Question about Moffat E32 Full Size Electric Convection Oven 208V
Oven door glass outer shattered
My conventional oven fell and both glass got broken the inner and the outer, I would like to have the full door if possible Thanks
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
The outer glass of my oven door shattered, can I still use it until it is repaired?
Hello- I would be careful using the oven mostly because the inner glass will be VERY hot to the touch, meaning you will get burned if you touch it. If you have children I would refrain from using the oven, too risky. If it is just you, or just adults then you should be ok to use it until you can repair it. Keep in mind that you will probably lose a lot of heat out the door and it make take longer to bake. Again, be wary of the inner door glass if you use the oven. Do a test run with a low heat and see how it performs. Hope this helps, best regards.
Sep 27, 2010 | Whirlpool Ovens
The main oven inner glass door panel has shattered
Unfortunatey, it happens quite frequently, there is no one reason for it to do so.
The only solution is to replace it.
Over a number of years use, the glass looses it's properties, and this is what can happen.
Jan 24, 2010 | Zanussi Ovens
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
GLASS BROKEN ON MY FRIGIDAIRE PRO
Inner or outer? you will have to take the door off, done by lowering door to full open postion and youll see a fold down flap at hinge, fold down and close door and lift. this will allow you to access screws easier. remove handle and four bottom screws. that will allow you to take off outer glass....there will be screws on inside to take out inner glass.
Jun 08, 2009 | Frigidaire FGB24S5A Gas Single Oven
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
Moffat E32 Full Size Electric Convection Oven 208V Logo
15 people viewed this question
Top Moffat Ovens Experts
Bee4Mee
Level 1 Expert
Lawrence Oravetz
Are you a Moffat Oven Expert? Answer questions, earn points and help others
