Question about IBM E54 15" CRT Monitor
Customer display input divce not support
I want to open ma computers divce but is not opening and the divces name is combo 52x what should i do to make it open
Good day. I think your referring to your DVD or CD drive.. There should be a pinhole there.. just need to stick a pin or a needle and it will open your device. Hope this information help you. Have a great day
May 29, 2011 | Computers & Internet
How do i hook up my ps3 with tv through hdmi as it keeps goin to blue screen
  1. Connect the PS3 standard composite video connector (yellow RCA plug) to the TV composite input and switch the TV to that input. Leave the HDMI cable connected.
  2. Make sure the PS3 is off. Turn it on and hold the power button until you get two beeps (at least 5 seconds). The PS3 navigation screen should be shown on the TV. If not, switch the TV back to HDMI; the screen should be displayed at 480i resolution.
  3. Go to the settings menu. Select Display Settings, then Video Output Settings, then press the X button on your controller.
  4. The on-screen instruction should be "Select the type of input on your TV." Select HDMI, then press the '> (solid right triangle) button on your controller.
  5. You will be offered the choice of Automatic or Custom settings. Try Automatic first (if there is a problem at the end, start over and pick Custom the second time).
  6. Press the X button. You will get a screen asking you to confirm the changes. Press the X button again to confirm.
  7. You may get a screen asking for the resolution setting. IMPORTANT: if your TV's maximum resolution is 720p or lower, do not pick a higher resolution. The TV may not display properly or may not display at all (blue screen). Pick the highest resolution your TV can display.
  8. Confirm this by selecting "Yes" and pressing the X button.
  9. The settings list should now read Connector Type HDMI; Resolution Standard (NTSC); 480p; 720p; 1080p (if applicable). Press the X button to confirm.
  10. You may be offered a choice of audio outputs; you can use HDMI or something else, depending on your setup. Confirm the setting and press X one more time.
At this point, the PS3 should send its signal to the HDMI port following restart. If your TV has more than one HDMI input, make sure you select the one connected to the PS3.
Mar 12, 2011 | Televison & Video
Input not supported error
The native resolution for the x193w monitor is 1440x900. The monitor will only allow certain resolutions. You may need to create a custom resolution using the nvidia control panel.
Goto:
advanced options display change resolution customize create custom resolution horizontal pixels : 1440 vertical lines 900 refresh I belive is either 75 or 60. Whichever looks better scan type: progressive
Feb 22, 2011 | Acer X193W LCD Monitor
LGA connection
You have to select the correct input source, for your television to recognize the computer as the input source. After completing the hook-up connections. Turn on the television. Use the television remote to select the input source. 1.push the input button 2. use the up and down arrows to find the VGA input and press enter.Now turn on you computer and adjust the display controls of the computer if necessary. This information was found on the Dynex website in the owner manual on page 8. The website can be found with this link.(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) Just copy the link and paste it into your address bar. You can find a customer section and communicate with customer service through the e-mail service. You can also call the customer service at the customer service telephone number 1-800-305-2204. Give them the model number of the television and the problem you are having connecting it to the computer. I hope this information helps you with your problem.
May 30, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Vista divce
Go to control Panel - System - Device Manager. Find out Which device has Yellow question Mark. Then Right Click the same and click on UPDATE DRIVER. (While doing this confirm that you are connected to Internet). then follow Recomended options.
Feb 24, 2009 | Microsoft Windows Vista Ultimate Edition
I can't get your website to update my tomtom divce. It tells me to go www.tomtom.com/home and reinstall. But I can not fined the place were it says to, reinstall. I realy enjoy my navigator. Plus I...
reinstall. I realy enjoy my navigator. Plus I move
from Missouri to California, and I update that part.
Please help fix this problem.
posted by lakend
Nov 01, 2008 | Tomtom GO GPS Receiver
Printer does not support
4355 HP all in one does not support driver for VISTA32 ??
Link download ????
Jun 27, 2008 | HP Officejet 4355 All-In-One InkJet...
HTC Touch Display lights constantly on while music playback ... Please Help
the screen display remains on if you're listening to music on the speakers. i've tried many things but couldn't overcome it. the only thing you could do is use the headphone to listen to the music. you can then put the device to sleep mode without interrupting the music.
Jan 22, 2008 | HTC Touch P3450 Smartphone
N0 sound on my labtop
go to device manager and let windows reinstall sound card
Dec 06, 2007 | Medion (40010998)
IBM E54 15" CRT Monitor Logo
10 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
