Question about Image 17.0R Treadmill Front Roller
It starts for a second then turns off - Image 17.0R Treadmill Front Roller
Occasionally, about every 6 to 8 times tried, the engine will turn but not start. If I turn the key off for about 3 seconds, it usually starts within a few turns. Do you know what can cause this?
A year, make, model, and engine size would help but I will through this at you.
Instead of just trying to start the car turn the key to the run position and wait 3 seconds. Turn the key off and immediately turn the key back to the run position and wait another 3 seconds. Turn the key off then try to start. Do this every time you try to start the car. If you symptom never occurs when you start the vehicle like this than I would suggest taking a closer look at the fuel system.
Oct 10, 2016 | Cars & Trucks
Tip
How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe
Hi, on most vehicles, the airbag light should come on for at 6 seconds, and then go off if the system is working properly. If there is a fault or a problem in the system, the light will remain illuminated, or flash continuously. If the airbag light does not work properly, some vehicles have an audible tone that sounds indicating a problem with the airbag light system. When the light is on (or the tone is sounding), the airbag will NOT deploy, even in an accident. <br /> The flashing light on your car is telling there is a problem. <br /> <br /> <b>How to reset AIRBAG SRS Light on 2003 - 2006 Infiniti G35 Coupe </b> <br /> Ignition Key Method: <br /> <ul> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.</li> <li>Wait 4 seconds.</li> <li>Turn IGNITION on (but don't start car).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 2 seconds.</li> <li>START Car (the light may be blinking slower than before).</li> <li>Wait 3 seconds.</li> <li>Turn IGNITION off.</li> <li>Wait 3 seconds.</li> <li>START Car.</li></ul> <br /> <b>This is a little easier</b> To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
on Dec 07, 2010 | Infiniti G35 Cars & Trucks
Tip
How to reset ECU,Throttle and Accelerator Position Learning
Hi.
Below the procedure to reset ECU,Throttle and to perform Accelerator Position Learning on Nissan. It works on Titan, Altima, Infinity, pathfinder and other models.
ECU Resetting
While performing the procedures below, ensue that you are respecting the times stated. If the steps are not done within the specified times, the module will not reset. You will need to use a watch or a chronograph while performing the procedures.
Procedure:
1. Ensure that the accelerator pedal is fully released, set ignition switch to the “ON” position, then wait 3 seconds.
2. Follow the steps a and b below, repeat the two steps in sequence quickly for five times within 5 seconds.
a. Push hard the accelerator pedal untill fully depressed.
b. Release the accelerator pedal in full.
3. Wait 7 seconds, then depress the accelerator pedal completely, and hold it for about 10 seconds until the CEL (check engine light) starts blinking.
4. Release the accelerator pedal while the CEL is still blinking.
5. Wait 10 second.
6. Depressthe accelerator pedal in full and hold it for 10 seconds or more.
7. Fully release the accelerator pedal while the CEL light keeps flashing.
8. Turn the ignition switch to “OFF” position and start the vehicle. If procedure has been done correctly, then the light light will turn off.
If the light continues to stay on, repeat the procedure.
Accelerator Pedal Release Position Learning
Procedure
1. Ensure that the accelerator pedal is completely released before starting the procedure.
2. Turn the ignition switch “ON” and wait at least 2 seconds.
3. Turn the ignition switch “OFF”, and wait at least 10 seconds.
4. Turn the ignition switch “ON” and wait 2 seconds.
5. Turn the ignition switch “OFF” and wait 10 seconds.
Throttle Valve Closed Position Learning
Procedure
1. Ensure that accelerator pedal is completely released.
2. Turn ignition switch to the “ON” position.
3. Turn ignition switch to the “OFF” position and wait at least 10 seconds.
Ensure that the throttle valve moves after turning the switch off.
Idle Air Volume Learning (Throttle Position Learning)
Procedure
1. Follow the Accelerator Pedal Released Position Learning described above.
2. Do the Throttle Valve Closed Position Learning also described above.
3. Start the engine, and allow warming up.
4. Turn the ignition on “OFF” positionand wait 10 seconds.
5. Ensure that accelerator pedal is fully released, then turn the ignition switch to “ON” position, and wait 3 seconds.
6. Repeat the steps a and b below five times within 5 seconds in sequence.
b. Release the accelerator pedal until reaching full extension.
8. Wait 7 seconds or more, depress the accelerator pedal completely and hold the pedal down for about 20 seconds until you see that the Check Engine Light stops blinking and starts getting steady..
9. Rrelease completely the accelerator pedal within 3 seconds after the light coming ON.
10. Start engine and let it run at idle for about 20 seconds.
12. Test the engine to ensure the idle speed and ignition timing are set correctly.
Regards.
on Mar 25, 2010 | Nissan Titan Cars & Trucks
How do I program a transponder key for the ignition in a 2009 Pontiac Vibe?
first the first digit must start with the number 1,or 4 of your 17 digit number for this to work.so fit your chip key in your ignition.
1, insert the key in your ignition turn the key to on for 10 min 30 seconds
2, within 45 seconds turn the key to off then back on for 10 min 30 seconds
3, within 45 seconds turn the key to off ,then back on for 10 min 30 seconds then back on for 10 min 30 seconds.
then after 10 min 30 seconds turn off then on .then start the engine.
Dec 17, 2014 | 2009 Pontiac Vibe
Mi car turn off suddenly
Turn the key on(don't try to start) let it set for ten minutes, Turn it off for thirty seconds. Then try to start. Security is set.
Mar 19, 2014 | 2000 Pontiac Sunfire
Changed a bad battery in my 2005z71. with new battery in @ start up the AC only blows hot air. was working just before battery change. Fuse check out fine. What do I need to look for?
Start the truck,and turn ac on,cold setting and all,let it run for 20 seconds,and turn ac off,then wait 5 seconds turn truck off,,wait 5 seconds,and then start truck,wait about 5 seconds,and turn ac on,see if this helps.
Jul 20, 2010 | 2005 Chevrolet Silverado
1999 hard starting expedition, with 5.4 engine
fuel pump may be going. try this. turn key on, listen for fuel pump to run for 5 seconds. Turn key off, wait 15 seconds or until you hear relay click inside car. Turn key on again for 5 seconds and ff for 15 seconds. repeat once more. This will pressurize fuel system to 40 psi so injectors have full pressure. If it starts quickly now, you are getting bleed down through the check valve in the fuel pump or the fuel pressure regulator on the fuel rail.
Jun 30, 2009 | 1999 Ford Expedition
1993 ford ranger difficult to start
This double crank you say works in a couple of seconds? Try this; Turn the key on and wait a couple of seconds before cranking. It may be it takes a couple of seconds for the rail pressure to build up. The fuel pump shouldn't have to refill the fuel system but pressure recovery could be hindered by the fuel filter no passing fuelfreely enough.. Age of fuel filter?
Apr 11, 2009 | 1993 Ford Ranger SuperCab
Problems when starts..
Turn your key on for 10 seconds but do not start the engine. That will give the fuel pump time to built pressure. After the 10 seconds try starting the engine. If it starts right away you may have a weak pump or dirty filter.
Oct 02, 2008 | 1999 Chevrolet Cavalier
When pc start the processor then turning vey fast for 3-8 second the pc turn off by itself
How you know the processor started state clearly are you talking about the processor fan starts running????
Jul 24, 2008 | EliteGroup 661FX-M7 (661FXM7V11)...
Image 17.0R Treadmill Front Roller Logo
Top Image Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Image Exercise and Fitnes Expert? Answer questions, earn points and help others
