Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Disconet alarm system to 95 chevey 1500 z71
Lost remote to disarm alarm need to start truck the battery may be dead do to cold weather
3 Suggested Answers
johnjohn2
  • 5763 Answers
SOURCE: lost keys for chevey truck
This is close to imposible, you would need a scan tool to reprogram a need chip code into the computer, now if theres no chip the power locks or the door lock should deactivte the alarm system, if you dont have a door key then you would need to remove the door panel and manualy turn linkake on the lock as if it were the key, but i think the 2000 had a key chip.
Posted on Oct 03, 2010
SOURCE: I just put a new battery in my 2005 Chevy Cavalier
see if your starter relay is switched out with one that works with your remote. If it is, switch it real quick with another relay switch like it (the blower motor one is similar) and see if the car starts with that. Might just be your relay switch. I found this out today troubleshooting another problem! Good luck! PS: If you are lucky you still have an instrument panel that works, lol...mine has been out for 2 years now! No other major problems though, can't complain till today.
Posted on Dec 28, 2010
Replaced battery in my 1993 jeep grandcherokee limited now security system seems to cut fuel off seconds after engin fires
Here's some info as it sound like the theft deterrent is armed.
Reset Procedure
NOTE: This information applies to a Vehicle Theft Security System (VTSS) that was armed when the battery was disconnected and reconnected.
When the armed VTSS senses that the battery has been disconnected and reconnected, it enters its power-up mode. In the power-up mode the alarm system remains armed following a battery failure or disconnect. If the VTSS was armed prior to a battery disconnect or failure, the system will have to be actively or passively disarmed following a battery reconnection.
The power-up mode will also apply if the battery goes dead while the system is armed and battery jump-starting is attempted. The engine no-run feature will prevent the engine from starting until the alarm system has been actively or passively disarmed.
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the liftgate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Once the alarm has been activated (horn sounding, lights flashing, and the engine no-run feature), either disarming method will deactivate the alarm.
Depressing the Panic button (if equipped) on the RKE transmitter will also disarm the VTSS, but the horn will sound and the lights will flash for about three minutes as part of the Panic feature. The horn and lights can be stopped by pressing any of the RKE transmitter's buttons or driving the vehicle above 15 mph.
Feb 11, 2013 | Dodge Stratus Cars & Trucks
Alarm keeps turning on when I turn on my car starter
Okay, the Avital 4111 is a one button remote starter. So, it has no way of locking your car doors except if wired to lock after start or, after shut down. In the 2010 CRV, the unit should have been wired to disarm the alarm before start(brown wire in kick panel) and to unlock doors when running (grey wire in kick panel in same harness as disarm) with the press and release of the remote starter remote. If the unit is not working in cold weather it may be due to the installer using a valet key instead of a bypass and/or the unit may be programmed for virtual tachometer or voltage instead of having a true tachometer wire connected.
Jan 25, 2013 | Avital Vehicle Parts & Accessories
When i try to start me 2008 sonata the alarm goes off and the engine will not turn over. what can i do?
Your Sonata is equipped with a "Keyless Entry & Burglar Alarm" system. When the Burglar Alarm is activated, it KILLS the starting system through the used of a relay called the "Burglar Alarm Relay". This mode prevents engine starting with the key.
Solution #1
Disarm the system with the Keyless Remote (key fob) If you don't have this remote (or its battery is dead) replace the battery & try disarming again.
Solution #2
Enter the vehicle & insert the key in the ignition and turn the ignition switch to 'RUN'. Wait 3 to 5 minutes until the alarm stops. You should then be able to start the engine.
Have a qualified/certified Hyundai Service Technician properly diagnose this issue.
Sep 07, 2011 | Hyundai Motor 2004 Sonata
I changed the batteries on my F350. This set the alarm off on the truck. I cannot get it to turn off. I finally had to cut the wires to the siren. The lights still flash for a minute or longer everytime...
If it is a Ford Factory Alarm it should have key FOBS (remotes). Just press the unlock button 2 times and that should stop it. Alarm systems no matter what brand always have remotes. If you have remotes pressing the unlock should disarm the system 99 times out of 100. If that doesn't work then either the battery in the remote is dead, or the remote is broken. Hope this helps. Cobra :-)
Jun 12, 2010 | 2003 Ford F350 Super Duty DRW SuperCab
I have a 02 silverodo battery went dead i charged battery reinstalled it it starts but dies and with the key out of the ignition security light stays on
you need to disarm the alarm. unplugging batt. or dead battery being jumped sets of the alarm not all alarms make noise
use remote to lockand then unlock doors need to be closed
or lock then unlock door with key if it dont reset then try passenger door
Mar 22, 2010 | 2002 Chevrolet Silverado 1500
I cannot disarm my alarm system so I cannot start my van what can be the problem?
It sounds like your transmitter on your remote is not functioning. You may just need to replace the battery in your remote! Some times unlocking the doors w/your keys will disarms the alarm system. Thats why i had to do when i lost my remote. See if that helps!
Sep 24, 2009 | 1998 Chrysler Town & Country
The car alarm and key pad will not disarm and the car will not start.
Normal system operation - when the burglar alarm is active, the starter circuit is disabled. Is the battery dead or weak in the keyless remote? Also, is the remote you have been programmed for this vehicle? If the answer is 'yes' to both questions, replace the battery in the remote. Otherwise, place your ignition key in the ignition and turn the key to 'run' (or 'ON") wait 5 minutes, the vehicle should start (if the battery isn't dead).
May 22, 2009 | 2003 Hyundai Tiburon
How do I disarm factory alarm for 95 sts without remote?
Lock the car up with Power Lock, KEY in HAND NOW at the DRIVER SIDE DOOR USE "KEY" TO UNLOCK THE DOOR this should disarm the Factery Security System.
Apr 18, 2009 | 1995 Cadillac DeVille
How can I reset my Factory Alarm on my Jeep it wont run
Alarm Module Reset Procedure
Passive disarming of the Vehicle Theft Security System (VTSS) occurs when the vehicle is unlocked using the key to unlock either front door or the lift gate. Active disarming of the VTSS occurs when the vehicle is unlocked by depressing the Unlock button of the Remote Keyless Entry (RKE) transmitter.
Jan 28, 2009 | 1999 Jeep Grand Cherokee
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
12 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
