Question about Nordic Track NordicTrack Summit 4500 Treadmill Motor Control Board
Stops wen running stops go slow - Nordic Track NordicTrack Summit 4500 Treadmill Motor Control Board
Have a 1991 Buick regal,it stops charging wen I plug in temp/fuel gauge into the cluster,why would it do that?
Does it stop charging or the light just comes on/gauge goes down? Plug it in and check if the alternator is putting out 13+ volts. It could be a short in the cluster or the wire from the alternator.
Jan 27, 2015 | Buick Cars & Trucks
Hi my hotpoint dryer wont turn please help
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to turn.
Apr 25, 2012 | Washing Machines
Iam unable to run shadow run microsoft game ,wen ever i try to run it driver stops responding
onboard intel drivers dont support pixel shader or vertigo, so thats probably why, and sadly you cant run a different graphics card as of yet
Jul 04, 2010 | Dell Inspiron 1501 Notebook
How do i test my fan blower in the refridgerator? calls for fan but fan trys and stops, the fan runs free and rocks back and fore wen stops.
If it has a burnt smell then it is probably no good. Thats the easiest way to find out. If it try to run then stop it is probably burnt or shorted out.
Jul 02, 2010 | Refrigerators
I hav 96 toyota cavalier auto,it shuddered and
I don't know if it would cause the shaking and vibrations, but for the smoke it could be loose nuts or broken studs on the exhaust manifold -- when engine is cold check each of the nuts (there should be 8) to see if they are loose or missing/broken; you may have to remove a heat-shield in order to gain access
Jan 06, 2010 | Chevrolet Cavalier Cars & Trucks
1994 olds cutlass 3.4 dohc
have you changed the fuel filter lately a plugged fuel filter will cause this concern
did the power loss start all of a sudden or did you start losing power over time ?
Oct 22, 2008 | 1994 Oldsmobile Cutlass Supreme
YPK5 Stops
connect it to the computer and charge 4 round bout 30 min n take it out and hold on wen it comes up it should work again dats wat i did wen dat happened
Aug 31, 2008 | Samsung YP-K5 MP3 Player
Nordic Track NordicTrack Summit 4500 Treadmill Motor Control Board Logo
14 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
