Question about JVC GR-DVL505 Mini DV Digital Camcorder
Just after Power Up, I get a E04 Unit in Safeguard Mode, Remove battery and Replace, which doesn't fix problem
sreekidu
  • 60 Answers
SOURCE: JVC GR-DVL109E Digital Video Camera
Hi, Assuming you have a JVC MiniDV Camcorder, the E04 error message means that the rotation of the video head has stalled or is too fast. When the little motor that pulls the videotape through the camera detects that the tape is not moving at the right speed, you get the SAFEGUARD MODE error. The principle here is that the camcorder detects a problem and shuts down in order to avoid doing additional damage to the unit. This is a legitimate way of protecting itself. The problem is that there are many reasons why the unit might not be able to move the tape, and obviously the question is: Why it is happening to my unit in particular? If your unit is still under warranty, then by all means run to JVC and have it diagnosed and repaired for free as soon as possible. Once your warranty runs out, if you start getting these errors again, it can cost over $150 just to have JVC look at it. Then possibly several hundred more to repair the unit. A few Quick Fixes to try: In most cases you should clean your camcorder's heads by running a cleaning cassette through. A little trick some have tried to eliminate this error message is to keep the cassette door open and then pull out the battery. Doesn't work? keep trying this routine. Some people actually report getting the error message to clear. Eject the cassette and just when it is about to eject, push it back in... and the error is gone. In Depth Solutions: Solution #1: Cold Reset The reason it tells you to REMOVE AND REATTACH BATTERY is not that the battery is bad, but that removing all sources of energy (battery and power cord) causes a COLD RESET. When you use the unit's on/off switch, parts of the camera are still receiving power and so you do not get the benefits of a COLD RESET. Just like your car; turning the ignition off will still power the clock and radio. You have to completely remove all power. If you are lucky, the camera will reset itself and start working again. Solution #2: Awareness of Humidity It seems older units would issue the same SAFEGUARD MODE error message for more than one problem. For example, older units do not tell you that they are shutting down for an hour because they detected high condensation, or moisture. So you play with the camera, remove the battery, reattach it, remove the tape, reinsert it, stand on your head, pray to your god, go to the bathroom, and voila! The camera is working again. It was nothing you did, just that the humidity went down enough for the unit to start working again. So consider high humidity as a possible source of the problem. If it is a rainy day, or you are near the sea, you might never get it to work that day in that location. Solution #3: Head Cleaning If you have never used a head-cleaning tape on your camcorder, you might give that a try. Mine has come back to life a few times by doing just that. Just don't do it too many times in a row because you can permanently damage the head. Read the instructions. So we have covered a few reasons why these errors come and go as if by magic. They are intermittent and recurring. The camera will appear to work at times, and the next minute it shuts down. Solution #4 : Fake Solutions Another reason why the problems come and go is that, as several technicians have reported, the problem can be a loose connector inside. That is why some people report that tapping the camera gently or rocking it side to side has brought it back to life. Some have gone as far as putting cardboard between the tape door and the tape mechanism in order to exert pressure and keep the camera working. I can only warn you that these kinds of "repairs" are temporary and likely to damage the unit further. Solution #5: Compressed Air On some models, there is no shield covering the many delicate electronic and moving parts in the tape mechanism when you open it to replace the tape. A piece of dirt, grain of sand, or other debris can get caught in the tiny gears and stop movement or throw them off alignment. You can explore this possibility by getting a can of compressed air at any computer shop and blowing it into the inside of the camera. Follow the instructions, keeping the air nozzle however many inches away from the target as they say. Practice on some other object first, because if you tilt the can or hold it too close to the target you can freeze the target and do more damage than good. This applies to fingers too! Solution #6: Tape Age, Brand, and Type Have you tried using a brand new tape? Or only your really old ones? Try a new tape. Now for the controversial issue of what brand of tape to use. Controversial because JVC's own Stacy Sample, Service Coordinator for JVC in Houston, TX says that "TDK and Maxell tapes tend to be two brands that are very problematic in our digital line wherein Panasonic, JVC and Fuji seem fine. We just find that TDK has the most problems, Maxell is a close second and Sony is 50% of the time. A different point of view I ran into is. Yes, there is an issue, but it has nothing to do with the brand, but with the tape type. There are MP and ME tapes. These two types use different particles, and different lubrication. The two lubricating materials form some sort of goo when mixed together, if you use both types of tape in the same unit. So as long as you don't mix tapes of different types, they will work just fine in your camcorder. Some refer to these types as "dry" and "wet", but I don't know which is which. In any case, it is not known (to me) how accurate this point of view of not mixing tape types is. Solution #7: Do not store tape in unit Because of the delicate nature of the miniDV mechanism, do not store the unit with a tape inside. The theory is that a loaded tape will put pressure on parts of the mechanism and increase the chance that parts will stick together, making the tape harder to be pulled by the motor, causing the SAFEGUARD error. regards sreejith
Posted on Jul 18, 2007
eagle338
  • 4889 Answers
SOURCE: E04
Here's what i found. I was able to clear the message by opening and closing and ejecting the cassette. I also had to play with the battery at the same time. Keeping the cassette door open and then pulling out the battery. After is did this a couple of times i got the message to clear. I too haven't used my camcorder for some time and now that the error message has cleared the camcorder tells me that i need to clean the heads. Hope this helps. Below is the message i found that pointed me toward ejecting the cassette. An error indication (E03 or E04) appears. - (E03 or E04 UNIT IN SAFEGUARD MODE REMOVE AND REATTACH BATTERY) This massage a malfunction of some kind has occurred. In this case the camcorder's functions become unusable. - Eject the cassette once and re-insert it, then check if the indication clears. When it does, you can resume using the camcorder. If the indication remains, consult your nearest JVC dealer or service center
Posted on Oct 18, 2007
SOURCE: E04 unit in safeguard mode
I tried every method I could find from people posting on the web, but the method that worked for me is this.
1. Eject the tape and close the tape holder.
2. Turn the camera off and remove the battery.
3. Put the battery back in. Leave the camera off.
4. Open the tape holder.
5. Slide the tape in, but as you press the holder in to accept the tape, keep your finger pressing in on the holder, being careful not to slow the tape holder from moving downward.
6. Turn the camera on.
7. If it doesn't work the first time, press more firmly to help the tape holder accept the tape.
That's it. This method seems to work for me and lets me use the camera for a long while. If the camera is sitting unused for more than a few hours, I have to do it again. And each time I insert a tape, I make sure that I keep pressing as the tape holder lowers the tape.
Posted on Mar 25, 2009
  • 4 Answers
SOURCE: Shows fault E04 remove & reattach battery
Do a search of this problem and you will ind that every JVC owner is having the same problem. I finally got mine "reset" by powering the unit on in payback mode while holding down the "play" button. Then, turn it back off and power it on in the camera mode while holding down the "rec" button. This seems to have reset it and I've not had anymore issues SO FAR!
Good luck with it.
Posted on Dec 17, 2009
SOURCE: JVC GR-DVX90
Put it on fire and buy some good camcoder<br />
Posted on Aug 20, 2010
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
GOT A AUTOSHOT 200X CC6363 THAT EVERY TIME YOU TURN IT ON GET ERROR CODE E04 & WHAT DOES IT MEAN
E04 - Battery in Safeguard mode.
The most common problem with this kind of model. there actually no fix for this problem. Unless of course your a jvc technician and can manage to open and clean all the sensor inside.
Have you tried to most popular solution for that.. tapping a little bit on the side of that camera. lol.
Look closely with the memory card, make sure it is inserted properly. push it a little more.
You may need to remove the battery from the battery pack and then reinsert again before turning it on. Doing it a few times may help solve the problem.
I do suggest you remove the battery when not in use. Leaving the battery inside is the usual cause for having the E04 when turning it on.
Hope this helps.
Mace1Mace
Dec 25, 2010 | RCA Video Cameras
Good luck with it.
Apr 28, 2009 | JVC Video Cameras
Hi, Regarding the above fault with my JVC camcorder, I have solved the problem by removing the tape and replacing with a new one. Thanks anyway.
Regards,
**** Coupe
Mar 30, 2009 | JVC Video Cameras
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
Jvc gr-dvx9 E04
The mechanism is out of sync, put a tape in and hold it, it wont go in but will try to open don't let it, remove the battery and reattach, let the tape eject, rinse and repeat 3 or 4 times and it will finally accept the tape.
Jan 08, 2008 | Video Cameras
JVC GR-DVX90
Dec 16, 2007 | JVC GR-DVX9 Mini DV Digital Camcorder
E04
Oct 18, 2007 | JVC Cybercam GR-DVM90 Mini DV Digital...
JVC GR-DVL505 Mini DV Digital Camcorder Logo
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
