Question about Optics
I need a crosman 38t parts
I need part numbers 30(ball bearing chamber spring),parts 47, 46, 45, which is sub group 58, and part number 52, which is a part of subgroup 68 according to the assembly drawing. where can I find these items please
SOURCE: Crosman 140 Piston rod replacement parts needed.
I just rebuilt my 140 that I had as a child, Rick had all of the o-rings and pump cup to rebuild it back to new working condition.
Rick Willnecker
Precision Pellet
37 Stoney Lane
New Park, PA 17352
717-382-1481
717-382-4065 Fax
e-mail airgunshop@aol.com
web site www.airgunshop.net
Posted on Mar 02, 2009
SOURCE: Parts for Crosman air rifle 1077
when the gun is pumped the air is not contained sounds like it is going right up the barrel
Posted on Apr 20, 2009
  • 33 Answers
SOURCE: need a assembly drawing of a Ariens deck-model
Your model number may be incomplete.  Go to www.outdoordistributors.com, click on "A" and then Ariens.  It'll ask for a model number.  It shows several snow blowers and several riding mowers.  You can then download a parts list.
Posted on Aug 31, 2009
  • 33 Answers
SOURCE: I own a cub cadet lawn tractor model Lxt1040. I
It appears to come with the chute assembly part # 631 04254
Posted on Sep 10, 2009
Testimonial: "thanks so I guess I either find another spring or buy the whole assembly($25.00).At least now I have a plan"
SOURCE: I need a parts diagram for a 788 crosman bb gun
http://www.crosman.com/pdf/manuals/crosman/788/C788-EVP2&3.pdf
Posted on Oct 08, 2009
How to fix a Remington Pallet Rifel model number RW1K77X .177 caliber spring. It seems like the spring snapped in half and doesn't have strong firing power. And knowledge on how to fix or if anyone knows...
Go here. You should be able to find everything you need and if you don't you can call them
http://www.crosman.com/cs/manuals/remington
Jun 10, 2014 | Garden
Crosman 38t parts
http://www.crosman.com/cs/manuals/crosman-pistols
Jan 22, 2014 | Optics
Cratftsman Lawnmower; 16.5 horse; 42 inch deck, need assistance replacing armbrake and tension spring #58 on sears schematic; MOwer model number is 917271120-- particularly, where does this spring attach?...
Judging by the diagram the spring mounts under the armbrake, the Bolt (#52) goes through the circular spring. One end of the spring goes into one of the holes near the bolt on the armbrake and the other ( after providing tension by turning the spring ) must attach to a non moving part on the deck to be able to provide the required tension Look for a small turned up piece of metal with a notch in it on the housing.
Hope this helps
May 18, 2011 | Garden
My Original Crosman 3357 , has the obvious weak latch from the barrel to the gun. I need to know how to fix this without string..
Hi there, I just fixed the same problem with mine! The latch spring as actually a small piece of rubber that with time and use hardens and fails to keep the latch in position... I used a rubber foot from an old PC and cut it to the same size and inserted this in place of the old bit. To fit this part, 1st remove the screw that the frame hinges on then the cylinder handle cover. Remove the two flat blade screws and carefully ease the side of the gun open. The rubber spring is located just under the latch and above the steel chamber - Works a treat! Cheers RichT.
Aug 17, 2010 | Crosman (4032)
I have a crosman 38t that I haven't used in awhile when I put they co2 cartridge in it leakses all out within seconds, what can I do???
It is likely some seals need to be replaced. I have had my 38 T for MANY years and have had the same problem. Seal kits are available, but not from Crosman. GOOGLE "Crosman 38 T seal kits" and you should be able to find where to order from. The cost is around$20+ for a complete set.
Btw, the reply from Norsky812 is waaay off the mark about the BB's. You clearly stated you have a Crosman 38 T, this gun shoots PELLETS.
Nov 14, 2009 | Crosman (4032)
Question no. 2 For the 50 observation given below. Prepare Frequency Distribution for the the class interval is 10 (lower limit starting is 0) and upper limit is 80. Also plot in graphing. 64 62 52 50 70...
64 62 52 50 70 60 55 20 25 48 35 55 55 47 64 42 36 50 30 53 51 63 58 50 60 54 33 48 40 76 61 46 65 65 15 45 58 40 64 18 33 40 64 18 33 40 48 9 38 41
Highest value observed: 76
Lowest Value: 9
Standard deviation from the ungrouped data: 15.25
Frequency:
Mean: 46.94
Standard deviation from grouped data: 15.40
Oct 23, 2009 | Microsoft Excel for PC
Diagram of front end for '94 F150 Ford
this is a 96 f150 suspension, 4x2, not 4x4.
Item Part Number Description 1 N806246-S56 Nut and Washer 2 5A333 Retainer 3 18124 Front Shock Absorber 4 40949 Bolt 5 N62048 Nut 6 N806496 Nut 7 18126 Lower Shock Bracket 8 805033 Bolt 9 3B404 Caster and Camber Adjuster 10 800937 Nut 11 5414 Front Spring Insulator 12 3105 Front Wheel Spindle (RH) 13 3106 Front Wheel Spindle (LH) 14 3050 Front Suspension Lower Arm Ball Joint 15 3B008 Steering Arm and Drag Link 16 800895 Nut 17 642569 Cotter Pin 18 383489 Nut 19 3006 Front Axle 20 388727 Bolt (F-150) 21 389574 Bolt (F-250, F-350) 22 606085 Bolt 23 605920 Bolt 24 3405 Radius Arm 25 34992 Nut 26 5A307 Lower Spring Seat 27 5414 Front Spring Insulator 28 18183 Front Shock Absorber Mounting Bracket 29 34992 Nut 30 5310 Front Coil Spring 31 5B315 Upper Spring Seat 32 18198 Insulator A — Tighten to 34-48 Nm
(25-35 Lb-Ft) B — Tighten to 18-23 Nm
(13-18 Lb-Ft) C — Tighten to 32-58 Nm
(23-42 Lb-Ft) D — Tighten to 60-80 Nm
(44-59 Lb-Ft) E — Tighten to 68-92 Nm
(50-67 Lb-Ft) F — Tighten to 112-152 Nm (83-112 Lb-Ft) G — Tighten to 112-152 Nm (83-112 Lb-Ft) H — Tighten to 340-460 Nm (250-339 Lb-Ft)
Jan 29, 2009 | 1994 Ford F150 Styleside Supercab
Optics Logo
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
