Question about Samsung UN40C6300 TV
Disable the start up and shut down melody - Samsung UN40C6300 TV
Remote start starts car and dies off after few seconds
try having the cpu reset using a code reader as you may have two systems operating in conflict that is causing the problem.
Jul 29, 2013 | Audiovox Prestige APS997C Alarm/Remote...
How to turn off melody on a samsung 7100
http://downloadcenter.samsung.com/content/UM/201009/20100906141849812/[UC7100-NA]BN68-03151A-01L03-0903.pdf
Looks like you press Menu and then Setup on your remote. Page 27 discusses the melody settings. You can either turn off the melody or enable "Fast Start" which will automatically disable the melody.
May 04, 2011 | Samsung Televison & Video
Want to silent keypad when typing or dialing
Hi nanro346,
Editing the Normal - Message Profile 1.Touch >Settings > Sound Profile >Normal. •Touch the name field and not the radio button to the right. 2.Touch drop-down menu (upper-right of the screen) and selectMessage. 3.Touch the Message Alert Type field, select one of the following and touchSave: • Melody: the phone rings using the ring melody selected in the Ring tone menu. • Vibration: the phone vibrates 3 times. •Vibration & Melody: the phone vibrates and plays a melody simultaneously. • Mute: the phone is silent and does not play a melody or vibrate. 4.Touch the Message Alert Tone field, touch to select a ringtone and touchSave. 5.Touch the Message Alert Repetition pull-down and select one of the following options and touchSave: • Once: repeats the message alert once. • Periodic: repeats the message alert periodically. 6.Drag the Alert Tone Volume slider to the volume level you desire (range is 1-7). 7.Touch the Vibration Pattern field, then touch to select Vibration 1 - 3. 8.TouchSave to return to the Sound Profiles menu
Apr 29, 2011 | Samsung SGH-A877 Impression Cell Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
How do I turn off the on / off melody on the 42 in samsung LCD tv?
Usually melody turn On-Off option is available in Settings menu of tv, let me know model number of your tv to provide you more detailed info about how to turn Off melody sound on start up and shut down.
Thanks.
Nov 07, 2010 | Samsung HCN4226W 42" Rear Projection...
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
simultaneously.
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
My vista is going slower when i shot down
When you shut down I think you mean. You would likely need to disable all your startup programs and then re-enable them one by one until you locate the culprit.
Click START/RUN and type in MSCONFIG.
Click on services tab. Click disable all.
Reboot.
Shut down.
If the problem is gone, repeat the process re-enabling things one by one until you locate whats hanging the system on shut down.
Oct 29, 2009 | Microsoft Windows Vista Ultimate Edition
How do you turn off the loud chime melody every time you open the Jazz DV 178 camera. The audio settings don't affect it.
I had hoped that there was an unadvertised code or key sequence to disable the chime, but I guess not. I am going to simply disconnect (if I can) or destroy the little speaker that produces the chime melody. It doesn't do anything else that's useful so I know I will not miss it.
I don't think I need a group of "experts" to ponder over this, for a fee. But thanks for the offer anyway.
--Bruce Mann
Jun 30, 2009 | Jazz DV-179 Digital Camera
Windows 98 will not shut down
There are several reasons that can cause old Windows operating systems to shut down. Has this always been an issue or did it just start happening? If it just started, then think back to what you may have changed on the system...hardware or software. Remove software or hardware and try it again.
You can also try disabling the fast shut down sequence by following these steps:
1. Go into msconfig (this can be done by typing msconfig under the command prompt)
2. Go into advanced.
3. Put a check mark in the disable fast shutdown box.
4. Click ok and ok again.
Try shutting it down.
If that doesn't do the trick or its already disabled then check out this link:
http://support.microsoft.com/kb/202633/en-us
I hope that helps. Check back and let me know! Thanks.
Apr 11, 2009 | Microsoft Windows 98 for PC
Button monitor problem
Disable all startup items. Click on Start> Run> Type msconfig then press enter. Click on the Start Up Tab the click on Disable All. Click close and restart your computer.
Your system should be starting up faster compared before.
Feb 08, 2009 | Dell Microsoft Windows XP Home Edition
Samsung UN40C6300 TV Logo
27 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
