Question about Air Tools & Compressors
Service paint evercraft spray gun - Air Tools & Compressors
2 Suggested Answers
  • 35 Answers
SOURCE: Spray painting operation advice for Binks mach 1 hvlp spray gun
Hey paul its paul. I posted on here so hopefully you will give me some feedback. That is a very nice gun. One of my favorite. I'm guessing you know how to use a HVLP gun but if not here are a few tips. Make sure it is clean. Very clean. Your gun probably came with a manual, you should read it. It will help you greatly. First off, you want to have a regulator, about 40 psi is what i start with. You need a space you can practice some painting before laying down a new coat on the corvette. Haha. So next you will have a pressure adjustment knob, you want to start with this all the way closed and with the trigger pulled, just half way so just air is coming out adjust the air until it sounds even. Next you can try to spray. If it seems like the Fan, like the width is not enough you can adjust the fan, another knob, closer to the back of the gun, you ussually want about 5-6 inches of fan, if you are spraying at the normal 6-8 inches back from the piece. Last adjustment is the fluid adjustment, you want to put on a decent amount of paint, clear or primer, and not cause runs. This is going to take some practice because everyone moves at a different speed.
So you are going to have to play with your gun and figure out which knob does what. After that these instructions should get you a bit further, with some practice you will be laying down a nice paint job in no time.
Paul.
Posted on Feb 26, 2009
Paint gun splatters paint on car
The needle valve in the spray head needs to be cleaned or replaced.
Nov 21, 2013 | Binks Paint Spray Gun Repair/rebuild Kit...
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
Rolson spray gun 70809 not spraying
the paint may be to thick for the gun. or it could be clogged. try spaying plain water through it if it sprays you have your paint to thick
Jul 14, 2012 | Air Tools & Compressors
Not sure how much paint thinner needs to be added to paint with a spray gun
That depends on what type of paint you are using, surface to be painted, and air pressure for the gun.
Some type of paint needs different air pressure.
This is something you will learn by practicing. Try mixing a little of paint with some thinner
and spray using different distances from the surface to be painted.
If paint is not getting well distributed on the surface then try adding some more thinner.
Aug 05, 2011 | Air Tools & Compressors
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
Porter cable PSH 1 - clogs even with thinned paint compressor 4 gal 5.1 scfm
strain paint befor using. run water in gun or thinner to see if it will spray it before using and mix paint to the consistancy that spray gun or paint requires for spraying ( fine strainer)
Feb 04, 2011 | Porter Cable Gravity Feed Paint Sprayer
My paint gun is pulsating instead of spraying evenly
It looks like you have a Devilbiss SRI.
Probaby the hole in the lid is blocked, The gun sprays, paint gets sucked out, no air can get back in through the little hole in the lid to replace so it stops spraying, pressures even up it sprays abit more, and so on.
Either that or you have a damaged fluid tip.
regards
Sep 18, 2010 | HVLP New PROFESSIONAL AUTOMOTIVE AIR...
My Kirby G3 paint attachment isn't spraying the paint. I have everything hooked up according to the manual, and it sprays a continuous stream of air, but isn't sucking up the paint to spray. Sometimes I...
mcdevito75 here, Sounds like it"s cogged with paint, the paint is not being sucked up into the Spray gun itself, the air flows thru thr spray gun thru the trigger assembly. Follow the makers cleaning of the spray section of the spray gun. Try running paint thinner thru the spray system. Hpope this helps.
Jul 19, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Air is coming out of the nozzle but the paint is not coming out.
There are different filter screen sizes for different thickness of paint. Even with proper screen size one might need to thin paint. I hope this information is helpful. Please give a rating if this was helpful. Good Luck and have a Great Weekend.
Apr 01, 2010 | Binks MACH 1 HVLP Pressure Feed Spray...
Problem spray painting water based paint
I spoke to a friend who was a spraypainter in his last job, apparently due to the thickness of the paint, I needed a larger nozzle on the gun. I couldnt get a nozzle to suit this gun so I purchased another gun with a cuple of different size nozzles. All seems to be working fine now.
Nov 19, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
35 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
