Question about Shaw Robert RS-9420 Thermostat
Flashing flame on invensys item 9420 - Shaw Robert RS-9420 Thermostat
Battery for GE telephone model 2-9420. How to replace
Try Googling (GE)(2-9420)(manual) without parens.
Jun 17, 2017 | GE Lands Phones
Invensys s86
Most likely clogged or worn out diaphragm. Replace valve is only solution. Take your model number and go to your local appliance parts store or go to www.searspartsdirect.com
Sep 25, 2013 | Whirlpool Washing Machines
Belling cooker xou90fp/444447307
Circuit board replacement required check for recalls on your model. So had bab circuit boards in them.
[img src="http://www.partmaster.co.uk/image/150/5031688363526/0/z/" alt="Stoves Energy Regulator Invensys MP-V01-SVC" data-pinit="registered">Enlarge Image
Image shown may differ from actual product appearance
Jun 10, 2013 | Kitchen Ranges
Hi i'm looking for user instructions for an old style switchmaster 950 heating and water timer system. Thanks
Try contacting them here:
Invensys Climate Controls Europe
Telephone: +44 (0) 845 130 5522
Facsimile: +44 (0) 845 130 0622
Technical Helpline: +44 (0) 845 130 7722
Website: www.climate-eu.invensys.com
Email: customerservices@invensys.com
Just a note... I did not find a SM 950 but did manage to locate a SM 980
The website above links straight to This link: http://www.draytoncontrols.co.uk/content.aspx?id=2649
Under documentation they have programming instructions for the SM1 and SM2 that mention the SM980 under SM1 mechanical time switch here:
http://www.draytoncontrols.co.uk/supportingdocuments.aspx?id=1504#
This may not be what your looking for. If not just don't rate the post please.
Kelly
Sep 27, 2010 | Heating & Cooling
How can i install visioneer one touch 8900 usb scanner in Windos 7?
The 9420 visioneer Scanner driver will run the 8900 scanner.
first,go to visioneer and download the .MSI file for the 9420. Run it. The driver files will be found in directory: C:\Visioneer\OneTouch 4.0\9420 Drivers.next, find the 8900 drivers.they will be in c:\ Windows\twain_32\vizscan8xxx. open the file and look for rtscan.dll Rename it old rtscan.dll.if you can't find them,either use Device manager to show you where they are. or you can reinstall the Driver(Xp\2000\Me\Win 89 from Visioneer site. Rename the rtscan.dll file which will be in the twain_32 folder(see above).
copy all the files in 9420 Driver file to the c:\Windows\twain_32\vizcsan8xxx folder. turn your scanner on.windows should find the drivers and install the scanner.
Sep 18, 2010 | Visioneer OneTouch 8920 Flatbed Scanner
My Robertshaw 9420 thermostat keeps flashing, it won't let me set a temperature.
my robertshaw 9420 wont let me set a temp and two snowflakes are flashing
Dec 23, 2009 | Heating & Cooling
INVENSYS CONTROL FOR KENMORE ELITE SIDE BY SIDE
Hi, you can purchase replacement part on amazon, here: Amazon com KENMORE ELITE INVENSYS CONTROL I hope this was helpful. Cheers
Apr 27, 2009 | Kenmore Refrigerators
No spark
Replace your Invensys U-67204-8 0+4 Module: http://www.toolbox.invensyscontrols.com/appliance/linkedElements/ElectronicSparkIgnition_SparkReignition.pdfwith a Tytronics 4 Point Re-ignitor #RI 120E-4: http://www.tytronics.com.au/__files/f/2792/4 Point Re-Igniter.pdf which has replaced the older Invensys Module on BlueStar Ranges like the RNB304BV1 - 4 Burner Range (also used in some Viking Ranges): http://bluestar-store.mwrc.net/en/product.php?product_id=40478 Call Prizer-Painter 800-449-8691 for instructions if not sure how to do this. Also, may want to do some cleaning first overall on the Burners and the Igniters - BlueStar Part #741801: http://bluestar-store.mwrc.net/en/product.php?product_id=37702 or replace if broken: http://www.bluestarcooking.com/bluestar-service-videos.html#
Apr 18, 2009 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
RTH230B thermostat not working - nothing's happening
The 2nd combination is correct (w/ jumper). Wire nut or tape the blue wire. The snow flake shows it's going into cooling mode after a 5 min delay. If the AC is not coming on then the problem may not be the thermostat. If you don't have 24VAC between the red wire and the blue one the problem is at the furnace or it's supply. If you do, then check for 24VAC between the blue wire and Y on the thermostat(after the 5min delay) - if it's there the thermostat is calling for cooling. To check the heat, switch the thermostat to heat mode and use the W(instead of Y) on the thermostat(after the flame stops flashing).
Apr 02, 2009 | Honeywell Programmable Thermostat Heater
My Washing Machine 13 month old, was repared 1
Likely the ECU is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Shaw Robert  RS-9420 Thermostat Logo
Top Shaw Electrical Supplies Experts
obsteiner
Gil Shultz
Are you a Shaw Electrical Supply Expert? Answer questions, earn points and help others
