Question about Craftsman Sears Snow Thrower Manual Model 536.887750
Newspaper jam how do I remove it. - Craftsman Sears Snow Thrower Manual Model 536.887750
    Master:
  • Craftsman Master
  • 428 Answers
Explain your self more about this ?
Posted on Oct 16, 2014
Coolpix L 100, got some water in it, dont know how much, initially the lense would come out now it wont, LCD turns on but flickers and is distorted (As TV Channel is untuned) and send message "Ur lense cap...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} First remove the battery, and proceed to dry the camera completely to take out all moisture trapped in the camera: Dry the camera, battery, any accessory, etc. with cloth, then wrap each piece, camera and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped camera in the bag with rice. The newspaper wrapping avoids direct contact of rice with your camera because the dust from the rice can get into the small areas of the camera. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
May 21, 2010 | Nikon COOLPIX L100 Digital Camera
Razr phone just fell out of back pocket into toilet. I took of back cover & removed battery. What next?
Dry the phone, battery, sim card, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
May 19, 2010 | Motorola Mobility RAZR V3
How to remove ice maker, it is jammed
moz-screenshot.pngRemove the ice bin first by pushing the button on side and pulling out.
Next look on the lower left side of where the ice bucket was, you will see a slot, insert a flat screwdriver into the slot tilt the screwdriver up, this will push down on a tab inside the slot and the cover will come loose.
Remove the cover and unplug the wire harness to the ice maker
Release the locking lever on the side and the ice maker assembly will slide out.
Apr 18, 2010 | Maytag MFI2568AE Side by Side French Door...
Shredder is jammed
hello. follow these steps:
  1. Turn the shredder off at the wall and unplug it. You DO NOT want to be poking round in those sharp blades and have it accidentally switch on!
  2. Take the top off the shredder and place it on a big piece of newspaper, or somewhere you can easily sweep up mess.
  3. Begin by getting a pair of tweezers and taking pieces of paper from one end of the shredding blades. This will loosen it up and give you more room to get the rest out.
  4. Carry on tugging the strips of paper out. It helps if you don't just pull a clump, but wiggle it from side to side. This will get the whole strip out, not just the top.
  5. If any pieces are curled round and you can't free them, cut them with the knife and then tug them out.
  6. Once it's mostly cleared, put the top back on and switch the shredder on. Put it on Reverse mode so it will spit the last bits back up for you to remove.
  7. If it's clear, continue shredding!
[edit] Tips
  • Remember to wiggle the paper, not just pull.
  • Shake it occasionally to get smaller pieces of paper out of the blades.
  • Try not to jam it in the first place (avoid loading a lot of paper or thick sheets of newspaper).
  • Use oil paper or performance oil to lubricate the blades on a regular basis. For an office shredder, medium to heavy usage can require lubrication as often as every three days.
  • To prevent the shredder blades from dulling, remove paper clips and staples before shredding. Shredding CDs and DVDs also cause premature wear & tear. Use the Disc Eraser (www.DiscEraser.com) if you have sensitive discs.
[edit] Warnings
  • Always turn the shredder off at the wall and unplug it! You don't want shredded fingers!
  • Be careful with the blades - they are sharp and you could cut yourself.
[edit] Things You'll Need
  • A pair of tweezers
  • A small, sharp knife
Oct 23, 2009 | Office Equipment & Supplies
What is the proper way to store an empty chest (deep) freezer for several months?
I would suggest wadding up about enough newspapers , to completely cover the bottom of the freezer . The ink in the newspaper , will absorb any odor that is in the freezer or can get in , while being stored . This is also , the only way known in the area , to remove fish , or bad meat odor . Takes a little more newspaper for that though .
Oct 14, 2009 | Whirlpool Freezers
I have not used my printer for ages it is working but not printing i have tried shaking the ink cartlidges but it has not worked
After long periods of non-use, ink can dryin the jets and jam them up. The clean printhead utilities that come with the printer may not work when this happens.
A couple tricks:Try pulling the cartridges and cleaning the print surface with a q-tip and alcohol. Then set it on a paper towel or newspaper for 30-40 seconds to draw the ink out. Replace them in the printer and re-try.
If this fails, heat some water up in a bowl (you don't mind getting ink on). Dip the cartridges in for a few seconds, then dry with newspaper/paper towel.. Replace in the printer and try to print.
Let me know how it goes, OK?
Mike
Aug 31, 2008 | Lexmark Office Equipment & Supplies
Front Paper Jam
I'm not 100% sure that this will work. I have a 3N, when we first got it I had the same problem. After clearing the jam - You have to open the top portion of the printer. Even if the jam is no where around that area... the printer won't reset itself until you lift that top piece. I even tried to turn it off, thinking it would reset...it didn't.
I know the 4g is much newer then mine...but being it's the same company.. this problem might be fixed the same way.
Good Luck.
Jan 05, 2008 | Xante Accel-a-Writer 3N Laser Printer
Not Coffee just Hot Water
runner, sounds like you've got a jam up! Remove all the coffee you can If you can, try to remove the burr and clean whatever you find out. Now, turn the unit upside down over the sink to remove everything messy. Then, turn the unit upside down over a newspaper and tap the unit a couple of times to dislodge what may be jamming it. Put it all back and you may be okay. Otherwise, you'll have to dig deeper into the unit to remove the coffee bean 'stuff' that is jamming it. You may even be able to flush it out with warm water. Be sure to air dry everything before reloading with coffee.
Nov 19, 2007 | Cuisinart Thermal DGB-600 Grinder
Craftsman Sears Snow Thrower Manual Model 536.887750 Logo
113 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
