Question about iHome by Lifeworks Technology IMAC-M110W Bluetooth Mac Mouse - White
IHome IMAC-M110W driver download
Where can i download the mouse driver
How do you connect ihome laser wireless mouse
The instructions are here... http://www.manualslib.com/manual/75850/Ihome-Ih-M170zr.html
Jul 04, 2014 | HP (C4736A) Mouse
Ihome IH-M826WC driver
The Microsoft mouse driver usually works with all pointing devices. It also has an extensive library of devices. Try different ones until you find the one that works.
Apr 16, 2014 | iHome IH-M826WC Black 5 Buttons 1 x Wheel...
Serial number 13 06 005713
if you are using a windows PC then the mouse wont be picked up Ihome is an apple specific company you might be able to find someone who has got it to work but I would suggest returning it and buy a mouse compatible with all platforms
Jan 12, 2014 | Computers & Internet
This is a problem with a iHome Laser Mouse product. ihome 3-Button Laser Mouse Model Number- iH-M120LB Serial Number:0906001183 I am having trouble using the left click button on the mouse. I...
When you change the left mouse pointer to be the right mouse pointer in the settings of the mouse, then if the right mouse button stops working, it is a software problem and reinstalling drivers is the way to go. If on the otherhand the left mouse button still does not respond, then there is a problem with the switch in the mouse. This is hardware related. Either clean the mouse or buy a new one.
May 11, 2017 | iHome 3 Button Fast Track Laser Mouse...
Mouse double clicking one click
I think the keys are in reverse.
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/win_reverse_mouse_buttons.mspx?mfr=true
Jul 17, 2013 | iHome Computers & Internet
I have a new iHome Optical travel mouse on my laptop. I can't get it to work.
Did you put in new batteries.
Did you try a different USB port.
Did you go to start button, control panel, windows update, run windows update, if it needs a driver, win update might find it.
Usually windows will use a generic driver for any usb mouse and as soon as you plug it in windows see's it.
It should have come with a disk, maybe there is a driver on it, but rare windows can't find it.
If you try these things and noting, its the mouse, contact the seller or the MFG and ask them for help, send email.
Mar 11, 2013 | iHome Optical Travel Mouse
IHOME Wireless Optical Mouse DRIVER
Driver related problems can be solved by downloading this tool: Driver Update Software for XP Vista 7 8.
wish you best of luck
Cheers
Dec 25, 2012 | Computers & Internet
Troubleshoot iHome optical travel mouse
which operating system xp windows vista or 7 ?
make sure you have the right mouse select in control panel
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x
right click you will need to update the driver
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall
make sure you have the right mouse selected click start control panel mouse hardware you will see which mouse is selected in xp
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
for the double click this will be in the folder options follow previous to get to control panel items
click start control panel navigate folder options tick in the double click to open circle
hope this helps
Sep 15, 2012 | iHome Optical Mini Travel Mouse W...
I installed the drivers manually i have no cd but windows 7 will not recognized the driver and still say driver is not successful in installation i need help!!
iHome IHW311NN is compatible with Windows 7 and no addition drivers are required. However, the drivers are available at iHome Official Support. Visit this link and download the latest drivers.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Jan 17, 2011 | iHome IHW311NN Web Cam
iHome by Lifeworks Technology IMAC-M110W Bluetooth Mac Mouse - White Logo
198 people viewed this question
Top iHome Office Equipment & Supplies Experts
jasbo
jasbo
Are you an iHome Office Equipment and Supply Expert? Answer questions, earn points and help others
