, unplug the power adapter from the back of the printer and re-plug it after five seconds and let the machine attempt a second initial setup.
Jul 26, 2014 | Lexmark OfficeEdge Pro 5500 Inkjet...
Lexmark scanner will not scan to computer
Have you tried scanning using our Lexmark Printer Home software? To access the Lexmark Printer Home software, on your computer, click on Start > All Programs > Lexmark > Lexmark Printer Home.
If it doesn't work, please contact our technical support team so they can do some diagnostics.
Jan 04, 2013 | Lexmark OfficeEdge Pro4000c -...
Loud fax noises
Just press the Home button > Setup > Fax Setup > Dialing and Sending > adjust the volume.
Oct 25, 2012 | Lexmark OfficeEdge Pro4000 Inkjet...
Lexmark officeedge pro550 print drawer won't close with legal size paper in it
That's normal. If you extended the tray to accommodate legal-size paper, then the tray sticks out from the front of the printer when inserted.
Aug 24, 2012 | Lexmark OfficeEdge Pro5500 - multifunction...
I have a pro4000 series. How can I stop it from printing a confirmation page for the fax?
On the control panel of your printer, press on the Home Icon > Setup > OK > Fax Setup > OK. Go to fax reports and turn off print confirmation page.
Aug 15, 2012 | Lexmark OfficeEdge Pro4000 Inkjet...
Lexmark service mode
Do you mean Demo Mode? Try to check this article on how to turn it off: http://bit.ly/SxJ28n
May 25, 2012 | Lexmark OfficeEdge Pro4000c -...
Scanner wont work
Try to uninstall the Lexmark driver and download an updated driver online: http://bit.ly/N1OgZm
Also, check this article: http://bit.ly/N1OqQv
May 12, 2012 | Lexmark OfficeEdge Pro5500 - multifunction...
Lexmark OfficeEdge Pro4000c - multifunction  fax / copier / printer / scanner   color Logo
90 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
