Question about Sportsart Exercise & Fitness
I have a Powerobics XT450 treadmill which slowly gets faster as you use it. It has a speed controller board with 1090NDRV SPORTS ART 97/04/25 marked in it.
Can it be repaired or do I have to replace the controller board
  • 14 Answers
SOURCE: replaced the motor controls
Is there a sheet of paper under the motor hood? It has the procedures for this calibration of the motor speed. Caution ! You should use a plastic screwdriver to make adjustment to the speed control on the motor controller. It is high voltage
Posted on Jul 08, 2009
  • 73 Answers
SOURCE: Running belt slips om treadmill Sports Art 1060
Either the belt has stretched (normal wear over time) or the tension needs to be readjusted to tighten it. Every treadmill is different, and some can't be adjusted, so I can't really help with particulars, but if you get down and look really carefully, you'll be able to find the tension adjustment mechanism if it exists. Good Luck.
Posted on Dec 07, 2009
maxtreadmill
  • 832 Answers
SOURCE: sportart 6310 treadmill - check speed sensor
Unplug unit and check the motor brushes they maybe worn and need to be replaced call Sports Art Fitness customer service @ 1-866-709-1750 they will sell you the brushes
Posted on Mar 13, 2010
maxtreadmill
  • 832 Answers
SOURCE: Athlon iQ2 treadmill-just replaced motor control
If this is the same problem you had prior to replacing the MCB and speed sensor. I would check the drive motor, unplug unit then remove motor shroud then unplug the connectors leading to the motor itself. If you have wire leads and a 18v drill battery connect the leads into motor then attach the other end to you battery and if the motor will rotate ( approx. 1mph) , if it does the check speed sensor to see if the correct spacing between sensor and front roller ( check if the magnet has not fallen out of front roller pulley this also can cause you problems) hope this help!!
Posted on May 15, 2010
2manyhobbies
  • 129 Answers
SOURCE: I have a MC2100-12A motor
The speed sensor on these machines have nothing to do with controlling the speed. The machine will run without it. The sensor is obviously working, since you are getting a speed reading.
The calibration is a mechanical adjustment found on the motor controller, the instructions are found under the lid as well as the meaning of the LEDs flashes on the tech sheet..
Follow the calibration procedure. If the operation is still erratic, I would suspect a defective controller.
Calibration: Press stop and speed up. Install the safety key/magnet. release the buttons. Press stop 1 time. one window displays speed, the other the calibration number. Both should be "0".
Press speed up, the treadmill should begin to move around 25-30. increase to 85, the machine should be a max speed. adjust the pot on the motor board to max speed. Some machines are 10mph, others 12mph. The tech sheet will tell you the max speed. When adjusted, press speed down. the machine will stop. Now press incline up. That will calibrate the incline. When completed, remove the safety key.
If operation is still erratic, change the motor controller.. It could be the console, but the cost of replacement makes the repair in most cases uneconomical..
Posted on Dec 15, 2010
How to put in the circuit board on hotpoint aquarius wf440 ?
this may be of some help good luck
otpoint control module configuration for selfix - YouTube
? 9:21
https://www.youtube.com/watch?v=cHpz2OcbHAY
16 Sep 2011 - Uploaded by Selfix UK
Hotpoint control module configuration for selfix ... How to change the display pcb on an Ariston Washing ...
How To Replace A Washing Machine PCB - YouTube
? 4:19
https://www.youtube.com/watch?v=vskrPU9zU5M
27 Apr 2013 - Uploaded by Selfix UK
How To Replace A Washing Machine PCB ... Repair HotpointWF541 WF540 WF740 with flashing lights ...
Modules & Control Boards ' Washing Machines ' Spare Parts ' Hotpoint
parts.hotpoint.co.uk/.../washing-machines/...boards/.../C8-RIC-LVTRC-...
Have you lost complete control of your washing machine? ... If your PCB assembly (printed circuit board) is faulty then replace today for an efficient and effective ...
How to Replace Washing Machine Control Panels - Hotpoint ' eSpares
www.espares.co.uk > Home > Advice Centre
8 Jun 2010 - Replacing any of the front panel controls on a washing machine is ... how to replace any of the knobs, buttons, printed circuit boards that sit ...
How to Diagnose Washing Machine Control and Program Problems ...
14 Nov 2013 - Watch Josh explain how to diagnose washing machine control and program problems. ... If you then suspect that the problem still lies in the circuit board ... to test the board and you'll actually just need to replace it altogether.
Hotpoint WD420 fault ' Page 2 ' DIYnot Forums
www.diynot.com > Forums > How to... > Appliances
31 Oct 2009 - 15 posts - ‎11 authors
hotpoint aquarius wf530 washing machine flash like Christmas tree when ... After reading this forum I took the PCB board out and the C17 ...
Hotpoint WF540 washing machine board issue - pics included ...
www.electro-tech-online.com > ... > Repairing Electronics
19 Mar 2011 - 14 posts - ‎9 authors
Just took the board out of the washing machine to check the c17 cap ... was gonna cost £150 just for a replacement board without fitting.
Hotpoint - EMW Electronics
https://emwelec.co.uk/index.php?l=product_list&c=13
This is the Mark 6 board fitted to late Hotpoint washing machines. The module will be programmed to your model number - ready to fit. Typical models are WF550P WF560G .... Hotpoint Arcadia PCB Modules. SKU: 256. Hotpoint Arcadia PCB ...
modules and PCB's for washing machines and washers for Candy ...
www.unifit.co.uk/washing-machine-washer-spares-parts-replacement-mo...
Hotpoint SCR, WMA, WMS washing machine pcb control board ... 1200RPM 6 KG 2003 TO CURRENT LINEN), HOTPOINT - WMA58N (AQUARIUS 1400 RPM 6 ...
  1. Hotpoint Appliance Parts‎
    Adwww.hotpoint.co.uk/SpareParts‎rating for hotpoint.co.uk
    Save £5 When You Spend £35 or More! Low Cost and Next Day Delivery.
    Price Match Guarantee · Spend £35 & Save £5
  2. Hotpoint Spares - Delivered Within 24-48 Hours.‎
    Adwww.hotpoint-spares.co.uk/Shop/Spares‎Machine Spares
  3. Dishwasher Parts
  4. Cooker Spares
  5. Fridge Spares
  6. Hob Spares
  7. Replacement Circuit Board - Fried the hard drive circuit board?‎
    Adwww.onepcbsolution.com/‎hotpoint washing machine circuit board
    hotpoint washing machine control board
    washing machine pcb repairs
    hotpoint washing machine pcb problem
    washing machine circuit board replacement
    hotpoint pcb repair
    hotpoint aquarius washing machine circuit board
    circuit board for hotpoint aquarius
1 2 3 4 5 6 7 8 9 10 Next
Nov 22, 2016 | Hotpoint Washing Machines
Tip
OS or O5 Error on Landice L-Series Treadmills
Probable Cause
An OS or O5 error on the Landice L-Series treadmills, such as the L7, L8 and L9, indicates an over speed condition and this occurs when the actual speed of the running belt is faster than the set speed. The possible causes for an overspeed, OS or O5, error are: A) User weight is over 200lbs, treadmill elevation is set between 10% and 15% grade and speed is set between .5 mph and 3 mph
B) User is pushing against treadmill belt causing it to go faster than the set speed
C) Defective lower board or misaligned speed sensor
D) Maladjusted speed potentiometer
Corrective Action
A) Gravitational force will enable the user's weight to move the treadbelt faster than the set speed. The speed sensor will pick up this increase in flywheel speed and sends this information up to the display electronics. The microprocessor will then compare the actual speed to the displayed speed, determine a runaway speed condition and shut the treadmill down. An overspeed will display in the window. This is a safety feature built into all treadmills that utilize closed loop speed circuitry. The way to address an over speed condition due to gravity is have the user decrease elevation below 10% or increase the speed.
B) Similar to the gravitational force, a user can be holding onto the handrails and pushing the running belt in such a manner where they are using the treadmill like a manual machine rather than a motorized one. User needs to set speed compatible for their actual walking or jogging speed so they are not pushing the belt.
C) It's possible a blown motor control board is the problem. This occurs more frequently with PWM drives than SCR drives. However, this problem is becoming rare due to the PWM circuitry which senses this condition and shuts itself down before the drive motor receives any DC voltage at all. This means you'll get an LS or L5 error if your PWM is blown, not an OS or O5 error. This is a safety feature on all Landice home treadmills with PWM motor control boards. The SCR motor control boards also have internal protection to prevent an over speed condition from occuring due to an internal component failure. In the rarest of cases, on home treadmills, a faulty relay board can cause an OS or O5. To verify this, using a digital voltmeter, with treadmill turned on, measure the DC voltage between the V+ and P1 on the PWM board. The reading should be between 6-7 VDC. Also measure the DC voltage between P1 and P2 on the PWM board. The reading should be between 0.5 VDC and 6-7 VDC. If either of these voltages measure zero, replace the relay board.
D) Get into Open Loop Speed mode and check the speed. Adjust pots as necessary to bring up correct speed for max and min.
http://www.sportsmith.net/support.aspx?did=BAB0DA9A-857E-41B3-A1DD-3DC0663BB9A4
on Apr 10, 2015 | Landice Exercise & Fitness
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
Have a ge profile refrigerator went completely dead,repair man replaced mother board and control panel still not working, fridge is only 14 months
If there is no power after the repair man replaced the board and panel, the repair job is not complete. Have the repair man finish the job.
May 03, 2016 | GE PFE29PSDSS 29 cu. ft. French Door...
Treadmill speed is going fast when I have it at 2.5
Your variable resistor (speed adjustment switch) is going out
Mar 23, 2016 | Sole Fitness F63 Treadmill
Sports art model 1050L give me err 1 how I can fix this problem? Thanks
Reason number 1:
Explanation for ERR1 1. Motor doesn't operate; ERR1 appears. 1-1. Explanation: Drive board has not sent power to the motor, so the motor doesn't operate; the optic sensor signal hasn't returned to the display board. This is caused by either a bad mcb or a faulty motor.
Reason number 2;
Reason for ERR1 2. Motor operates; ERR1 appears 2-1. Explanation: The motor operates; the optic sensor signal didn't reach the display board CPU; ERR 1 appears. In this case the issue is more than likely a faulty speed sensor or a there is dirt, lint or other debris blocking the speed sensor from reading the disc.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Dec 19, 2015 | ART Exercise & Fitness
Sports art model 1050L err 1 how fixed ?
Reason number 1:
Reason number 2;
Pro form sport 1000 treadmill goes full speed on power up
Typically when this occurs, it is an indication of a short circuit in the motor controller board. To test to make sure the problem is in the board
1) Unplug the treadmill from the wall.
2) Remove the motor hood.
3) Unplug the speed wires from the board. On many boards, you will have 2 to 3 wires that control speed and many are labeled H, W, and L. If you cannot find the speed wires, do not guess, contact us with your make and model number and we will try to help you with the wiring.
4) Return the treadmill to a usable position once the speed wires are disconnected and plug the treadmill back in.
5) If the treadmill begins to run at full speed, the motor control has failed and requires replacement.
6) If the treadmill does not run at full speed you could have a speed input problem, wiring problem, or another short circuit.
For any further troubleshooting questions please do not hesitate to contact us, our number is 888-713-2880 or check out our Tech Support Center online
http://www.sportsmith.net/supportsearch.aspx
Always hear to help, SportSmith
May 16, 2015 | Proform Sport 1000 Folding Treadmill...
6300 sports art wony incline at all
hi
check inline fuse
if you start it and incline reads more than o when pressed it is fuse
it is lokacted on motor controll board
there is 2 one for drive motor one for elevation motor
cll if assistance needed 347 515 8670
Nov 17, 2010 | Sportsart 6300 Treadmill
What does F1 mean for a whirlpool cabrio
F1 error code is for main board failure, replace main board
Sep 07, 2010 | Washing Machines
Exercise & Fitness Logo
89 people viewed this question
Top Sportsart Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Steven Brandon
Steven Brandon
Sportsmith LLC
Sportsmith LLC
Are you a Sportsart Exercise and Fitnes Expert? Answer questions, earn points and help others
