Question about Frigidaire Ovens
Frigidare gas oven wont ignite - Frigidaire Ovens
  • Frigidaire Master
  • 5,323 Answers
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Posted on Apr 17, 2015
5 Suggested Answers
  • 38 Answers
SOURCE: ignition wont stop while oven is working
Egnition is a push button to a spark generator, If this is electric, the obvious answer would be turn off the electric. This should not affect the gas unless if is temp controled by electric. Usually the temp is set gy a gas regularor controlled with a knob and set before gas is ignited.
Posted on Feb 11, 2009
heatman101
  • 43501 Answers
SOURCE: have to replace oven ignitor on a free standing
No you do not need to shut off the gas, but you do need to unplug the unit from the wall...to prevent a shock.
Heatman101
Posted on Mar 10, 2010
heatman101
  • 43501 Answers
SOURCE: Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Dec 27, 2010
  • 517 Answers
SOURCE: I have a frigidare gas
Good day!!!
Your pilot light might have gone out. If this is the case then you have to re-light it. If the pilot light won't stay lit, then you might have to adjust the thermocouple or move the pilot light closer to the burner.
I hope this information will be helpful..
Thanks for using fixya..Have a nice day!!
Posted on Aug 27, 2011
Propane oven will not get up to tempature
change the igniter
had the same problem I was told the oven cools off
because igniter isnt allowing gas to flow
it will lite but temp isnt there
Sep 16, 2012 | Frigidare FGB24S5DC Gas Single Oven
I have a frigidare brand self cleaning gas range and the oven will not light
If the rest of the unit work properly, then you are having an electronic ignition issue. Contact your manufacturer and then a professional they suggest to have it repaired.
Sep 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
Aug 26, 2012 | Frigidare FGB24S5DC Gas Single Oven
My oven is not lighting like it is getting no gas. the coil glows and even if i light a match and put it under the oven it will not light
your igniter is weak
if you turn on gas to light and it takes awhile , or not at all, weak igniter in most cases
Jan 31, 2011 | Frigidare FGB24S5DC Gas Single Oven
My broiler works on my frigidare oven but the stove will not light
heatman101
Dec 26, 2010 | Frigidaire FGB24S5A Gas Single Oven
The ignition coil on my oven glows fine, seems like there is no gas. Won't light.
it may glow but it s weak the gas wont flow
seems like alot of these going bad
I had 3 last week in my rentals
Nov 21, 2009 | Frigidare FGB24S5DC Gas Single Oven
Electronic ignition works, but the gas does not come on
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, either repeat the procedure or call a qualified appliance repair technician.
Jun 26, 2009 | Frigidare FGB24S5DC Gas Single Oven
I have Fridgidaire 30'' wall oven. Tried to bake something but only the broiler will ignite. NOT the oven! AHHHH...I want to cook my meatloaf. Help?
your model says its a 24"
but the hot surface igniter for oven is bad
it should have a seperate one for broiler
check here on fix ya ( hot surface igniter)
Mar 09, 2009 | Frigidare FGB24S5DC Gas Single Oven
Oven model FGF316ASA OVEN WILL NOT IGNITE
change the igniter its just weak
cost around $65 for universal fit
takes 15min to change
Nov 17, 2008 | Frigidare FGB24S5DC Gas Single Oven
Ovens Logo
98 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
