Question about Streamlight Charge Cord Dc Charge Cord, Cigarette
Sl-20x car charger specifications - Streamlight Charge Cord Dc Charge Cord, Cigarette
Battery
recharge it when leaving cables on and charger unplugged it will draw the battery down and with the clock radio always on will ad to the draw.
Oct 03, 2012 | 1997 Saturn SL
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
BACK TO TOP
Specifications:
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
Zaurus SL-C860 Handheld: what type of charger can i use...
Use a 5V switched-mode adaptor with a miniature co-ax plug with centre-positive polarity. I use an adaptor from a Sony PSP (PSP-1000) with my SL-C860, and it works fine.
May 17, 2010 | Sharp Zaurus SL-C860 Handheld
Specific location of fuse for cigarette lighter on a 1996 Saturn SL
The pencil points to the specific cigarette lighter fuse (20 amp) located in the interior of 1996 Saturn on passenger side "kick panel."
Mar 31, 2010 | 1996 Saturn SL
I have a HP model dvd1040i-H16 Super Muti DVD Writer Man.Date april 2007.I'm trying to install in a Dell GX 260 is this player a IDIE Cable or Sata?I don't think Dell supports Sata is there some way to...
Should be IDE cable...IDE interface according to the specs. You computer has IDE connections so the drive should work.
Product Specification Model HP DVD1040i Lightscribe 20X DVD Burner/Black/Retail Manufacturer HP Mfr Part # DVD1040i Buffer 2MB Interface IDE
Include
  • Internal DVD ±R/±RW drive with DVD±R up to 20X, double-layer recording, DVD-RAM, and LightScribe direct disc labeling
  • Software CD including electronic user's guide
  • Quick-Start placemat
  • Getting Help guide
  • Installation screws
  • Nero 7 Essentials
Data Transfer Rate (Read)
  • DVD-ROM up to 16X (CAV)
  • CD-ROM up to 48x (CAV)
  • Data Transfer Rate (Write)
  • DVD+R up to 20X (CAV)
  • DVD+RW up to 8X (ZCLV)
  • DVD-R up to 20X (CAV)
  • DVD-RW up to 6X (ZCLV)
  • DVD+R Double Layer up to 8X (ZCLV)
  • DVD-R Dual Layer up to 8X (CLV)
  • DVD-RAM up to 12X (PCAV)
  • CD-R up to 48x (CAV)
  • CD-RW up to 32x (ZCAV)
  • Access time
  • DVD 160 ms
  • CD 160 ms (typical)
  • Supported Disc
  • CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
  • CD Text, CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM
  • OS requirement
  • Windows 2000 Professional SP4
  • Windows XP Home edition
  • Windows XP Professional
  • Warranty 1 Year Weight 3.3 lbs
    Jan 12, 2010 | HP DVD1040i 20x Super Multiformat Dvd...
    Power cord for Techniques SL-PD9 CD Player
    Fairly common cable - I have several for various chargers for cameras, camcorders and laptops. You can get them at Radio Shack
    Feb 01, 2009 | Technics SL-PD9 5-Disc CD Changer
    Advent camera battery charger
    Here's a list of cameras that use the same battery.
    ADVENT:
    ADV1172E
    BENQ: BENQ:
    DC C500, DC E43, DC E53, DC E63+, DC E720 DC C500, DC E43, E53 DC, DC E63 +, DC E720
    KONICA MINOLTA: KONICA MINOLTA:
    DiMAGE E40, DiMAGE E50 DiMAGE E40, E50 DiMAGE
    PREMIER: PREMIER:
    DS-4331, DS-4346, DS-5330, DS-5341, DS-6330, SL-6, SL-63 DS-4331, the DS-4346, the DS-5330, the DS-5341, the DS-6330, SL-6, SL-63
    ROLLEI: ROLLEI:
    Prego DP4200, Prego DP5200, Prego DP6200 Prego DP4200, Prego DP5200, Prego DP6200
    Hopefully this will broaden your options when searching for a compatable charger.
    Mar 23, 2008 | Cameras
    Streamlight Charge Cord Dc Charge Cord, Cigarette  Logo
    23 people viewed this question
    Top Streamlight Camping, Backpacking & Hiking Experts
    Stan Ford
    Tom Chichester
    Are you a Streamlight Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
