Question about Dell OPTIPLEX GX1 PIII-667MHz 128MB 10GB (DELLP3667) PC Desktop
Formatting I need to format my pc but it is old and the cd drive does not work, i don't even have the cd to format it, what can i do?
  • jatman1271 Oct 26, 2007
    The OS is Windows 2000 Professional SP4
  • purple_dark8 Sep 27, 2008
    how to format and why i can't go c mos and when insert cd window can't run??
  • 196 Answers
What is the operating system?
Do you have a floppy drive?
You can get boot disks, with the format command, at www.bootdisk.com
Posted on Oct 26, 2007
My laptop won't boot up
Improve the FixYa experience for everyone by voting.
I'm at a disadvantage because you haven't specified an operating system.
My suggestion, if you are running Windows, is that you reformat your hard drive and reinstall your operating system. The proper procedure is set forth below:
When formatting a hard drive you will need certain things to perform this task correctly. Here is a list of things you will need when you want to format your computer.
  1. You will need a Windows operating system CD. Hopefully you will have the original CD hanging around somewhere. it is also okay to use a copy of your exact disk that you had as long as you have your Windows COA sticker attached to your computer. This is also known as the COA sticker and holds the serial number for your copy of Windows.
  2. You will definitely need to have your files backed up to either an external hard drive or maybe even an online backup service.
  3. When formatting a hard drive you will obviously need a computer that needs a format. This might be a computer with so many errors that it is not worth fixing. It may also be a computer that just hasn't had a good format in a long time.
  4. If you are formatting using Windows XP or even Windows Vista you will need to have either a backup of your device drivers or a system disk that holds your drivers. If you do not have a disk that hold your device drivers then you might have to search for them on the Internet. before formatting a hard drive I seriously recommend making sure that you have a driver for your network adapter so you can connect to the Internet. This will allow you to download the other drivers if needed.
Backing up your files before formatting a hard drive
This is one of the most important things that you can do. People do not understand that when you are formatting a hard drive, this means that you will wipe every piece of darter from that hard drive. If you had saved photos and files or even e-mail addresses, they will all be gone after formatting the hard drive. I hope you understand what I am saying here. Absolutely everything will be gone from your computer and you will only have a fresh new copy of Windows is installed on your computer. This also means that any programs that you have installed, such as photo editing programs, games, and so on, will be absolutely gone. When you have finished formatting your computer, the usual procedure is to reinstall all of your necessary programs and drivers to enable you to start using your computer again.
When formatting a hard drive with any version of Windows you must insert the operating system CD and boot from it. This means that you will see a message on the screen saying "press any key to boot from CD or DVD..". If you do not see this message when you start your computer with the Windows operating system CD in the CD drive, then you must enter your computer BIOS and change the boot settings. Here is a brief tutorial on how to change settings in your BIOS.
  1. It is always recommended that you delete the previous partition that Windows was installed on an create a new partition for the new installation.
  2. In all versions of Windows you will have the chance to divide or partition your hard drive into any size you require.
  3. All of the recent versions of Windows use the NTFS file system. It is not recommended that you use the old FAT32 file system.
  4. When formatting a hard drive in any version of Windows you will see an option to choose a quick format or a slow format. A slow format is always better when you have had major errors on your computer. This can also be known as a low level format.
Common problems people have when formatting a hard drive with Windows
  1. The first step is probably the hardest. As previously mentioned above, you will need to insert the original Windows operating system disk and then start your computer so it boots to that CD. People do not realize that you need to enter the BIOS to change the settings to make the computer boot to the CD first. Some people think there is a problem when the CD does not start.
  2. People often get confused when deleting the partition and creating a new one. Please pay particular attention to this area as it is not as hard as you think.
  3. When you have had your Windows disc for a long time it can become worn. Often I will make a copy of my original disks to use as the original would not transfer the system files to my computer correctly. If you find that when formatting a hard drive, the process stalls a number of times, then it could be your CD is worn out.
  4. One of the common problems that people have when formatting a hard drive is that they accidentally interrupted the process. It is not okay to stop the process of formatting a hard drive half way through. This is a definite way to cause major errors or even the dreaded black screen on your computer.
Formatting your hard drive with Windows
Below I am going to list step-by-step instructions to follow when formatting a hard drive in various versions of Windows. They are all very similar with only a few minor differences. Therefore if you are experienced in formatting a hard drive using Windows XP, you will definitely have no problem formatting with Windows Vista or Windows 7.
The following steps below presume that you have entered your BIOS and change the settings for your computer to boot to your CD or DVD drive. Therefore you will see the message on the screen saying "press any key to boot from CD or DVD..." If you have not this far and press a key on your keyboard, this means that you are booting into the CD to start formatting your hard drive.
Formatting a hard drive using Windows XP
1. The first screen you will see will be blue and it will look like files are being loaded onto your computer. You will be prompted to press the F8 key to agree to the Windows terms and conditions.
2. The next screen you will see after booting from the CD will be a blue screen. On the screen you will need to read it carefully and then press enter. If you press enter on your keyboard, this means that you want to install Windows XP. See the screen shot below
3. Now you will see a screen showing the previous installation of Windows.
4. Select that version of Windows so we know which partition we are going to delete. If you have not got a previous version of Windows on your computer you will see an un-partitioned space.
5. As you can see in the screenshot above I have selected the previous version of Windows.
6. Now I will press the escape key to install a fresh copy of Windows XP.
7. On the next screen I will select the partition with Windows on it and press D on the keyboard to delete it.
8. Then I will press the letter L to confirm that I want to delete that partition.
9. To recreate a petition we will need to press the C on the keyboard. Your computer will estimate the size for the partition and all you have to do is press enter.
May 20, 2012 | ASUS Eee Computers & Internet
How to format your computer
I have no personal interest or association with any product that I may suggest.
Unfortunately, you have provided no information on your operating system. The information set forth below is for Windows XP.
  4. If you are formatting using Windows XP or even Windows Vista you will need to have either a backup of your device drivers or a system disk that holds your drivers. If you do not have a disk that hold your device drivers then you might have to search for them on the Internet. before formatting a hard drive I seriously recommend making sure that you have a driver for your network adapter so you can connect to the Internet. This will allow you to download the other drivers if needed.*
*This is one of the most important things that you can do. People do not understand that when you are formatting a hard drive, this means that you will wipe every piece of darter from that hard drive. If you had saved photos and files or even e-mail addresses, they will all be gone after formatting the hard drive. I hope you understand what I am saying here. Absolutely everything will be gone from your computer and you will only have a fresh new copy of Windows is installed on your computer. This also means that any programs that you have installed, such as photo editing programs, games, and so on, will be absolutely gone. When you have finished formatting your computer, the usual procedure is to reinstall all of your necessary programs and drivers to enable you to start using your computer again.
  • When formatting a hard drive with any version of Windows you must insert the operating system CD and boot from it. This means that you will see a message on the screen saying "press any key to boot from CD or DVD..". If you do not see this message when you start your computer with the Windows operating system CD in the CD drive, then you must enter your computer BIOS and change the boot settings. Here is a brief tutorial on how to change settings in your BIOS.
  • It is always recommended that you delete the previous partition that Windows was installed on an create a new partition for the new installation.
  • In all versions of Windows you will have the chance to divide or partition your hard drive into any size you require.
  • All of the recent versions of Windows use the NTFS file system. It is not recommended that you use the old FAT32 file system.
  • When formatting a hard drive in any version of Windows you will see an option to choose a quick format or a slow format. A slow format is always better when you have had major errors on your computer. This can also be known as a low level format.
2. The next screen you will see after booting from the CD will be a blue screen. On the screen you will need to read it carefully and then press enter. If you press enter on your keyboard, this means that you want to install Windows XP. See the screen shot below:
May 19, 2012 | Computers & Internet
How do I format a dvd disc
You don't have to. DVD's and CD's are already formatted from factory. But if you are having problems to record on (burn) them probably your computer is not capable for DVD burn, just CD's. But if it is equipped for burning then try this:
See alsoFormat a CD or DVD
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting. There are several ways to format a CD or DVD disc. Your choice of format determines which computers and other devices will be able to read the disc.
  1. Insert a disc into your computer's CD or DVD drive.
  2. In the dialog box that appears, click Burn files to disc.
  3. In the Burn a disc dialog box, type a name for your new disc.
  4. Click Show formatting options, and then click one of the following formatting options:
    • Live File System
    • Mastered
  5. Click Next to prepare the disc.
    Now you can copy files to your disc using whichever method you selected.
Nov 30, 2011 | HP Computers & Internet
I bought a Dell Optiplex 745 with no hard drive. I bought a second hand WD800JD SATA hard drive with no CD's and installed it. The computer does not recognize it so I cannot load an OS. Can you help?
make sure that the leads are in there correct slots
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Dec 04, 2010 | Western Digital Caviar SE WD800JD SATA...
How i can format wyse x90l
You can not format the Windows Drive (referred to as windows partition) while the windows is running.
CAUTION: FORMATTING A PARTITION OR HARD DRIVE WILL RESULT IN ALL THE DATA BEING LOST.
But you can format any other drive or partition, to format a drive or partition other than the windows', open My computer right click on the drive icon and click format, press all the OKs and your drive will be formatted in a while.
To format whole hard drive, even the windows partition,
CAUTION: FORMATTING A DRIVE WILL RESULT IN LOOSING ALL THE DATA AND THE WINDOWS AS WELL.
Now back to business, to do a complete format you need a bootable cd, If you have your recovery disk or even a bootalble windows disk you can format everything.
Lets assume that you have a windows bootable cd, insert the disk while the laptop is starting (make sure that the computer boots up with the cd), let the setup load its files, then follow the instruction until you reach to the point when you can see your hard drives and its asking for formatting press F to format the drive which is highlighted.
Thats it.
Please feel free to ask me any further.
Apr 07, 2010 | WYSE X90e - C7-M 1.2 GHz ULV - RAM 512 MB...
How to format laptop?
if you don,t have a proper formatting cd which comes with the laptop.then don,t try to format with any cd it can cause problems.so buy a formatting cd from a reputeted store
Nov 25, 2009 | HP Pavilion dv1000 Notebook
Unable to delete data or format or partitioning samsung HDD
Have you tried booting from a Windows XP CD? If you have one available you can boot from it, delete the partition and format it. Works all the time for me.
Jul 30, 2009 | HP Computers & Internet
Windows XP with SONY RW-AW-G170A DVD-RAM Drive
try a bit of burning software called "infra-recorder"
http://infrarecorder.org/
Its 100% free. If it doesn't work with this, then try the drive on another computer. If it doesn't work there well then the Drive is dead.
If it works on another computer try updating your drivers for your whole system and if that doesn't work reinstall with the newest drivers and software that you can find.
May 19, 2009 | Computers & Internet
How to format my desktop
i pc has affected with virus, so i want to format my computer. how can i format ?? My operationg system is Windows xp
Jun 07, 2008 | Computers & Internet
N91
Menu>Tools>Hard drive>Options>Tools>Format hard drive
Formatting the hard drive will clear any data stored on it. This should be a last resort and we'd suggest trying to scan the hard drive first. This will attempt to fix any hard drive disk errors. If your N91 does not have the scan option (some don’t) then connect to your PC in mass storage mode, right click on the F: drive, then hit scan.
Mar 24, 2008 | Nokia N91 Cellular Phone
Dell OPTIPLEX GX1 PIII-667MHz 128MB 10GB (DELLP3667) PC Desktop Logo
119 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
