Question about Primos Truth Cam Blackout Trail Camera
Put card in and it reads SOFUL
When I went to switch cards the new card reads SOFUL on the camera
Camera cannot read cf card
It is possible that the card capacity is too great for the camera - does the manual give a maximum storage size ? If not, contact the manufacturer who should be able to help you.
May 08, 2016 | Konica Minolta Maxxum 7D / Dynax 7D...
Camera says new sd card is full
put it in a computer and see what it reads,it might need formatting .
Jan 25, 2018 | Kodak EasyShare C330 Digital Camera
SAYS SOFUL ON DISPLAY,WILL TAKE PICTURE BUT NOT SAVE IT TO THE CARD
i have the same problem with my prrimos truthcam. one SD card works fine and one says "SOFUL" and will not take anymore pics. There is a weird .if file on the card. not sure where it came from. but my other card works. I may try to reformat the card somehow, but the other option is just get another $10 card
Nov 17, 2011 | AT&T ATT Primos Truth Cam 35
New Jazz DV150. Installed new batteries (tested) and SD card (tried switch in both locations). Powers on, says "Read card....", "Goodbye", powers off.
HI, I just got off the phone with a very nice man in NJ at Digitac. He walked me through a few fixes: Try a different SD card, clear SD card, put SD card in and then start camera, start camera and then put SD card in. None worked, so he said something is wrong with the camera computer and I will have to send the camera in for warranty work.
Feb 28, 2011 | Jazz DV150 Camcorder
Message says can't read card, even when I put a new card in. How do I fix it?
Your camera is programed for SD memory cards from 8MB through to 2gig if you have put a SD card in the camera larger then 2gig it can't read it. If you are under the 2gig maximum then it's possible the SD card is in the lock position. At the top left corner there is a little white slider type switch make sure this switch is pushed forward to the top of the card in the direction of the gold contacts. Also a new card will need to be formatted for the camera to read the card properly. See page 11 screen shot I have provided for correct card installation.
Also page 12 for the formatting of the memory card.
Hope this is a help Robert in Canada
Dec 27, 2010 | HP Photosmart R827 Digital Camera
I took my CF card out to get photos, went to put it back in and the screen read "There is a problem with CF card. Replace the CF card." I didn't think there was a problem with the card. But I replaced...
Your CF pins in the camera are most likely bent/broken. This is a very common problem. Most repair shops will charge $150-$200 to repair this.
Hope this helps.
Wes
Sep 10, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Bought a new memory card for easyshare c330. Put
Something wrong with the card reader pins.
Either bent, dirty or cold solder.
Apr 15, 2009 | Cameras
Card locked on my optio w10
Check your manual for the image protect function. or simply reformat in camera.
Jun 14, 2007 | Pentax Optio W10 Digital Camera
Primos Truth Cam Blackout Trail Camera Logo
Top Primos Cameras Experts
Are you a Primos Camera Expert? Answer questions, earn points and help others
