Question about Sharper Image SHP921-2 Wireless Headphones - 2 Pack, Black
Cannot get the earphones to connect with the tv. on recieves radio on both settings
There isn't an audio out on my tv and I wanted to hook up a sub with surround sound
A couple of ideas. 1st does the TV have an earphone jack or AUX out . If so you can get an adapter to go from this plug to your line in on your reciever(if using the earphone jack set the volume low and adjust it up to a suitable level. Too much input from earphone jack could damage system). 2nd if you have a satelight or cable box it may be possible to hook a sound sysyem through these devices instead of the TV. If not using these devices you could get a digital TV conversion box on a whether you need it or not basis and run line out on some of these also.
May 05, 2011 | Curtis-Mathis Televison & Video
How to connect my computer audio to pioneer vsx515 reciever..
here the steps:
1. locate the earphone jack on your pc.
2. after finding the earphone jack from your pc you need a connector (baby stereo plug to 2xrca plug).
3.connect the baby stereo plug to your earphone jack and then the rca plug to your Pioneer axuliary in.
Jan 02, 2011 | Pioneer VSX-515 Receiver
The Yamaha Reciever RX-V465 is connected to my digital TV by fibre optic cabel. I have sound when I connect my MP3 to the V-Aux and the speakers are displayed on the display window of the Reciever same as...
Please check your TV settings and the optical cable.
The speaker icons disapper from LCD display when the receiver does not detect any input signal throught the optical/coax/hdmi cable.
Dec 13, 2010 | Yamaha Rx-v465/rxv465 Home Theater...
I'm trying to set up my Onkyo HT-r380 receiver (which came in the HT-S330 home theater system). I can get AM and FM radio to play on all the speakers. I can not get sound from my XBOX 360. The 360 is...
I looked at the manual and they provided the following settings.
To listen to audio received by the HDMI IN jacks through your TV's speakers:
  • Set the "TV Control" setting to "On" (? 37) for an p-compatible TV.
  • Set the "Audio TV OUT" setting to "On" (? 36) when the TV is not compatible with p or the "TV Control" setting to "Off".
  • Set your Blu-ray Disc/DVD player's HDMI audio output setting to PCM.
  • To listen to TV audio through the AV receiver, see "Connecting External Components" (? 17).
Jul 19, 2017 | Audio Players & Recorders
Cant recieve or output , I bought a new cable and antenna plus a swr meter.
With an antenna connected, volume set to 1/4 from minimum, squelch / RF squelch fully counter-clockwise (or minimum) - do you hear anything from the speaker? If not - plug an earphone / external speaker into the external speaker jack on the rear - any sound? If not, do you see the S/RF meter needle moving (not resting on 0 or 1)? If not - find a channel with activity on as indicated by the S/RF meter first.
Try with another antenna connected if possible, or transmit with another CB radio on the same channel nearby - and try again.
If you aren't able to receive sound (not just static) - or indicated signals on the S/RF meter, the radio *MAY* need to be professionally serviced. Make sure you get an estimate for the work before authorizing - otherwise you may be spending more on a repair than the radio is worth. It is not uncommon to have to pay a diagnostic fee - that most shop will put toward the repair if allowed to do the work.
Sep 07, 2010 | Cobra 29 LTD CB Radio
Only the radio output works but no sound if connected to TV or DVD player ?
you will probably have to set the correct input on the reciever, those two inputs will be able to recieve a digital input i,e coax or optical or the traditional analog (red and white ) jack.. the reciever might not know which type of cable your using for the tv and the video input..
Sep 07, 2010 | Kenwood VR615 Receiver
I've connected the minijack from the laptop to the phono slots red and white on my tv but there is no sound. Could you help me please
Often there is NOT enough output to drive the TV's audio amplifier directly from the earphone's port. You will need a small Pre-amplifier, in between the two, You should also try your "Line Out" as that puts out more signal, than the earphone jack. If that still will not drive it, then toy will need a pre-amp, Radio Shack, or the like will have them. Also ensure your Volume is set high.
Feb 26, 2010 | Sony VAIO VGN-N130G/W Notebook
I have the Delphi MyFi xm2go. It is not the newer version, SA10113. My problem...It is no longer transmitting to my car's FM radio. While it is sitting in the cradle in the car, it 's display shows that it...
Make sure that this is NOT a "Sure Connect" version that has a very weak FM transmitter, but the older original model with a bland box. Make sure no earphone is plugged-in, then go to the menu and set the FM frequency and set the FM output level and you should be all set..
Jan 20, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
Chang Jiang N958
assuming it is a wire earphone which comes bundled with the set then
as soon as u plugged in the set should detect and show 'earphone plugged in', if not the problem is with the earphone itself.
If it is ok and can,t hear, check for the user profile selected as 'Headset'.
Now turn on the radio.
To check whether FM is working or not [diagnostic verify]Warning: DO NOT CHANGE ANY SETTINGS
enter *#66*# to enter Factory mode. Go to the end of the menu & select FM Radio --> select any channel to listen hiss sound. If so the set is ok. EXIT now. Mind that the earphone wire only works as fm antenna for the device that's why radio is disabled by default till it finds the earphone is plugged in.
Keep some space blank in the phone memory as it may be the problem.
if the problem is something else then describe what is happening stepwise.
Oct 08, 2008 | Nokia N95 Cellular Phone
How do i know if my amp is blown
Hey Yoo,
Go to Radio shack and get you an adapter that will take an earphone jack and convert it to RCA male.  You use this to simulate the signal coming from the reciever.  Hook up to a Cd player or Walkman, anything with an earphone output jack. Test that the device actually puts out music or anything worth listening to.  Connect the device to the input of your amp, with the car running, and the reciever turned on.. This will tell yo if the signal is getting from the reciever to the amp. You may not be getting signal from the head unit.
If you still get no sound to the woofers, dsisconnect the woofers and try a different speaker.  If that speaker dont work,  Change setting and switches., and if you still get no sound, then your amp is toast.
Oct 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Sharper Image SHP921-2 Wireless Headphones - 2 Pack, Black Logo
18 people viewed this question
Top Sharp Kitchen Ranges Experts
William Miller
William Miller
 John
John
Gil Shultz
Are you a Sharp Kitchen Range Expert? Answer questions, earn points and help others
