Question about Liebherr KTS 1534 Comfort Compact Refrigerator
Which light bulb fits a liebherr comfort fridge?
3 Suggested Answers
SOURCE: How to find part number of Liebherr fridge freezer
Normally if you remove the LHS salad drawer in the fridge you will see a sticker on the wall of the unit with the relevant information.
Hope this helps.
Posted on Jun 08, 2010
  • 4793 Answers
SOURCE: Disgusting smell from my Liebherr fridge
use a syringe to blow clorine bleach down the drain hole.(the clorine will gas off and leave no smell after about an hour)
Posted on Jul 23, 2010
Liebherr bulb switch
Generally at the top on the door inside the fridge there will be a little door switch as we call it. When pushed in it should open the contacts in the switch and kill the power to the bulb. If the bulb is not turning off when the switch is pressed then I would presume the contacts have been fused shut and if you would like the light to turn off you may want to replace the switch, or pull out the light bulb andhave no light. Good luck
Sep 08, 2012 | Refrigerators
Hope this helps.
Jun 08, 2010 | Liebherr Refrigerators
Our liebherr freezer door seal has broken, should this cause the fridge to warm up.....5 upto 17 degrees?
All sorts of things can go wrong. Warm air will be sucked in and typically there will be water dripping from the cieling. The compressor will also continue to run .Will almost certainly get an ice build up on evep. plate. Suggest replacement as soon as possible.
Sep 16, 2009 | Liebherr KTS 1534 Comfort Compact...
Liebherr fridge parts? The plastic on the glass shelf has cracked and I need to replace the shelf but I don't know where I can do this... I'm also not sure what model the Liebherr fridge is either...
There should be a tag with model # on it somewhere on unit. Usually in inside side wall of fridge section. Or maybe on back of unit. Definitely need model # to order part.
Sep 08, 2017 | Refrigerators
Fridge
i think all that is wrong is that the drain is blocked - you didn't say if you have cooling.
to clear drain, push something flexible into the drain hole to clear the blockage. follow up with a small jug of water to check water flows away freely
Jun 21, 2008 | Liebherr KTS 1534 Comfort Compact...
Fridge and frezeer not working
Liebherr embraco compressor....compressor fluid leaked while moving, what is the fluid? is it easy to replace?
Dec 06, 2007 | Liebherr KTS 1534 Comfort Compact...
Liebherr KTS 1534 Comfort Compact Refrigerator Logo
43 people viewed this question
Top Liebherr Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Liebherr Refrigerator Expert? Answer questions, earn points and help others
