Question about Clarion VZ400 Car Video Player
I have the clarion VZ400 and the radio will no longer turn on. It was working fine yesterday and today it does nothing. I'm not sure what happened to the unit but any answers would be appreciated.
SOURCE: My clario vz400 won't turn
if you have a Dodge Ram you might have a infinity system so you need to go to cartoys or Best buy and get a special adapter I got mine at Best buy but you have to talk to an installer they have them in the back. it was about $70
Hope this helps.
Posted on Oct 21, 2010
jose_v17
  • 227 Answers
SOURCE: Is there a brake bypass
If you are asking for a way to watch movies while your in motion, all you need to do is hook up a simple switch (Cost 2 bucks at Radio Shack) You connect the "parking brake wire" to one end and then connect a wire from the other side of the switch to a ground, any will do. When you start the car simply flip the switch on then off and you should be in business.
Posted on Nov 25, 2010
604Autosound
  • 162 Answers
SOURCE: does the clarion vz400 dvd player support steering
Yes it will with the proper interface for your vehicle (works with most vehicles) You will need to get the interface from a good Car Audio store who can also help you hook it up and program it.
Posted on Feb 04, 2011
604Autosound
  • 162 Answers
SOURCE: Were does the backup wire go to on a clarion vz400
You use that when hooking up a backup camera to the unit, so that the camera image will show when you put your vehicle is put into reverse. Typically it is wired to your reverse lights when you install a camera.
Posted on Feb 05, 2011
muntejaya
  • 10421 Answers
SOURCE: I'd like to buy a
Please get the code here :
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__cg7
Posted on Feb 27, 2011
I have power to the unit but when i turn the ignition off it resets not keeping settings
Check your memory wire (usually yellow) to make sure it has a good connection. if this does not work then the internal memory module is malfunctioning or loose
Aug 21, 2011 | Clarion VZ400 Car Video Player
I have a clarion vz400 in a 2004 doge truck with an infinity sound system. It plays sound well through the radio and bluetooth but when you try to play a dvd or iphone through usb there is no sound. What...
your unit are not compatible to each other. try other usb that can compatible to the unit Clarion. Option use audio jack like earphone jack and RCA jack if you don't want to replace your DVD and Iphone
Aug 15, 2011 | Car Audio & Video
I Have A Clarion CZ100 On My Integra, I Put It Back On Yesterday Because My Car Came Out of The Shop. It Was Doing Fine Until Today, Turn On My Car and It Played, But When I Wanted To Change The Radio...
it's more likey the faceplate, and where it makes contacts with the unit. if you try applying pressure and moving the detachable faceplate on while attached and it turns on, there could be a cold solder/loose connection on the board.
Feb 06, 2011 | Clarion CZ100 Car CD MP3 Player
Feb 05, 2011 | Clarion VZ400 Car Video Player
Does the clarion vz400 dvd player support steering wheel controls
Jan 31, 2011 | Clarion VZ400 Car Video Player
I did not creat a password for my Clarion VZ400. The system is now asking me for a password in order access the system. Is there generic password to the system ? HELP !
Try '0000' and if you locked it by trying too many times, take a pen and press the reset button which is actually the small red light under the AUX in put once you reset it, it will turn off and turn on, when it turns on power it off by holding the SRC button which is the middle big one. Then it should allow you to enter the password and try '0000' it should work cause I have had the same problem and figured it out. Also if its still locked reset it a few more times in that order it'll work.
Jan 03, 2011 | Clarion VZ400 Car Video Player
Is there a brake bypass code for the Clarion VZ400?
Nov 25, 2010 | Clarion VZ400 Car Video Player
My clario vz400 won't turn on when I turn my truck on I press the power button on the remote and nothing happens when I press on the open button nothing happens all I see is a blinking red light on the far...
Hope this helps.
Oct 16, 2010 | Clarion VZ400 Car Video Player
1992 SAAB 900. Clarion radio. After repairs to
Are you sure that 1112 is the correct code as it looks as though your radio is not accepting it.
To check, post the radio MODEL NUMBER (begins with PU ) and also ALL the LETTERS+NUMBERS on any labels, barcodes or stamped in the casing and I will be able to see if I can check the code.
Sep 11, 2009 | Car Audio & Video
Clarion VZ400 Car Video Player Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
