Question about Omega Constellation Watches
How to stop the omega constellation perpetual calendar watch. It keeps moving it's almost 5 hour now....
SOURCE: watch
You should be able to pull the crown out 1/2 way and turn the crown clock-wise and you should hear a click and the calender should move one day. Don't change when the hands when the time is between 10 and 2 , just manually move the hands past that time , and re-set afterwards. If that dosn't work let me know ,.There are other types of those watches , but the way I told you is the most common.
Posted on Jul 07, 2008
VOTIT
  • 2071 Answers
SOURCE: battery for omega constellation f300hz watch
Before I repair that kind of watch,using the battery size Maxell "SR 912.In Swiss battery liked Renata has a equivalent number of 912 is Japanese standard battery size. Its better you bring it to a authorized service center im sure they have available special battery for that watch. They have a special tool to open that with no scratch it is an expensive watch.
hope it may help you;
Regards;
VOTIT
Posted on Jan 08, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: changing the date on a timex perpetual calendar watch
You can download the Perpetual Calendar instructions from Timex's website here.
If you don't like clicking on a link, here's the URL:
http://assets.timex.com/instructions/perpetualCal.pdf
Hope this helps. If this solution has been what you needed, please take a moment to rate it a fixya, and thanks for asking here!
Posted on Mar 11, 2009
SOURCE: How to reset the calendar on a Seiko Perpetual calendar
How to boot a mp3 player
Posted on Mar 26, 2009
SOURCE: Set hour minute on Omega Constellation Day Date (Quartz)
Found solution at: http://www.timefactors.com/omegacon.htm Regards, Joe
Posted on Jun 11, 2009
How to reset the watch
Depends on the watch. A perpetual calendar needs some one who knows how as it is a set combination of buttons to push on the movement. A Omega seamaster there is a button on the crown you need to push in for a few second and the second hand will stop, this is complicated to explain. O normal watch just pull the crown out on stop to change the date/day 2 stops to change the time.
Nov 27, 2017 | The Watches
Just a quick question On my Omega Double eagle, I went to mexico for the week left my watch at home and when I return I gave it a shake to start the movement being it is a chroncile watch and for some...
A mechanical watch will tend to stop in the same place if an internal gear is slightly unbalanced and/or there's a spot of grease/dirt that makes that particular point on a gear slightly more difficult to pass. I've often seen watches with day/date indicators stop just around midnight, as it takes more energy to advance those dials than just move the hour and minute hands.
Try winding your watch with the crown as opposed to shaking it to wind it via the automatic rotor. Actual winding will bring your mainspring up to full power much faster than a whole lot of winding via automatic rotor. See if this changes the behavior of the watch. If it doesn't, you probably need to have a watchmaker take a look at the watch. He or she will probably recommend cleaning the movement to clear any dirt that might be causing the problem.
May 08, 2011 | Omega Constellation Double Eagle Gold &...
WATCH ON DESKFOR 24 HOURS KEEPS PERFECT TIME'WHEN I WEAR WATCH IT LOSES IN 1 HR. LOSES 40 MIN. BATTERY NEW. OMEGA CONSTELLATION 30 YEARS OLD CAN YOU HELP?
When a watch is on a desk, the balance wheel is vertical, when you are wearing it the balance wheel horizontal.
Has the watch been dropped onto a hard surface?
If the balance wheel bearing is worn or has suffered a large shock, then the shaft may move in its bearings or the bearings damaged, which may give the problem you decscribe.
Take it to a watch repairer to have it adjusted or repaired.
Dec 27, 2010 | Omega Watches
Omega constellation self winding watch stops
Omega claim that your watch will run for 40 or more hours, so stopping overnight should not happen. I doubt if you need to be particularly active to wind up the watch, otherwise this would make the problem quite common. My one experience of owning an automatic did not raise this sort of problem.
Discuss your problem with your supplier and describe your use. As you correctly say, having to hand wind i defeats the point of buying an autoamtic. (It could be that you have been sold two duff watches, however unlikely this may seem, it could happen).
Jun 06, 2010 | Omega Constellation 95 1262.15 Watch for...
Reserve time on my omega constellation
The watch needs a warranty repair. It should run for 36 hours at least
Jun 18, 2009 | Omega Constallation 1502.40 Wrist Watch
Watches Logo
Top Omega Watches Experts
DROPNDEAL
DROPNDEAL
Geoff
Are you an Omega Watch Expert? Answer questions, earn points and help others
