Question about Audiovox Jensen In-Dash DVD/CD Receiver w/ 7 LCD Screen" Car Video Player
Ribbon loose The screen comes on for a second then goes completely black, the parking break wire isn't connected but I have solid black screen after it first powers up. The screen stays on long enough to see the Jensen logo then black. Should I at least see a blue screen??
2 Suggested Answers
  • 57 Answers
SOURCE: PARKING BRAKE DISABLE
yes its saying in toorder to play dvd's u must engage parking brake which means the wire is suppose to be hooked up to the parking brake....BUT i know the trick to make it work where u can play dvd's and drive
Posted on May 31, 2009
I need to know how the sreen wirering goes in a toshiba c655d-s5300
Usually located around the hinges.Be careful... Try removing the hinge clips there is a ribbon cable ...these can break easily.but check that the connection into the main board has not dislodged before inspecting the screen area.the screen housing clips together at the bevel edges.be aware that faults can just be failed backlight,,,,inventor,,,,loose connections ,,,,broken ribbon,,,,dead or cracked lcd.
Feb 19, 2015 | Toshiba Computers & Internet
HP screen goes black 5 seconds after ac adapter is plugged in or out
This may not be the ac adapter itself. the metal prongs on the side of your HP Laptop to connect to the wire of your ac adapter may be bent or shortciruited. try to get a replacement which may be hard depending on what type of HP Laptop you own. or you may just have to send it back if you dont know how, in order to avoid breaking the warranty policy by mistakenly damaging it.
Apr 18, 2013 | Computers & Internet
No video. audio comes through crystal clear. model #vs6140
A very common problem in older Mitsubishi sets is bad solder connections develop.
If bumping or jarring brings back picture you are going to have to get the entire chassis loose----it involves getting the chassis unbolted from cabinet, releasing some bundled wires and lifting chassis up so bottom is facing rear of set.
Then you take a good look in power supply and other areas for any "ringed" connections: connections that are cracked loose and not soldered solidly.
The hard part is getting the chassis loose; usually in this case I find four or more loose, or poor connections.
What happens is from age the board expands and contracts and some parts that produce more heat crack/break loose solder connections.
Let me know if you have questions.
Steve
Feb 29, 2012 | Mitsubishi VS-6041 60" Rear Projection...
I connect my alpine cva 1003 to valor dv-169T dvd player. sounds come out but the screen is not getting connected to dvd player. i connect red, white and yellow wires.
if evrything is ok with the dvd (make sure the dvd is working fine), you need to hook up the yellow/ blue wires and yellow / black wires one for parking breack and the other for the breack chek the diagram on top of the alpine radio .
Jun 15, 2010 | Alpine CVA-1003 Car Video Player
Dualphone 3088 is completely black. \r\nchanged
The Dualphone 3088 LCD screen has a terrible habit of coming loose from the ribbon connector socket on the main board. If you take the phone apart, carefully remove the LCD screen from the plastic surround it is in and you will see the ribbon and its board connector. The small clipson either side of the connector have a habit of coming loose, freeing the LCD screen. Carefully put the ribbon cable from the LCD screen back into the connector, you will need to press both clips on the connector at the same time to lock it in place. (yes its fiddly and I have to do it all the damn time)
Jun 14, 2010 | RTX DUALphone 3088
I recieved a ds lite with water damage and the four odd wires on my ds lite motherboard all come off does any one have a diagram of where the wires might go thanks please help
from the tom screen there should only be 2 wires 1 black and 1 white. The white wire is the mic that plugs straight onto the board, and the black wire which plugs onto the wirless insert which attaches onto the board. the other 2 wires could be loose speaker wires if there is another black and a red wire, other than that could you explain a bit further what the wires actually look like.
Jan 16, 2010 | Nintendo DS Lite Console
Have LG 42 inch plasma, 1 inch black line down center of screen, picture good other than black line blocking center of screen, comes and goes sometimes
Sounds like the middle scalar board is defective. Since the issue comes and goes it could just be a loose connection to the between the scalar board and the PDP Module (plasma panel).
Great caution needs to be taken when checking this connection because it is a ribbon cable connection it and needs to be put in correctly aligned or it could cause a short in one of the circuit boards.
Oct 07, 2009 | LG 42LC2D 42 in. LCD HDTV
Lexmark x8350
In the back of the printer is an access panel with one screw to hold it in place.
The outer side edges are held in place with it plastic tabs (which you can not see due to they are inside the printer. So carefully remove this panel without breaking the tabs. Look inside and you will see a ribbon connecting to a circuit board. This is probably loose or disconnected. The end of the ribbon is hard and not flexible. Push the end of this ribbon in the white plastic standoff slot. This ribbon sometimes comes loose when the top scanner cover is partially remove from the printer. I said, partially because if you needed to remove the top scanner completely, then this ribbon would need to be completely disconnected. You can also see, when the access panel is off, other wire connections connected to this circuit panel. Sometimes they also come loose or disconnect when the top scanner is partially remove. Connect them if they are loose or disconnected. I believe to solve your problem is the ribbon disconnected. Best wishes in solving your problem.
Sep 28, 2008 | Lexmark X8350 All-In-One InkJet Printer
Usb problems, DVD Issues,and Radio volume problems.
connect the breaking wire(brown) for model VRVD630 to a ground (i just connect it with the black) meaning ground wire black and breaking wire brown will run too the same ground wire which will show up your dvd screen and it wont b blank
Jun 10, 2008 | Virtual Reality Sound VR3 CD Player w/ USB...
Brake wire for Jensen VM9311ts
You first have to figure out which one of these wires goes to ground potential when the brake is engaged. Get a digital multimeter set it to read resistance (turn the dial to the omega symbol)and then connect one end to ground of the car try the outer ring of the 12 cigarette lighter and the other using the tip to pierce the insulation of one of the wires, then press the parking brake. The meter with the brake not pressed should have ---- when the break is pressed the meter should read 0000 or some value less then 1.000 ohm. The wire that goes to ground when the brake is pressed is the parking break wire and attach your DVD player brake wire to that. My money is on the solid green wire.
Sep 21, 2007 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Audiovox Jensen In-Dash DVD/CD Receiver w/ 7 LCD Screen" Car Video Player Logo
11 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
