Question about Dryers
Maytag dependable care dryer mde9206awy - Dryers
rickzilla
  • 706 Answers
SOURCE: MAYTAG GAS DRYER TUMBLES BUT NO HEAT (FRONT LOADER 6 YRS. OLD)
Hello maryfitgera,
It certainly sounds like you are not getting a flame established in your dryer. That can be one of several components such as a non-resettable thermal fuse, gas valve assembly or control relay to that gas valve assembly. Unless you are well versed on how to work on these kinds of components, I suggest you just call in an appliance tech or.. let me know if you want to attempt diagnosing and repairing it yourself. Be advised that there are elements of danger in so doing. Let me know how you want to procede on this and I'd be happy to walk you thru it..
Regards,
Rick
Posted on Nov 24, 2008
  • 686 Answers
SOURCE: MAYTAG DEPENDABLE CARE PLUS I DRYER LDE8704ACE
rear bearing is dry
Posted on Feb 27, 2009
  • 13 Answers
SOURCE: maytag dryer barely gets warm
Is your vent stopped up? Or your lint screen? Usually an element will be all out, not just a little.
Posted on Apr 13, 2009
dblred
  • 68 Answers
SOURCE: my dryer works ...tumbles ...heat works...timer
if it is on sensor dry, check to see if the vent in your house or dryer is plugged. If it does this in time dry, there is probably a broken contact in the timer not allowing it to advance, and the timer would need replaced.
Posted on Oct 09, 2009
  • 205 Answers
SOURCE: Maytag Dependable Care Plus/Heavy Duty
HI- Usually when the clothes take a long time to dry it is an issue with the vent. Look in the back of the dryer and make sure the vent is not crushed, crimped or blocked. As well, go outside when the unit is running and feel how much air is coming out of the exit vent. It should be blowing pretty good. If not replace and clean the vent, if the vent goes through the wall and makes a bunch of turn over a long distance you will need to have a vent cleaning service out to brush and vacuum the vent. You can test this by detaching the vent where it goes into the wall and putting pantyhose over the end and see if it dries better. You could also have a thermostat issue but I look at the venting first. Hope this helps.
Posted on Sep 24, 2010
I have a Maytag Dependable Care Heavy Duty dryer and it makes an awful noise when it runs, also it isn't heating what should I do?
the knocking is either a belt that is going or one of the wheels is broken(they ride on three or four wheels). and those fixes are fairly inexpensive. but if it is also not heating, that can be inexpensive or not. maybe a new one, or fairly new via craigslist. how old is your dryer. over 10-12 years, maybe replace this one
Mar 15, 2015 | Maytag Dryers
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Have a Maytag Dependable Care Dryer that is about
you have to take it apart,it could be a roller or the belt pulley but you have to pull the drum to do this and you need a tool to remove the clip that holds the roller on,it's just a pair of needle nose plyers with like pointy tips on it to fit into the clip to pop it off,that's called a jesus clip if you drop it you'll see why it's called that lol,you can go on utube and you can find a video on how to take your dryer apart.i think the part number is 12001541 for the roller
Feb 07, 2018 | Maytag MDE308DAYW Electric Dryer
Maytag dryer barely gets warm
Apr 13, 2009 | Dryers
Maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
Mar 13, 2009 | Maytag Dependable Care LAT9706
Dryers Logo
29 people viewed this question
Top Dryers Experts
