Question about Emerson EWC1304 13 in. TV/VCR Combo
Channels not working
I just want to use the VHS feature and hook up a game console and DVD player. No antenna or cable
  • 3 Answers
Have to use in put connection the red white yellow some only have yellow and white red not used these connection on back of tv called line in or video in red is audio so is white some time the connection in on the front must set the tv to line one or 3 depends on set should be a in put button on set if not on remote or try to cannnel up to find input
Posted on Apr 28, 2014
Cant retune through dvd player
Sounds like a few things going on here... Your indoor antenna for one is probably not making it easy for you as an outdoor antenna will work a whole lot better. This is why it open picks up half the channels and they are pixelating. Also you may have faulty rf leads. Replace these.
Feb 25, 2014 | LG Televison & Video
Want to record a television program on a channel higher than 16.
there must be a setup feature on the sony for channels that you get in your area?
Dec 18, 2009 | Sony SLV-D370P DVD Player/VCR
Can't see dvd on TV
how to hook up to watch dvds
May 25, 2009 | Sansui VRDVD4005 DVD Player/VCR
I am not getting the channels on my unit to record anything.
This unit, like most these days, does not have a TV tuner built in. If you want to record, you need to provide the video and audio from another source, such as a cable box or satellite receiver. You can't just connect an antenna and tune a channel to record. You haven't missed anything; the capability just isn't there.
Jan 24, 2009 | Zenith XBR716
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Need instruction to hook up dvd player
You will need a TV or monitor with audio/visual inputs. The better ones have what is known as an S/VHS input, which separates the TV picture signal for better color reproduction. You will need to be able to switch your TV, usually by the channel selector, to the proper input for audio visual signals. Sometimes this is known as Video 1, Video 2, A/V etc. These are usually below Channel 2. Maybe your remote has that option. You will need an a/v cable. This is a three-connector cable with RCA plugs on each end. Connect the DVD player to the TV as follows: 1. Yellow cable, from video OUT on the DVD player, to video IN on the TV. Video is ALWAYS yellow. 2. Red and white cables from audio OUT on the DVD player to audio IN on the TV. 3. If you have S/VHS capability, buy an S/VHS patch cable which will have the three plugs mentioned, plus a round 4-pin plug. Select S/VHS OUT on the DVD player, and S/VHS IN on the TV. When using S/VHS, ignore the yellow connector. It is for composite video and not needed. Here's a hint: Your YV audio/visual inputs will usually be on the back of the set. Some better units have a/v inputs in front. What if my TV doesn't have a/v inputs? If your DVD player as an RF output, connect an RF "f" cable from that output to the antenna in cable on your TV. Otherwise buy an RF converter (about $20 or so at Radio Shack). Connect your a/v cable (yellow, red and white) from the DVD player to toe converter, then connect an RF cable (like the kind your cable box is connected with) to the antenna input on your TV. This signal usually comes in on Channel 3. Let me know if your problem is more complicated, It seems like a lot of wires and connections, but it is really straightforward, Remember, yellow is ALWAYS video. The two audio cables can be connected without worrying about color.
Dec 13, 2008 | Televison & Video
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Hooking up a cd player
I'm assuming you mean a DVD player, not a CD player? 1. You can get an input splitter (basically an A/B switch for the cable), and connect to that, manually switching between the two sources. 2. You can replace the VCR and the DVD player with a combination DVD/VHS unit. Although it would seem logical, it is unlikely that you can hook the DVD player to the VCR, since the VCR will refuse to let the signal pass though it, as part of its MacroVision copy protection. (This is the same sytem that prevents you from recording DVDs onto VHS tapes.)
Feb 18, 2007 | Zenith B25A74R 25" TV
Emerson EWC1304 13 in. TV/VCR Combo Logo
60 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
