Question about Viking VWH3048 Kitchen Hood
Removing blower vent from viking - Viking VWH3048 Kitchen Hood
How do i remove a tooth brush in my dryer vent?
Try to pull out from lint filter door. If not try to access from back vent tube. Remove the house vent line and then look into machine inside vent line. It is a 4" diamter hole.
If no luck then you have to access the blower wheel compartment. It depends on your model how to access the blower wheel compartment
Dec 03, 2014 | Dryers
Want to change fan on blower heater
Removal
  1. Remove wiper arms.
  2. Remove cowl panel.
  3. Disconnect blower motor electrical connector and vent tube.
  4. Remove blower motor retaining screws.
  1. Remove fan retaining nut from blower shaft through plenum opening while holding the fan from the engine compartment.
  2. Remove fan from blower motor while removing blower motor from vehicle.
Installation
  1. Hold fan through plenum opening.
  2. Install blower motor to vehicle while installing fan to blower motor.
  3. Install fan retaining nut to blower motor shaft through plenum opening.
  4. Install blower motor retaining screws.
  5. Connect electrical connector and vent tube.
  6. Install cowl panel.
  7. Install wiper arms.
Aug 13, 2013 | 1991 Oldsmobile Cutlass Ciera
Rear Foot AC vent/blower
remove the vent and clean inside
Jul 13, 2012 | GMC Yukon Cars & Trucks
We have a viking cook top and the vent goes up and down but the fan does not always turn on ? Can you help
Some units have a dead man switch, which means that if the filters are not in place correctly the blowers will not operate. Its a safety thing to prevent little ones from dropping toys into a running blower. Double check the filters placement, if the filters are in the proper location than I would look at the power to the blower unit. The vent has two jobs, (1) to raise and lower, (2) to turn on the blower unit once in the full up position. If this is not the case, the upper switch in the vent system has failed. If you already confused, you will need to call a Viking expert to correct this problem. Its not difficult but can be time consuming.
I hope this helps
I have seen this problem twice and found the filters were the problem, rarely replace blower motors..
Jul 26, 2011 | Viking Cooktops
My viking downdraft vent isn't working. I didn't
The halogen light have all gone out (3) is there a fuse and is it hard to find or replace
Dec 20, 2009 | Viking Kitchen Ranges
Have a 7 yr old maytag dryer it seems to heat up fine and everything but we have to redry clothes 2 or three times and dryer vent is not plugged
You possibly have a stripped blower wheel . On Maytags , either blower or clogged vent is the problem when too long to dry . Suggest removing vent hose and feel if you have good exhaust air . If not , blower wheel bad , if so , vent problem . Try drying a load without vent hose connected to dryer .
Jul 06, 2009 | Dryers
Vents in the Viking hood fall out on their own
Remove the filters.
The slot that the filters sit in at the rear edge, can be removed, it is basically hooked into place.
When you remove it you will see that the sides are different, reinstall it with the smaller edge hooked thus leaving the larger edge to hold the filters in place.
I hope this is clear.
Dec 12, 2008 | Viking VWH3048 Kitchen Hood
Maytag dryer
it sounds like there is no air flow check outside of home where vent exits house there should be strong air flow it either a blocked venting or a bad blower fan in the dryer most likely blocked venting start outside then work your back to the dryer if no air flow outside remove venting from the dryer ifgood air flow here the vent is blocked if not blower fan most likely broken these blower fans drive hub round out on the motor shaft of the motor but it would be very loud this should fix it for you thanks kevin
Sep 30, 2008 | Whirlpool Dryers
Viking hood damper
Remove the blower and reach up into the duct through the back flow damper and put weather stripping on the 2 edges that are chattering, it will greatly reduce the noise
Dec 20, 2007 | Viking VWH3048 Kitchen Hood
Viking VWH3048 Kitchen Hood Logo
79 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
