Question about Jet 2007 GMC Sierra - New body style, Denali, 6.2L V8 - Performance Module
Headlights don't work on my 07 denali
High beams fog lights and running lights all work
07 Chrysler 200 low beam headlights won't come but high beams and fog lights work just fine. Please Help!
your headlights are most likely the halogen type, when these headlights burnt out, it is almost always the dims that go first, then the high beams. replace.
May 23, 2017 | Chrysler Cars & Trucks
No headlights or fog lights
I suspect it is the headlight switch
Mar 18, 2014 | 2004 Pontiac Grand Am
Is my 2007 Lincoln Navigator (HID headlights) equipped with HIGH BEAMS? If so - they don't seem to work. Allow me to explain; 1. The headlights come on automatically in low light conditions. 2. The...
First of all are your headlights a double filament type headlight? If yes then I would suspect that a power wire to the high beams is broken or shorted. If your high beams are a separate set of lights from your regulars running lights then either the high beams headlights are missing. or has a broken power wire or shorted or...You could check the fuse box under your dash and under the hood of the car to see if you have a fuse for the high beam lights.
Oct 28, 2013 | Cars & Trucks
High beam indicator comes on with fog lights
Could your Mazda have daytime running lights? If you checked all fuses, did that include the three in the joint box?
There is an auto light-off control module that is central to all functions you describe. It is assumed that you would only turn on the fog lights with headlights on and set for high beam. If you set the headlight switch to LOW, the module closes the headlight relay to turn on the low beams. If you then turn the headlight switch to HIGH, the module turns on the high beams and allows you to turn on the FOG LIGHT switch, closing the fog light relay and turning on the fog lights. Since this sequence is not working, I suggest checking both high beam lamps as both could be burned out. Other possibilities are a defective headlight switch or the module
Oct 01, 2012 | 2005 Mazda 6
2005 Ford Focus ZX3 SES, the blue high beam indicator in the dash comes on with low beams, and goes off with high beams. The indicator is on at the wrong time! I have tried the following: The turn signal...
It sounds like you are confused about how your headlamp system is supposed to work. The DRL does not run on the High beam circuit, it runs on the low beam circuit. The fog lamps are supposed operate with the park lamps and also with the low beams, not the high beams. From your description, I would say that your system is operating as designed and you are having trouble telling High from Low. (Don't feel bad, that is why high beam indicators were invented in the first place.)
May 08, 2011 | 2005 Ford Focus
My 2000 Blazer low beam headlights won't come on .High beams, fog,running, turn signals all work fine.
Try changing the headlights....some headlight high beams will work even when the low beams dont
Aug 17, 2010 | 1995 Chevrolet Blazer
Driver side head light does not work...the high beam does
Change the bulb. High and low beams are separate bulbs located in the headlight housing. Im not sure on the 07 but the earlier design Yukon (02)you have to pull out a pin located under the hood on the top of the light housing in order to remove it.
Jun 05, 2010 | 2007 GMC Yukon Denali
Hi I have a 1997 for f150 I have no high or low head lights
check the fuses first, no luck replace the day time running light module.
Jan 27, 2010 | 1997 Ford F150 Regular Cab
High beams wont turn on.
First place to start is with headlight switch. I did have a case many years ago when both high beams were blown out at once, but this is rare. When you have the headlight switch out, jump power from te low beams to the high beam contacts. If high beams come on, replace switch.
Bill
Nov 19, 2008 | 2004 Ford Explorer Sport Trac
Jet 2007 GMC Sierra - New body style, Denali, 6.2L V8 - Performance Module Logo
66 people viewed this question
Top Jet Wine & Spirits Experts
richie46
Don Hart
Richard Warren
Richard Warren
Are you a Jet Wine and Spirit Expert? Answer questions, earn points and help others
