Question about Google Computers & Internet
Allowing chrome through firewall bt home hub 4
SOURCE: ive got a 40gb ps3 and a bt home hub wireless router how do i connect ps3 to computer ps ps3 is upstairs and pc downstairs
look on the back of your home hub. there should be a Wireless Key in a Grey box. (BT Home Hub wireless settings)
note the wireless key.
go to your ps3. and turn it on log on ect. go to settings and down to network settings (right at bottom).
(Im not sure of the next section because im currently on a network but it should be an option to find network).
anyway you search for networks. should find your home hub.
keep going right untill you have to enter any settings. and write your WEP Key (Not WKA). (wireless key from back of router).
Posted on Jan 21, 2008
  • 48 Answers
SOURCE: comm problem between range extender and BT home hub
make sure the SSID, channel & wireless key on router & all extenders are the same, also the default gateway on the extender has to be the IP address of the router.
Posted on Feb 10, 2008
  • 86 Answers
SOURCE: cannot connect to wifi on our bt home hub
Could be a variety of reasons.
Assuming you have not had it working before
Assuming the wifi is broadcasting it SSID
Assuming you have laptop connected by ethernet cable to hub:
Assuming you have XP:
Go to start/control panel/network connections/right click the wireless lan icon and select properties/select wireless connections and delete ALL previous entries.
With Vista go:start globe then
Control Panel\Network and Sharing\Manage Wireless Networks and delete all entries
Now:
press windows key and R
type cmd and enter
type ipconfig and enter
note lower set of figures ie 192.168.0.1
open browser and type in those figures and enter
should now open router firmware
When asked for log in use defaults of admin - admin or admin - password
navigate to wireless security and set encryption to WEP 64bit and create a simple encryption code - save settings
Change broadcast channel to 8
make sure wifi is set to open and not shared
Save all settings, allow hub to reboot and now see what happens
Posted on Dec 10, 2008
frankzjm
  • 191 Answers
SOURCE: Acer Aspire 7730 UNABLE TO GET WIRELESS CONNECTIVITY
you need to try
1) check bios aetup screen thereis setting wireless enable/disable
and check xp control panel--system--device manager wireless driver no yellow triangle mark( which need update driver)
2) check wireless switch at laptop frront or right side, set to "on" to make sure the wireless light not on. if wireless indicate light still black means your wireless card out of works, check wireless card by open small back cover clean pins and reinstall it again
3) finally you might need change a wireless card.
Posted on Feb 09, 2009
  • 68 Answers
SOURCE: Iv got a BT home hub 2 cant get conections for
There are ISPs that block utorrent. I found this explanation of how to do port forwarding on the BT home hub, though: http://portforward.com/english/routers/port_forwarding/BT/BTHomeHub/Utorrent.htm
So, all I can suggest is to open the ports on your home hub as suggested above and to connect your computer straight to your home hub rather than to your CWR-854 (unless you actually have no such router and just picked that to ask the question under).
It is possible that someone has decided that you should not use torrents (they slow down everyone because they actually have the nerve to use the internet) and they are associated with thieves. Not to mention that there are tons of legit uses for them,
This could be someone in your ISP or your house. So do you have access to everything? You can poke around with telnet - can you access the ports on the other systems that utorrent accesses to make itself part of the network of systems that are downloading and sharing the torrent?
But if one knows the ports it is easy to block torrent.
If you have multiple routers that do nat, the home hub has to forward to your router, not to your system. So if your router is 192.168.3.12 and your system is 192.168.5.6, the BT home hub has to forward to the port on your router, on 192.168.3.12 , and your router has to forward to your system on 192.168.5.6. If the home hub tries to forward directly to your system (if you have multiple routers, which you might have because of the way you asked your question) then it won't work since your router hides 192.168.5.6.
Posted on Jan 10, 2010
How do I turn off smart set up on BT home hub 4?
Switching Smart Setup on and off on the BT Home Hub 4 or Hub 5
  1. Click on Advanced Settings.
  2. Enter the admin password. ...
  3. Click on Continue to Advanced Settings.
  4. Click on Home Network and then Smart Setup.
  5. Click the appropriate radio button to turn Smart Setup on or off and then click Apply.
Aug 12, 2016 | Computers & Internet
Hi. We are trying to setup a phillips tv through a bt vision box please
  1. A TV aerial feed - The BT Vision box gets its digital TV signals over-the-air, so needs a TV aerial. This needs to be connected to the aerial input socket on the V-Box. There is an output RF aerial socket to allow you to connect an aerial feed to a TV if required.
  2. SCART lead - You need to make a connection from the Vision+ box to the TV using a SCART lead. If you have a HD TV set, you can also connect via an HDMI lead (not supplied).
  3. Connection to Broadband - You'll need to connect from the BT Vision+ box to a BT Broadband connection. This is done using the BT Home Hub. The Home Hub is the Broadband router supplied by BT, and it connects into to your phone line to give you Internet access-The most common way to make the connection, is to connect an Ethernet (networking) cable from the BT Vision+ box to one of the Ethernet ports on the Home Hub. If you can't make a direct connecting to the Home Hub, you can use powerline adapters to make the connection. The self-install kit includes two Powerline adapters to allow you to connect to the Home Hub if it's in a different room to the BT Vision+ Box.
  4. The BT Vision v-box has an additional scart socket, which can be connected to a video or dvd recorder.
Jun 02, 2016 | Philips Phillips - 40" Class - Led - 1080p...
I cannot get online with google chrome, it keeps flashing reconnecting.
A few things you can try:
1) Check to make sure your firewall is not blocking Chrome. If it is allowed, try deleting it from the list, then start Chrome and follow the firewall prompts to allow Chrome.
2) Uninstall Chrome, reboot, then reinstall Chrome.
3) See if this Google Diagnostics page can be helpful:
https://support.google.com/chromebook/troubleshooter/1257251?hl=en
Best of luck.
Apr 23, 2015 | Microsoft Windows 7 Home Premium 64BIT...
How do I change my bt broadband username
Telephone BT, and ask for their Help Desk, to get technical support. They can change your ID.
Dec 10, 2014 | BT 2Wire Gateway BT2700HGV Home/Office...
How can I recover the password for my bt homehub 2
This page will show you where the default password is for all the BT Hubs. Where to find admin password BT Home Hub Help BT com Help If you need to reset the device as the password has been changed then look here How do reset my BT Home Hub to its factory settings Help BT com Help This will change the passwords to what are written on the BT Hub.
Oct 09, 2014 | AccessData Password Recovery Tool Kit (ftk...
How can i reset my password on a bt hub
If you do not remember the login password then you have to reset the hub. Reset the red reset button with a paper clip and the hub will return to its factory settings.
Keep me posted
Jul 15, 2014 | BT 2Wire Gateway BT2700HGV Home/Office...
Iv got a BT home hub 2 cant get conections for utorrent even though opened firewalls
Jan 09, 2010 | Cnet CWR-854 Router
Computers & Internet Logo
22 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
