My tv remote does not work I bought a rca tv in sept. 2014 47 inc. model RLED4778A and the remote will not work it does not even turn on the tv but the tv works how can I either change the remote under warranty or re-programmed the remote ??? thank you
CompuGuy44
  • 432 Answers
SOURCE: Need code for remote control
Code Search Method: Turn on the device you wish to program. Press and hold CODE SEARCH until the indicator light lights, then release. Press and release the device you are programming (tv,vcr, or dbs). The indicator light will blink once then remain lit. Press and release off-on until your device turns off. You may have to press off-on up to 200 times. When your device turns off, press the ENTER button and the indicator light will go off. Code Entry Method: Manually turn on the device you want to program. Find the code for your device in the code list. Press and hold the CODE SEARCH button until the indicator light lights, then release. Press and release the device you want to program, the indicator light will blink then remain lit. Enter your code using the number buttons.After your code is entered the indicator light will turn off. Aim the remote at your device and press the off-on button. The device should turn off. APEX CODES: 006,014,033,035,036,039,041,152,247,172, 173
Posted on Sep 15, 2007
  • 74 Answers
SOURCE: can't get the remote to work
Try pressing the TV button on the Prima remote to make it work on the TV. It should work on the Prima Tv without new codes. Codes would be needed for your cable box.
Consider calling Prima at 866-447-7462 for the codes. They should have a website for the codes or email you the codes for free.
PS Please rate me if this helps.
Posted on Mar 30, 2008
kitquint
  • 40 Answers
SOURCE: Remote programing for TV after changing batteries
HOW TO PROGRAM GE Remote Control DOING CODE SEARCH
1. turn on device 2. press setup (underneath on/off) till red light stays on the take finger off the button 3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once 4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press 5. press and release enter to install code
Posted on Sep 15, 2008
SOURCE: I need a code to make my remote work my tv
i have a rca tv and a magnavox universal remote and i need codes to program
Posted on Jan 01, 2009
  • 6 Answers
SOURCE: "I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help""I need to program an old Panasonic TV with a RCA universal remote model RCR311St Help"
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Posted on Jun 03, 2009
I have a Toshiba TVs that I lost the remote to..so I bought a RCA universal remote model RCR3273R can get it turn TVs on and off but can not get input button to work
Some universal remotes control some TV functions but not all. You may have to do a code search to find another code that will work with your Toshiba TV. It may be necesary to try another universal remote or even a replacement OEM remote.
Dec 22, 2014 | Televison & Video
Hi i have a rca tv model rled4778a wont turn on
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jul 31, 2014 | RCA Televison & Video
Remote Control Problem
Are Both TVs Vizio TVs? If not it means it has droped the code to the set it is not turning ON
Jan 08, 2010 | V, Inc. VIZIO RP56 Rear Projection...
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
Bought a fairly used 2003 HDTV 4 months ago, Didnt come with remote but got a Universal I used that worked, my friend took the batteries out for a while for something else, we put the batteries back in...
Hard to say what the code is without knowing the model number of the remote and the brand of TV.
RCA's website has a remote code finder you can use.
Dec 17, 2008 | RCA Universal Remote 3 Device Remote...
MY TV WANT COME ON
go to radio shack or target before they close and buy an rca brand universal remote you wont even have to program it to your tv good luck
Sep 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
The short version: Will a 14-year-old TV work with digital-to-analog TV converter? Specifically, I have RCA Model G25342AT, built in Sept., 1994. In case yes, converter should work... Trying to connect...
The converter box should work. Getting the remote to work with the TV might be a challenge. You might have to stick with two remotes. It used to be in the old days you could plug your tv power into the remote that way you would turn the tv on with the tuner remote but I be they stop doing that.
There is website that will let you check the digital televison signals for your area. This site should help you:
http://www.tvfool.com/?option=com_wrapper&Itemid=29
Jun 29, 2008 | Televison & Video
Tried everything, but can't find the right code to work.
While this isn't really a solution, I have the manual and it doesn't list an Emerson DVD/VCR (EWD2204) that I have. I can't get it to work with my VCR. I bought the RCE Universal remote (RCU703SP) at Lowes (in 2008). I can't help but notice that the date on the package is "2004 Thompson, Inc." I know that the DVD/VCR is newer than that. Perhaps this remote is a bit old (explains why it was cheap?) Anyway I did find a site that you can get the codes like in the instructions: http://remotefinder.rca.com/default.aspx?site=rca so hope this helps.
Feb 23, 2008 | RCA ACC-RCAURC Remote Control
Broksonic TV code for RcA RCU704 remote control
I had a similar problem with a 1994 vintage Broksonic TV. I called the company (Hatzlachh Supply Inc. @ 800-333-9099). Broksonic TVs are not compatable with any universal remotes! You need an original factory remote. Remote for my set cost $20.00 plus shipping for a total of $24.95.
James Benson
Dec 26, 2007 | RCA 257003 Remote Control
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
