Question about Kitchen Ranges
Hi i have a kenmore model c970-652522 and my ove dosent want to heat i can put bake and put my temp to 350 but no heat and my elements seem to be good any solution
catriver
  • 878 Answers
SOURCE: Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Posted on Sep 07, 2006
fridgetech
  • 473 Answers
SOURCE: Electric Kitchen aid, model kerc607...broil elements
What is the complete model # from the sticker on the range? I will need that so I can look into this for you. I will say that I have seen, in several cases, where the oven control gets a surge and fries after an element has broken.
Posted on Nov 10, 2007
  • 26 Answers
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore Stove
You could very well have an Electronic Oven Control (EOC) board problem. There two separate circuits that control the oven BAKE and BROIL functions. If you have replaced the BAKE element, and have ensured it connected properly, the only other component that controls that function, is the EOC. If you post back with your complete model number, I can double check to make sure. The model number will be located on a nameplate somewhere around the oven door opening or lower drawer opening. The reason I need to confirm is because some ranges have a separate relay control board.
Posted on May 28, 2008
  • 197 Answers
SOURCE: My oven's bake/broil element won't heat
It could be the stat (temp probe) or the cut outs. if these are faulty then it will not allow the elements to heat up
Posted on Sep 21, 2009
Oven will not pre-heat properly
you might want to check where the thermometer is located on older models it can be knocked out of position perhaps to close to the roof of the oven which gives false heat reading
May 01, 2015 | Kenmore Kitchen Ranges
RF214LXTS 0 I have a whirlpool stove, have power on both incoming legs. the top works fine, but the bake and broil elements in the oven dont work. the saftey fuse on the back seems to ohm out good as...
The way power typically is supplied to the bake/broil elements is that directly off the terminal block 120volts ac is supplied directly to the elements at all times and when the touch pad is pushed a relay on the clock/eoc (electronic oven control) will close and supply 120vac so the element has 240vac to heat. you should be able to see the wire coming directly off the terminal block where the cord from the house wireing connects to,going directly to the elements and as stated above theother 120 vac from the relay to the elements (their is 2 relays,one for bake and one for broil)
As far as testing the oven sensor(temp probe) at room temp the ohms reading should be 1060-1100 ohms and as the tempature rise the ohms rise so to test it verify is 1060-1100 at room temp then heating it usinga blow dryer,match or cigarette lighter and the ohms should rise as it gets hotter and drop when its cooling
Good luck,i hope this helps and if it does help please give me 4 thumbs up
Gene
Jul 27, 2011 | Whirlpool Ovens
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
My Kenmore Elite oven will take over an hour to preheat to 350 degrees and never does get done preheating.
There's a few things that can cause this.
1. Check to see if the both that Bake and Broil elements (burners) are heating up. Check the Broil element in Broil mode.
- during pre-heat the Broil element gets cycled on and off for short time durations to speed up the heating. If the Bake element is not working, then the oven will heat, but very slowly and never reach high temperature.
2. If the elements are both working, then it's possible that you have a bad temperature sensor.
- this is a temperature dependent resistance device that should measure 1080 ohms at 70 deg F (room temp).
3. If #1 and #2 are ok, then the problem is with your oven clock/control unit. We rebuild these at fixyourboard.com.
Aug 14, 2010 | Kenmore Ovens
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
I have a Kenmore model 911.9352190, the probelm is that the ove doesn't get up to temp. if you set it at 375o/o it might go to 125o/o or 150o/o I replaced what I thought was the thermastat the long part up...
Disconnect the power to the range. Remove the bake element. Use a volt meter set for continuity or ohms and test the element. One meter lead to each terminal.No reading is a bad element. If the element is good,the ERC board is bad.
Nov 25, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Kenmore 4042990 built in oven not heating properly
that stove doesn't have a thermostat,everything runs through the clock assy,and that board isn't made anymore there's a sensor that could be bad the sensor tells the computer board or clock assy. same thing how hot it is in the oven but you can't get that either the stove is just to old they don't make parts for it anymore but first thing,when you put it on bake does both elements get hot?when you bake both elements are used bake and broil if it's taking a long time to heat up one of the elements could be bad,and you can still get the elements,first run it on broil and see if the element gets hot if it does then put it on bake and see if the element turns red when it's on,you could have a burnt wire that connects to the element and it's not fully heating,you're only getting 110 volts to it not 220 or either one of the elements are bad and the oven isn't heating up to temp. but if the elements are good you can't get any other parts for that model and that is 911.4042990 correct sorry for the bad news but hopefully it's just a bad element good luck
Nov 09, 2017 | Ovens
Mar 30, 2008 | GE Profile Spectra JBP95 Electric Kitchen...
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
