Question about Kitchen Ranges
Whirlpool gold gr448lxps
Burners wont boil water unless on high all the time. middle setting wont heat well
KOakaKO
  • 135 Answers
SOURCE: Stove/oven gets hot then shuts off
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
Posted on Aug 09, 2007
  • 1314 Answers
SOURCE: Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Posted on Jan 19, 2008
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
MNTECH
  • 1543 Answers
SOURCE: The burners are too hot. Even when set to 'lo'
Your range uses what is commonly refered to as infinite heat switches. Without getting into too much of the mechanics of how they opperate, basically they cycle the burner on (at full power) for a very short time at warm or lower settings,(and longer off periods), at medium type settings, on / off might be more like 50 /50, and at high, they are on 100% of the time. There is no calibration for these. Sometimes, the electrical contacts inside arch and make poor contact, or weld themselves together, giving high heat at all settings. The only way to fix this problem is to replace the individual switches, which are the part the the knobs push onto.
Posted on Oct 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: while using kenmore 790.9621 smooth
It appears your Ignitor has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Testimonial: "Thanks for your answer. I've been upside down with this thing! I put a new 4 prong 40amp cord on it and it looks like it solved the problem. Thanks "
How do I properly operate the Turbo Boil on my new Kenmore range?
Turboboil is a feature offered on a number of Kenmore electric ranges and cooktops. Without you model number it's hard to get into specifics - but turboboil is a special, high wattage heating element that delivers up to 3KW of energy to a specific heater on the cooktop. If I understand correctly, you would only use this setting when you wish to bring water to a boil in the shortest period of time possible - then change to a normal burner heat setting to maintain the temperature of the water in the pot.
Remember, an electric heat element is turned "full on" and "full off" as needed to maintain temperature (unlike a dimmer knob controls a light bulb). The turbo boil turns on a "double heater" to rapidly heat the water - after water reaches 212 degrees, it can not be heated any further (it turns into steam) so you should switch to a normal burner mode from that point forward.
Kenmore com
Apr 07, 2015 | Kenmore Kitchen Ranges
My dishwashers normal light keeps flashing and wont do anything
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 07, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
All the ignitors simultaneously popping unless unplugged
Usually this is from moisture getting into a spark ignitor switch, which is located under your burner knobs. A pan boiling over, someone cleaning your cooktop and using a sprayer, too much water on a sponge, very high humidity, can all get moisture into a switch. Recommend you unplug your cooktop for a few days and see if your switch dries out. Plug it back in an see if it works properly again. If it doesn't then you will have to replace one, or all of the switches, depending if they come seperately or in a set. This entails removing the top of the cooktop, which can be very difficult if not impossible in some cases. Heat and corrosion go together, so in just a few years the screws or nuts that hold the burners down onto the cooktop are so corroded that you cannot remove them without chiseling the nuts off or drilling out the screws, which then damages the burner bodies underneath. Can make it unrepairable in some cases. Drying the unit out works about 80% of the time. Good Luck, Appliance Specialists
Dec 22, 2009 | Whirlpool GLT3615 Gas Cooktop
Hello My gemini top burners cycle on and off,
The burners are designed to cycle on and off, it is technology that helps to keep from burning food. If you are using the correct pan to burner size ratio and high setting on your burner, the water should boil in the normal time. Don't watch the pot (just kidding)
Nov 30, 2009 | Maytag Gemini 30" Self-Cleaning...
The burners are too hot. Even when set to 'lo' setting food over cooks or water boils. Can the burners be calibrated to provide an actual 'lo' setting. Food cooked on 'lo' sticks to pan and liquids...
Oct 28, 2009 | GE JBP30 Electric Kitchen Range
When turned on, the stove heats up and down periodically.
If you are talking about the burners on a glass top range yes they cycle, even on high. will it boil water?
Aug 06, 2009 | Whirlpool GR563LXS Kitchen Range
Front Right Large Burner Wouldn't Boil, Now won't heat at all
The burner has a short now. The burner is a resistor and when it is shorted the burner will not heat to its full capability. You should be able to replace the burner element. Home Depot or Lowes may have the part you need or you can most likely get them from Amazon. They have everything.
Cheers
Nov 26, 2017 | General Electric Stove/Oven/Range Chrome...
Parkray Cumbria efficiency problem
Some circulation pumps have a 3 phase mixing valve (cold,warm,hot) to regulate the water pressure in the building; no way to know unless you trace the plumbing. Basically, the hot water temperature could be lost because the circ-pump is cooling it with the cold water supplied to it. This is used to balance the pressure (aka Pressure Balancing Circ-Pump), so heater is really working overtime to heat the water. If the pump has two in and one out that's more than likely your problem; but you should consult a "old-school" plumber in your area.
Nov 25, 2008 | Water Heaters
Burners/Heat
make sure you have the correct orifices, make sure you have good gas pressure and make sure pressure regulator is ok.
also if the unit has been in service for a while check the orifice for build up a wire or needle will work to knock out any build up
Apr 23, 2008 | Jenn-Air JGD8130 Gas Cooktop
I have a Inglis smooth top stove, model IME 8230. One of the front has a dial for single/dual --for quick heat up. It was working fine, til couple of days ago, it suddenly went haywire. When I turned it...
The swich for the burner is bad and needs to be replaced. The glass will be fine, but unless your just boiling water you wont be abe to use it until you replace the switch.
Apr 08, 2008 | Kitchen Ranges
Kitchen Ranges Logo
21 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
