Question about Dorman 1994 Ford E-150 Econoline Club Wagon Air Pump Pulley Dorman
Door lock relay location 1998 ford econoline van
Lock but no unlock
How to do a tune up on a 1999 econoline v8
If you could be a little more specific as to what model Econoline do you have?
I found a list of DIY's for the econoline and have assumed that yours is a 250. Go through this diy for helping you work on the van without any difficulty. Be it changing the spark plugs or regular maintenance work or even overhauling!
http://www.automotix.net/autorepair/diy/1998-ford-e_250_econoline-repair.html
Feb 27, 2013 | 94-00 Ford Econoline Van Side View Mirror...
Where is the oil sensor located on a 1998 Ford Econoline Van?
my dad's Ford is left of center on rear, behind manifold.
_________________
Ford vcm ids
Oct 31, 2012 | 1998 Ford Econoline
97 f150 econoline fuel pump relay location
location of fuel pump relay for a 1997 ford econoline van
Apr 15, 2011 | 1997 Ford Econoline
On a 1998 Ford Econoline E-150, it has electric door locks. The side door and the back door lock does not work. Everything else in the van works. Where do I start looking besides fuse #4 and #5.
it could be the lock motor or it could be the wiring that came lose or wire damage ! need to now if it works from the doors that dont work or from the driver door it my be locked out at the diver door or it can be a wire lose or switch on driver door !
Apr 05, 2011 | 1998 Ford Econoline
Where is the powerlock relay located on a 1998 ford expedition eddie bauer
The Aux. Relay Box #4 is located in the rear driver side removable panel with the jack. The box holds the Door lock and unlock relays; The driver's door lock/unlock relay and the ACC. Lights relay.
Jan 10, 2011 | 1998 Ford Expedition
2000 E350 door locks wont lock, but will unlock. Recent rain must have caused short because fuse was blown. After changing fuse locks unlock, but will not lock. I understand they are separate relays? where...
i dont know about a e350,but on a f150 there is a locking relay behind the dash on the passengers side,just listen for clinking sound when you un-lock it.
Jan 24, 2010 | 2000 Ford Econoline
The power locks will just all of a sudden pulse up and down without touching any buttons. I will be driving down the road and the locks with lock then unlock, the interior lights come on and after a short...
Good Afternoon,
From what you are describing it sounds like you have a faulty relay or 2. See if you can locate the relay to the door locks and for the interior lights. It is unlikely that 2 relays are gone at the same time, so I suspect that there might be one relay controlling both functions. If you find it simply replace it. I hope this information helps you.
Mar 26, 2009 | 1998 Ford Econoline
Power door locks working sometimes!
try replacing the master door lock switch in the drivers door this will take care of the problem
Mar 09, 2009 | 1999 Ford Econoline
Dorman 1994 Ford E-150 Econoline Club Wagon Air Pump Pulley Dorman Logo
Top Dorman Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Tom Chichester
Are you a Dorman Fish Expert? Answer questions, earn points and help others
