Question about Kenmore 93702 Top Load Stacked Washer / Dryer
Water keeps draining
I have a Kenmore stackable washer/dryer and the washer will drain slightly while water fills so every 20 seconds or so of washing it will refill water again.
  • 3 more comments
  • Anonymous Mar 12, 2014
    this is an older washer dryer combo. It is not a stackable unit. the problem is that when the washer enter sthe rinse cycle water comes out the bottom of the machine as soon as the washer stars draining.
  • Anonymous Mar 14, 2014
    my washer keeps filling with water and the water is draining right out. Never washing clothes.
  • Anonymous Mar 19, 2014
    The washer keeps filling with water after it's done with text wash
  • Anonymous Mar 20, 2014
    when adding detergent add water softner to washer and then running the wash the softner remain in the fill compartment
  • Anonymous Mar 27, 2014
    Ge washer dryer stackable washer won't drain out water and dryer when turned on will pop house breaker
  • 5,911 Answers
You may be experiencing what is known as "siphoning".  If you have your drain hose shoved too far down in the drain standpipe, or if you have the top of the standpipe opening sealed off, sometimes it creates a vacuum and will cause the washer to drain constantly drain.  You need an air gap in order to prevent this.  Double check your drain hoses for the following:
1. Make sure the hose is only placed in the standpipe about 3 to 4 inches.  If it is sitting so far down in the pipe that it is resting in the trap where all the water is it will siphon.
2. Check the opening around the top of the standpipe where the hose rests.  Makes sure there is still an air gap around the hose.  That is, make sure the hose isn't seated so tight that it seals off the standpipe completely.  This will cause siphoning.
3. Make sure you haven't placed anything around the standpipe opening.  Many people will wrap old towels or wash cloths around the opening in order to prevent overflows and odors coming back up through the pipe.  In doing so, they often inadvertently seal off the standpipe and cause a siphoning problem.
Last of all, the standpipe should be about 36 inches from the floor.  If your drain line is sitting too low it can also cause siphoning issues.
I know I'm keying in on this drain line issue quite a bit here.  There are some other things that can cause water levels in a washer to drop, but you mentioned nothing about any leaks and this is the most common problem.  You will know for sure if you pull the drain hose out of the standpipe and suddenly hear a sucking noise.  This is air being reintroduced through the drain line.  I hope you find this information helpful.
Posted on Oct 27, 2007
Stackable kenmore washer dryer
could be a clogged pump or drain hose causing the water to spin over the top
Jan 15, 2013 | Washing Machines
98702 Stacked Washer / Dryer Your question about 98702 Stacked Washer / Dryer has been posted. Mom has a Kenmore stackable washer. She ran water in for a load and the water ran out of the washer and onto...
Get the control panel off and remove the water pressure tubing. Blow it out and reconnect to pressure switch. Remove water so that pressure can once again build inside the tube. Retry>
Oct 22, 2011 | Kenmore 98702 Stacked Washer/Dryer
Water drains out the back left corner when the tub is filling. Water will not stay in drum. What could be the problem. Its a stackable Kenmore.
Could be the over flow sensor tube thats attached to the side of the drum has come off or one of the drain hoses. Take the front panel off by unscrewing the 2 screws at the bottom and pushing down on the panel to unlock. From there you should be able to see with a flashlight where the water is coming from.
May 17, 2011 | Kenmore 98702 Stacked Washer/Dryer
Ge stackable washer dryer MODEL wsm2700wbwww
3 year old GE stackable washing machine, had water coming out the top and would not drain or go through cycle, when shut off it drained a little but when turned on again it filled up and over flowed.
Apr 18, 2010 | GE Spacemaker Washer and Dryer Electric...
Water under stackable washer dryer
The front panel comes off and you will be able to trace the water source. These combo units spin immediatly and if the drain is slow the water will spin up over the edge of the tub during drain.
Eric
Dec 24, 2009 | Kenmore 98702 Stacked Washer/Dryer
Our kenmore stackable washing machine on the rinse and wash cycle is not filling up with water. the water keeps running out
Make sure the drain hose is not pushed too far down the drain pipe. It could cause a siphon effect and drain the tub.
Make sure the drain hose is not tight in the drain pipe. It should fit loose so as not to trap the air which can also cause a siphon effect.
Dec 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable w/d will not drain or spin
You will need to replace the switch I am afraid. If I had your Model # I could get you the part # . If you would like to order a swtich, I can give you my web site address
I would appreciate if you would rate my prfomance here because I am new to this site. Any feed back on how I am doing would be helpful.
Thanks
Vic
May 09, 2009 | Kenmore 88752 Top Load Stacked Washer /...
Stackable kenmore model 41794702300
We have had that happen too. You will need to take out what ever has blocked the valve on the drain. Ours was a bobby pin! My model is a bit different but if you follow the drain hose underneath you can find it. Remember you are dealing with lots of water. I think I scooped out the water first and have some towels ready. Or hire somebody to do it for you. I hope that helps.
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 93702 Top Load Stacked Washer / Dryer Logo
460 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
