Question about Whirlpool Refrigerators
Model number et1chmxkb06
Water pooling underneath fruit & veggie bins and in the freezer.
aborcass
  • 2651 Answers
SOURCE: Refrigerator/ water collecting under veggie bins
sounds like you do have a clogged drain tube, its self defrosting but the defrost water is pooling under hte crispers instead of in the drain pan under unit.so you ll either have to remove hte rear panel of freezer and locate the drain trough/ tube, and defrost it allowing for water to drain down, o rclear all the tube leading down to the drain pan.
Posted on Mar 21, 2008
SOURCE: My Whirlpool refrigerator leaks water
I also could not find the drain plug that everyone is saying to clean out. The only obvious things were styrofoam coated vents that went down to the fridge.
I have the same fridge with the sheet metal and cardboard in the back. My mfg. date is 6-04. That date is found near the ser. # and model #. My Whirlpool model # is ET1chmxkb03 THERE IS NO DRAIN TUBE RUNNING DOWN THE BACK!! It is all internal. Here is how I fixed the problem.
First, unplug the fridge. Empty all contents from the freezer and remove the shelf. Your food will be fine. Tell your wife not to worry!! You're going to need to remove the entire back panel of the freezer. Not hard. Remove the ice maker by unscrewing the single bottom screw and LOOSENING the two screws located above the ice slots. No need to remove them. they simply hang the icemaker in place. unplug the wiring assembly from the ice maker. set ice maker in sink if it has ice in it.
I had a lot of ice in the bottom and back of the freezer so i carefully chiseled and cleaned as i went. try using some hard plastic pointy thing to chisel. if that doesn't work use a screwdriver VERY CAREFULLY. I am not responsible for damages. ha.
the plastic "Y" shaped piece that covers the fan needs to come off. gently push down from the top to undo the two tabs that are holding the top to the wall. any resistance you feel is ice holding everything together. a hair dryer can also be useful to loosen things up. its going to get watery so keep towlels ready to sop up.
After the "Y" piece is off, you should only have two nuts or screws at the top of the panel. undo these and work off the panel. careful to push the wiring harness through the hole and the ground wire simply clips on the metal panel.
if you have a lot of ice at the bottom you'll feel resistance getting the panel off. scrape off as much ice as you can from the bottom and work the panel back and forth until it comes free. there is nothing holdin the panel in place at the bottom. it's just the ice.
when the panel is off you'll seea thin aluminum pan at the bottom probably covered in ice. keep chiseling (carefully) and you'll come across the drain hole everyone keeps telling you to unplug. this is the start of the tube that comes out into the pan under the fridge. i kept chiseling until there was no ice left anywhere in the freezer. always wiping and cleaning with the towels. there is also ice under the thin aluminum sheet. try to find a way to get this ice out too.
i tried several ways to get the ice out from inside the drain tube. even a little salt. boiling water from a turkey baster worked the best. my ice was frozen down about an inch so it took a few tries.
my drain pan was bone dry at the beginning of all this so i kept looking for water down there. finally it showed up.
pour little extra hot water down there for good measure and if you have some kind af flexible tubing to snake down there to clean it out it would be a good idea. 1/4 inch fish tank air tubing woorks pretty good. there are some bends in the drain tube so you might have to work it down.
hopefully this will fix the problem. reverse the steps to put everything back together being sure to reclip the groundwire to the icemaker. put the food back in the freezer and tell your wife instead of griping about the food being left out, maybe she should thank you for being a he-man and saving the family $500 by fixing the friggin thing yourself!!
Posted on Jan 16, 2009
woodchuck789
  • 4066 Answers
SOURCE: Magic Chef CTB1722 refrigerator leaking water from
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 12, 2009
mgprice
  • 744 Answers
SOURCE: water is pooling under the veggie bins- watere
Hello, this sounds like you have a blockage in the drain tube, remove panel back/bottom of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking into the freezer and down the vent into the fridge instead of running into the drain hole...Please feel free to comment again if you need any further assistance. Mike
Posted on Sep 12, 2009
woodchuck789
  • 4066 Answers
SOURCE: Model TBX21KLK water pooling UNDER vegetable bins
Posted on Sep 21, 2009
Where is the draining hole in a ge profile model tbx25pa refrigerator with top freezer
Underneath the cooling coil (evaporator) located in the freezer, there is a drain pan with a heater to warm it during the defrost cycle. The drain opening is probably blocked by ice or debris.
Sep 26, 2014 | GE Refrigerators
Ge model number tbx21jaxerww. Water collecting under vegetable bins
The water building under the veggie bins problem is usually a result of the drain under the evaporator coils being clogged with either ice or debris.
The get to the drain, the shelves and sometimes the bins will need to be removed, then the back panel will need to be removed. There usually are a few screws on each side that hold the panel in place...
Then look for the drain right under the coil....if possible run a wire down the hole to make sure it is open to the pan underneath.
If it is frozen then a wire can be used to keep the drain open...here is a tip about how to do that...
WaterRunning in refrigerator from Freezer
heatman101
Jul 27, 2011 | Kenmore 18.3 cu. ft. Top Freezer...
The vegetable bin freezes, fruits and veggies, such as oranges. we have changed settings and nothing seems to work
It sounds like to me that you might be getting additional cold air from the freezer side. Several models have an adjustable vent that allows cold air from the freezer into the storage bin on the fridge side. Close that vent and that should solve the problem.
Jul 02, 2011 | Refrigerators
Hi, I have a Kenmore coldspot top freezer, model # 106.70162990. it drips A LOT of water from the center to back in the top of the fridge, so much that it collects in the veggie and fruit bins and under...
Make sure the fridg. is level,(if it has been moved recently) there is a tube that allows the water from the evap. coils when defrosted to run to a drip pan. The tube is either frozen closed from prior defrosting or something is blocking the tube just below where it is leaking at. Turn fridg off and leave freezer door open (with a fan blowing in freezer if possible) for at least one hour and return to regular operation.
Aug 16, 2010 | Kenmore Refrigerators
Water is pooling, on the inside, at the bottom of the refrigerator, under the veggie/fruit drawers. After about 5 days, it spills out onto the floor.
hi , i can help you with that.
open the freezer back wall after taking all things from your freezer out.
on the bottom center of the freezer back wall there is a drain hole,
defrost all the ice with hair dryer and wipe it with a towel.
this hole should be free all the way to the drain pan next the compressor.
clean it with hot water and a pump...
thats all :) let me know if you need any more help...
Jan 11, 2010 | Refrigerators
Water leaking along back interior to bottom under & over veggie bins
Sounds like the drain to the drip pan is clogged -- maybe with ice.
Defrost water runs down to a drain in the bottom of the fridge and into a pan underneath where it evaporates.
Sounds like the defrost water is not reaching its final destination.
Here's the way the same problem was solved earlier today:
For those who have this problem with this model: The drip pan is in an open space on the back side of the refrigerator. There is a rubber spout that empties into it. But to clear clogs...you must take out the shelves from the freezer, unscrew and remove the back panel on the inside of the freezer. There you will see the water exit. Boiling water cleared it out.
May 29, 2009 | GE Refrigerators
Refrigerator has water underneath vegetable and fruit bis. It seems like an air flow situation
We found that the drainage for the defrosting was plugged. The water from the freezer drains from a hole that's on the top of the fresh food unit. There's a gutter that shunts the water to a tube that runs to a tray underneath the refrigerator. The tray was bone dry. So we unscrewed the gutter from the top of the fridge, and yes, it was plugged. Some Scrubby bubbles later, the plug was done. We reinstalled it, and now we don't have water underneath the vegetable/fruit bins.
This is for the GE TBF15DC For other models, your mileage may vary.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Whirlpool refrigerator top freezer
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Apr 07, 2008 | Refrigerators
Mar 21, 2008 | Refrigerators
Refrigerators Logo
69 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
