Question about Gestetner Office Equipment & Supplies
We have 10 gallons of Gestetner "Roller Wash/Offset Blanket cleaner, where can we get a MSDS sheet for this product?
4 Suggested Answers
old marine
  • 2005 Answers
SOURCE: Looking for MSDS Sheets for
Here is the link.
Posted on May 08, 2008
komguy
  • 2306 Answers
SOURCE: Material Safety Data Sheet
The printer itself won't have an MSDS report. Each of the toners and supplies come with MSDS sheets, or the address and phone #'s to obtain them from Samsung.
Posted on Jun 22, 2009
andrewpsp
  • 92 Answers
SOURCE: FIRESTOP MORTAR CP637 I NEED
I found msds resources at http://www.msds.com/, I'm not sure of the question, can you be a bit more specific ?
Thank you
Posted on Nov 03, 2010
C5 LDS leak fouled neighbour's driveway. Can't get the stuff off. Neighbour well racked off. Is there an 'LDS solvent ?? Robbieupnort. (C52.2Hdi173hp)
Material Data Safety Sheets are required on all chemicals liquids in the United States. One of the sections will give you recommended clean up procedures. You can search for the MSDS for your specific product here:
If this was helpful please rate yes.
MSDS Solutions Center offers 3 5 million MSDS documents available online
Nov 16, 2016 | Cars & Trucks
Do you have an MSDS sheet for this product, please?
In the UK this product would fall under the COSHH (control of substances hazardous to health) regulations.
Employers are supposed to obtain a COSHH information sheet for every product they use, keep the sheets in a folder and make the folder available for inspection. In fact it is strongly suggested employers request employees read it every six months. In addition to the product information sheets the folder should also contain risk assessments written by the employer or a consultant about how the substances are used within the company, what they are used for, the dangers of using them and what they should not be used for and the recommended procedures for dealing with accidents resulting from the use or misuse.
Lots of suppliers will provide information sheets automatically but sometimes a sheet must be requested.
There are difficulties obtaining complying information sheets when a substance is intended for domestic rather than industrial use, sourced from a retailer rather than a trade supplier or where the product presents little or no danger to the user.
In such cases it is considered sufficient for the employer to carry out such research about the product as is possible and also carry out any testing that might be needed and write his own information sheet along the lines of the official sheets, including the usual risk assessment.
Dec 03, 2015 | Fujitsu Scanner 100ml F1 Cleaner, Low VOC...
How do I get msds sheet for this product?
If whoever made that product made an MSDS sheet, then it could be listed in the following database: http://www.msdssearch.com/msdssearch.htm.
Feb 26, 2015 | Seiko Smart Label 420 Thermal Printer
AM LOOKING FOR MSDS SHEETS FOR SHIELD PINE,AND OTHERS
Solution #1 Call the seller and ask for a MSDS sheet to be emailed to you, they generally have them and use them for shipping purposes.
Solution #2 Find the active ingredient in the product and "Google" along with "MSDS".
Jan 06, 2014 | Johnsondiversey Cleaner Degreaser Size 1....
I HAVE AN A.O.SMITH POWERHOUSE POWERSHOT POWER VENT WATER HEATER , THE MOTOR RUNS FOR 10 SECONDS AND CUTS OFF AND GOES TO VACATION PLUS THREE LIGHTS. NO SPARKS AND THE BURNER DOES NOT LIGHT UP
Sounds like water heater air intake clogged with dust, caused slow venting of combustion gas that overheated combustion chamber and tripped FVIR lockout system.
http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html#AO
Copy following link to identify type of gas control valve and download service manual that might apply to your unit.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
You need to clean air intake with compressed air or feather duster:
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
And possibly replace gas control valve, and/or replace thermal cut-off located inside combustion chamber, or on later models, reset thermal cut-off located on front of combustion chamber, or replace FV sensor.
Oct 02, 2012 | Water Heaters
How many thermoststs does the nissan nomad have
1 this being the specifications on it
Features & Benefits Quality Controlled Factory Calibration Assures Accuracy Of Opening & Closing, Regardless Of Pressure Changes. Positive Piston Heat Motor Provides Accurate Temperature Control. Sturdy Metal Construction Throughout. Attributes Depth from Flange : .82"
Design : Offset
Flange Diameter : 2.125"
Height from Flange : .91"
Jiggle Pin : Yes
Temperature Range : 195 Deg
Warranty Limited Lifetime-See Manufacturers Written Policy
Warranty PDF
Material Safety Data Sheet (MSDS) There is no MSDS for this item Application Information: 1990 Nissan Van Engines : 2.4 L 2389 CC L4 SOHC
Comments: 195 Degrees;Alternate Temperature
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Warranty PDF
Per Car Qty: 1
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Design : Offset
Jiggle Pin : Yes
Feb 27, 2011 | 1990 Nissan Minivan
FIRESTOP MORTAR CP637 I NEED TO HAVE THE MSDS SHEETS FOR THIS PRODUCT
Thank you
Nov 03, 2010 | Office Equipment & Supplies
MSDS FOR BROTHERS TONER CARTRIDGE
Material Safety Data Sheet,
It is the form that tells you all of the components that make up a product, the chemical break down, what to do in an emergency, such as ingestion, getting in eye, etc.
Hope that helps, Mikey
Apr 04, 2008 | Office Equipment & Supplies
26 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
