Question about Kicker ZX400.1 Car Audio Amplifier
I have a zx 400.1 kicker amp that goes into protection.
I tested the mosfets by testing the resistance and determined 2 were not corresponding to the other 4 so i removed the 2 and when tested the amp powered on and played but sounded a little distorted but that could also be my test speaker.the amp went into to protection if turned up the bass up too much.It could however handle full gain with no bass. when i replaced the 2 mosfets the amp went back into protection again. remove them and it comes on again. Does anyone know what i should test next or where i might find a schematic for this amp. thanks for any help
GARYDALE
  • 15 Answers
SOURCE: Kicker DX350
it sounds like you pop the power Reg. transistor or one of the Amp. chips instide. Some Amps has a pic fuse inside on the main board its green very small shape like a tear drop with a wire comeing out both ends it would in a socket some times white or black.
Posted on Sep 22, 2006
SOURCE: Kicker ZX 750.1
I figured it out!!! Thank yopu for responding though. I had a weak graound signal:)
Posted on Apr 21, 2008
  • 631 Answers
SOURCE: Kicker KX800.4 Protection light problem
If the voltage is sufficient on the B+ and remote terminals and the amp goes into protect with no speaker wires or RCAs connected to the amp, it probably has shorted output transistors.
Let me know if you have any other questions.
Posted on Oct 15, 2008
fixerdlt1
  • 18 Answers
SOURCE: kicker zx 1000.1 green light flickers and no sound
The first thing I would suggest is to check all connections to the amp and speakers, especially the ground. A loose ground can cause the problem listed. You can test this by temporarly running a ground from the amp to the battery neg. . If the amp fires up ok then that means your grounding point for the amp should be checked and cleaned and reattached firmly. If you have a meter(multitester) set it to ohms and check the impedances of the voice coils in the woofers. If one is cooked it may be shorted and tripping the amps protection. Always hook thing up with the sys off and then turn on and test.
Posted on Jul 22, 2009
SOURCE: cut out
check your ground always bring your ground to the battery
Posted on Feb 18, 2010
ZX 1000.1 amp stays in protection mode
It is normal for them to go into the protect mode, If the speakers are not hooked up to it,
Nov 09, 2012 | Kicker Car Audio & Video
I have phase linear uv8, need to know how to get subs 2 work! Amp goes into protect mode when rca's r plugged in, there r 3 sets of preamp out puts 1 front left and front right, 2nd is rear left rear...
try testing the amp without speakers plugged in. Run the sub preamp out to the amp that you will drive the subs with, but don't wire up the subs yet. Test for protect mode kicking in.
Yes - unplug the rca ins from the amp. retest.
No - Problem lies within the sub wiring. What is the load on the amp (measure with an ohm meter)? If it is below 4ohms, chances are the amp can't dip that low. Give it more resistance by wiring it differently (series vs. parallel)
Bruce
May 05, 2011 | Kicker Car Audio & Video
MY KICKER ZX 750.1channel amp "FLIP FLOPS" from protected mode(red light) to normal (green light) every 2 seconds.
Are you getting any sound output at all from amplifier?
Is there a popping or banging coming from speaker?
It could possibly be a faulty output mosfet that is ocillating cause DC to leak onto the speaker output causing it to flip into protect.
please advise
thanks,ben
Sep 27, 2010 | Kicker (ZX750.1) Car Audio Amplifier
Irf z44n resistence i want to see if this is its original peace?
THERE IS NO WAY TO MEASURE THE RESISTANCE OF A MOSFET OTHER THAN DETERMINING IF IT IS SHORTED, WHICH WILL BE INDICATED BY A CLOSE TO ZERO OHMS MEASUREMENT ACROSS ANY TWO OF THE THREE LEADS. I DO HAVE A METHOD OF TESTING MOSFETS, BUT IT GOES BEYOND THE SCOPE OF THIS FORUM AND REQUIRES AN EXPENSIVE HIGH IMPEDANCE MULTIMETER TO DO SO. YOUR IRFZ44N SHOULD BE MANUFACTURED BY INTERNATIONAL RECTIFIER AND THE EXACT REPLACEMENT SHOULD BE OF THE SAME MANUFACTURER. THESE MOSFETS ARE PROBABLE IN THE POWER SUPPLY OF YOUR AMPLIFIER, AS THEY ARE RARELY USED IN THE OUTPUT SECTION. IF YOU FIND THAT ONE IS SHORTED, THEN THEY ARE PROBABLY ALL SHORTED WITHIN THAT BANK. THE OTHER BANK ALSO MAY OR MAY NOT BE SHORTED......V
Dec 30, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Need help please...
If you unplugged the fuses, the amp won't come on at all. I'd say its a blown transistor, you can test this by opening up the amp and using a multimeter to check resistance on the transistors.
Aug 03, 2009 | Volfenhag ZX-8400 Car Audio Amplifier
Kicker zx 1000.1 green light flickers and no sound
Jul 21, 2009 | Kicker ZX10001 Car Audio Amplifier
Kicker protection light won't shut off
Hello newwithtech,
There are 4 possible causes for the amp to go into protection mode. Kicker calls it SORT for Short, Overvoltage, Reverse polarity, and Thermal. If the amp has been in and working properly, it's probably not reverse polarity. And if it goes immediately into protection when power is connected, I'd rule out thermal. So it's probably either a short or overvoltage.
1) Start by removing the speaker wires and see if the amp powers up properly. If it does, one or more of the speakers is shorted or grounded.
2) Test each pair of wires with a multimeter set to the lowest resistance (ohms) scale. Measure across each pair and from each individual wire to ground. Across each pair, the meter should read about 3-4 ohms. From each individual wire to ground, it should read infinity. If the meter reads "0" ohms (shorted) in any test, you have located the problem.
3) If the speaker wires test OK, set the meter to read DC volts and measure the voltage at the amp positive terminal. If the voltage is higher than 16V or lower than 9V, you've located the problem.
4) If the voltage is OK, remove the RCA inputs and test for proper power up. If it powers up without going into protection, you have a shorted/grounded input. Replace them one at a time to determine which one(s) is/are defective and replace the cable.
If these tests show all the wiring is good and the voltage is OK, the amp is probably shorted internally (most likely an output MOSFET), and requires service at the component level. You need to take it to your local audio shop or send it to Kicker for repair.
Hope this helps.
Jun 29, 2009 | Kicker KX300.4 Car Audio Amplifier
SHOULD I GO AHEAD AND BUY A 400 WATT AMP?
All amps aren't created equal. More exspense amps put out "cleaner" power. You need to know what the RMS power rating is for the amp at 8 ohms and 4 ohms. Also, is the speaker an 8 or 4 ohm speaker? How you wire a speaker or speakers (series or paralell) can change the ohms (resistence) which will change the power put out of the amp. Also, I'm assuming you are setting it up in mono?
Jun 22, 2009 | Pyle 2 Channel 4000 Watt High Power MOSFET...
Amp cuts out but not in to protection
definately wireing wrong some amps dont like the 1.33 are you testing your wiring jobs with a volt meter! just set it to the resistance/ohms and verify that you are actually getting 1.33 or the ohms you want!
Feb 19, 2009 | Kicker KX1200.1 Car Audio Amplifier
Oct 15, 2008 | Kicker KX1200.1 Car Audio Amplifier
Car Audio & Video Logo
81 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
