Question about Humidifiers
Why is my zoo Med Reptile Fogger Terrarium Humidifier leaking from the bottom where the motor is?
2 Suggested Answers
SOURCE: water leaking from the bottom of the humidifier
Make sure the bottom port on the humidifier is seated properly in drain port. Make sure your drain line is not obstructed.
Posted on Mar 04, 2008
Honeywell humidifier htt-145 leaking from bottom
If you can locate a crack in the clear plastic tank, there may be a chemical you can buy to "weld" the crack closed. If you aren't sure what plastic it is, you might try sealing the crack with bathroom caulk that is mold resistant. You must locate the source of the leak and patch that.
Mar 08, 2014 | Honeywell QuietCare HCM-630 Humidifier
Aprillaire 760 leaks from the bottom left of the case. panel is new, drain is clear, all vents open in the house, the panel cage is free from excessive scale. Any ideas?
Here is a link to your humidifier http://www.iaqsource.com/article.php/my-aprilaire-humidifier-is-leaking-what-to-do-about-it./?id=35
Oct 19, 2011 | Aprilaire 700 Humidifier
My furnace is leaking when the air is on and the motor in the autoflo 800 humidifier is bad. Could this be the problem?
Hello, the motor itself wont cause the unit to leak water, the float valve on the unit is what adjusts how much water is coming into the humidifier. If the float valve is not adjusted properly or broken it will cause to much water to enter the humidifierand therefrore overflow. Replace the motor and chexk the float valve to enure it is adjusted properly and if it is stuck or broken replace.
Jun 15, 2011 | AutoFlo 800BP Humidifier
I have a General Filters 1042-LH Humidifier in my home what setting should it be he choice low/ med /high live in Michigan
Sorry to read about your problem, I hope this helps you out.
OUTSIDE TEMPERATURE RECOMMENDED SETTING
-20F -29C 15%
-10F -23C 20%
0F -18C 25%
+10F -29C 30%
+20F - 7C 35%
+30F - 1C 40%
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 21, 2010 | General Filters 1042-LH Humidifier
General Humidifier Model 1042-L leaking water
Check the bottom of drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray is clogged with hardwater minerals or other material.
If the unit has not been used in a while it's possible a spider has take up residence by spinning a web in the bottom tray or tube.
The last poissible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
Jan 16, 2009 | General Filters 1042-LH Humidifier
I have a General Humidifier Model 1042-L that is leaking water out of the bottom pan. How do I fix this?
Check the bottom of the drain tube (tube connected to the bottom center of the bottom tray). Does water freely flow out the bottom end of the tube when the humdifier water feed is on?
If there is no flow from the tube and water is leaking from the bottom tray when the humidifier water feed is on then the tube or bottom tray may be clogged with hardwater minerals or other material.
Also, if the humidifier has not been used in a long while it's possible a spider has take up residence by spinning a web in the bottom tray or tube. Tell the spider to find a new home.
Another possible reason is the tray is cracked. You may order the tray from multiple sources on the web. Simply shop for model and price.
And lastly, is the unit installed properly, parallel to the ground? If tilted, water flowing through the unit may catch the sides and flow out where it should not.
Water leaking out of bottom
A leaking humidifier is a sign that the unit's filter needs to be cleaned/changed. I had the exact same problem on this model.
Jan 05, 2009 | General Filters 1042-LH Humidifier
Water leaking from the bottom of the humidifier
Feb 25, 2008 | Aprilaire 700 Humidifier
Filling humidifier
On the Vicks v-3100 the water tank should lift off of the unit. Flip it over and there is a lid. Open the lid and fill the tank. Once you've filled it back up, put the lid back on. Flip the tank over to make sure there are no leaks, then put it back on the humidifier.
Note: It's very important to check to make sure the tank isn't leaking before you put it back on the humidifier, if it is, it will flood the reservoir, in turn causing water to leak out of the bottom of the humidifier (which is one of the major complaints about the 3100).
Sep 11, 2007 | Vicks V3100 1.2 Gallon Humidifier
Humidifier leaks
My Air-O-Swiss U7142 has a leak from the very bottom. I found that as long as the water flows on to the "pan" that evaporizes the water, the water will come out from the bottom. Does anybody know how to fix this?
Jan 18, 2006 | Honeywell HCM530 Humidifier
Humidifiers Logo
41 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
