Question about Frigidaire FPHS2687KF Side by Side Refrigerator
FRIGIDAIIRE MODEL LPHS2687KFO KEEPS TURNING ON AND OFF BEEPING RELAY CLICKING
Relay keeps clicking and furnace will not start
try turning off the power to the furnace, wait about 10 to 15 minutes, then turn the power on, it might work, if not, the relay is bad
Oct 29, 2014 | Dayton Gas Furnace Heater
Laptop computer will not power up. using power cord and keeps beeping three times every time when powering up.cleaned ram contacts and reseated these. still no change!
Suggest Anti-Static Procedures need to be followed, laptop opened up, and cooling system cleaned.
Also suggest replacing Thermal Paste on Processor, and Thermal Pad on graphics chipset. (Piece of small copper sheet would be better)
What is the Dell's model name and model number?
Bottom of laptop.
Post back in a Comment.
Regards,
joecoolvette
Apr 05, 2013 | Dell Studio Computers & Internet
2000 jeep grand cherokee reverse jumped the car
Check for a dead battery or bad starter solenoid,
loose battery cables both ends
Nov 13, 2012 | Toyota Cars & Trucks
Philips Magnavox 32MT3305 keeps shutting off with relay clicking. The green power light stays on but the picture and sound go out right after the orange status bar goes away. If the channel up or down...
the relay is the safety protective device..sometimes a defective component or something. maybe an overloaded power supply might caused this problem..so before any thing could gets worst..the relay will shut the unit..
Jul 18, 2011 | Philips 32MT3305 TV
Compressor keeps clicking off and on and fridge just keeps beeping
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 09, 2011 | Microwave Ovens
The fridge keeps beeping. Door is closed. Different beep than door beep. Tried turning off and turning on again, keeps beeping.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 22, 2010 | Fisher and Paykel Active Smart E522B...
Relay turning on then off, on then off
Could be a compressor relay.  You don't say anything about whether the unit is working or not.
Nov 20, 2008 | Refrigerators
Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Aug 19, 2008 | Dacor Preference RSD30 Gas Kitchen Range
F7 error code
f-7 means either the touch pad is stuck or a relay on the control board is stuck. if the code came up while the oven was not being used then the touch pad is shorted. if it came up while in use then the controlboard is bad
Nov 22, 2007 | GE JGRP17 Gas Single Oven
Frigidaire FPHS2687KF Side by Side Refrigerator Logo
90 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
