Hello, I own a Kelvinator Split System Aircon KSE26HRB but I has a blinking orange light and won't turn on, what do I do?
It keeps flashing but won't turn on, I've tried turning it off on the wall switch and then back on again and it works for a couple of minutes then turns off and the light starts blinking again and won't turn on from the remote.
rayname
  • 70 Answers
SOURCE: hi i have kelvinator ksr25f
If fresh batteries dont help check if sensors are clear try removing power then restart unit
Posted on Jan 05, 2009
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
bobotfel
  • 236 Answers
SOURCE: LG Split unit turns itself off after a couple of seconds of opera
Check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Posted on Feb 16, 2009
skrbin
  • 121 Answers
SOURCE: samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
  • 400 Answers
SOURCE: i have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
Posted on Nov 18, 2009
Nuova simonelli manual switch flashes
it means that no water is flowing on the flowmeters. need to check flowmeters if clogged
Jun 03, 2013 | Nuova Simonelli Coffee Makers & Espresso...
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Wii won't turn on.
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
Jul 22, 2012 | Nintendo Wii Console
Dodge headlights keep flashing off
try to check your relays ,may need to replace them and check all your fuses
May 13, 2012 | 1998 Dodge Dakota
Washing machine keeps beeping then all lights and screen start flashing.
i would guess that you have a faulty main board, the quickest and surest way to determine the problem and that is to replace it with a second hand board out of an known old machine which has faulty seals.
Dec 11, 2011 | Fisher and Paykel Washing Machines
I have a rennai energysaver 556ftr heater, and the filter and on light keeps flashing red, i've taken out the filter and cleaned it, but still the lights are flashing. what's wrong?
If you removed the filter to clean it, while the unit was ON, that may be the problem. Turn the Master ON/OFF Switch to OFF and unplug the unit from wall outlet. Leave unplugged for 15 minutes. Remove and replace the filter. After 15 minutes has elapsed, plug the unit into the wall outlet and turn the Master ON/OFF Switch to ON. The unit should have reset itself and reverted back to the original factory default settings. In which case, you can change the settings to what you desire.
Just remember to always turn the Master ON/OFF Switch to OFF, when removing the filter to clean and replace it.
Hope this helped you solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Heating & Cooling
Subzero--Vacuum Condenser Signal Won't Turn Off
The vacuum condenser indicator keeps flashing on and off. I did vacuum the unit, the the indicator lights keeps flashing on and off. How can I reset it and keep it off?
Thanks,
Rob
Aug 22, 2009 | Sub-Zero 650 / O Bottom Freezer...
Fisher&Paykel Smart Drive 051 keeps beeping/not draining
Hi, I have the same problem and for my wahsing machine it is block pump, so I turn the machine on and advance it to spin and turn the pump fan to help clear the block, the pump locate at the buttom of the basket of the machine...
Mar 31, 2009 | Fisher Washing Machines
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
