Fujitsu ASTG18KUCA Error code 97
Hi, we have just got a new ASTG18KUCA and it has an error code 97. When we switch off the circuit board it restarts ok for about 20 mins then stops, the flashing lights indicates its a 97 code error. any ideas?
  • 86 Answers
SOURCE: Fujitsu ASU9RLQ
check indoor unit sirkit board
Posted on Mar 15, 2008
SOURCE: Kenwood kdw243a dishwasher has an e3 error code
i have same prob,seen this elsewhere folks. apparently it's the temp sensor which MAY have failed. http://www.howtomendit.com/answers.php?id=134096
has to be cheaper than an expensive call-out and worth a try.
Posted on Mar 16, 2009
  • 659 Answers
SOURCE: mastercool swamp cooler fan doesnt come on.
Are the relays perment on the board or are they seperate from the main board? If they are mounted to the board, you will need to replace the board. Sounds like you are getting a call to the relay but none leaving so this would indicate that you have a bad relay switch.
Posted on Mar 21, 2009
  • 10 Answers
SOURCE: Fujitsu inverter air cond. just stopped working pr...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
Posted on Jul 15, 2010
  • 3 Answers
SOURCE: Fujitsu asu24cl blinking lights
This machine is a looser. Mine has same blink codes. Its been serviced every year since it was installed 3-4 years ago.. Since the elctric work was half the cost of installing it, maybe Ill put in a differnt brand!
Posted on Oct 28, 2011
Fujitsu astra07jec. 3 flashes on timer I have changed batteries in remote. Turned off and on at outdoor unit and still not working Indoor unit still blows air but not cool Please help
'Serial signal error' that means the outdoor unit is not talking to the indoor unit. Usually caused by bugs, geckos, cockroaches, etc. getting on the inverter board and frying it. You could try turning off the isolator (switch next to the outdoor unit) or the circuit breaker in the switchboard controlling that particular circuit for 10 minutes then back on. Sometimes that clears the error if you're lucky... but not normally. You will probably have to get a replacement controller. Get a tech to diagnose. The boards are pretty expensive but normally can be repaired by the Module Repair Service in Melbourne far cheaper than a new board.
Apr 16, 2018 | Fujitsu Heating & Cooling
What is the meaning of timer flashing twice in the indoor unit of fujitsu heatpump astb24ldc?
Need to check that models error codes but for most Fujitsu A/C's, that means a "serial signal reverse error at start up" which means your outdoor controller board is stuffed. Try turning the main power switch off for 5 minutes and then back on. If the error persists, you will need a new controller.
May 06, 2015 | Fujitsu Heating & Cooling
The red is blinking 8 times and green 4 times. The error charts states PFC circuit error. How can this be fixed ?
Power off at the isolator for 10 mins then switch back on and try again. If error code persists, then it is most likely the controller in the outdoor unit.
Excessive voltage of DC voltage on PFC circuit in inverter PCB is detected, or the excessive current in the circuit is detected.
> Permanent stop.
[Diagnosis Point]
Controller PCB defective (Refer to after mentioned "PFC circuit diagnosis")
Mar 21, 2015 | Fujitsu 15RLQ Halcyon Wall Mounted Mini...
Fujitsu ASY12RSE-W. Unit not working at all. Timer lamp blinking & operation lamp flashing twice
It's showing an error code for the outdoor unit no communication from the outdoor circuit board.
Jul 30, 2013 | Fujitsu 24C1 Air Conditioner
I have error 41
Hi Hector Aguilera - Typically error code E41 indicates that washer has detected that the main control board thinks the door switch is open. Try reprogramming the washer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, contact a professional to move forward accurately and properly assist with the repairs.
Jan 26, 2013 | Frigidaire ATF6000ES Front Load Washer
Eee code
error code 01 reset? indoor signal sensor
Apr 08, 2011 | Fujitsu 36CS Air Conditioner
Toshiba e-282 printer says call for service
please hold down 8+c and let us know what the error code is it will be shown on the display
if the error is c440 then do the following
switch off the machine
while holding down 8+0 switch on the machine
when the machine is in test mode key in 400 and press start button
key in 0 and enter switch off the machine wait a few seconds and switch on the machine if your code is c440 that should clear your error
Apr 05, 2011 | Toshiba e-Studio 232 Black and White...
I have a fujitsu AOTR30LCT, when turned on the green timer light and the red power light blink 3 times. Only the fan works and does not cool.
Error c0de-3.Return air thermistor short circuit.
This sensor when it's defective, will not command for compressor for working.
Replace it.(Room air sensor). Helpful?
Jan 24, 2011 | Fujitsu Heating & Cooling
Toshiba 160 error code
For error code C44, it indicates Heater abnormality.
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
Mar 09, 2009 | Toshiba E-Studio167 Copier
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
