Question about Oregon Scientific aw131 aw131
Does not show meat tempeture - Oregon Scientific aw131 aw131
GE monogram buildin refrigerator - climate control drawer cannot hold the temperature as set for meat. It always shows at 47F.
sounds like the damper door down there is not opening also the fan down may not be coming on to bring temp down to 32.
Sep 17, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
I change thermostat, water pump, housing coolant sensor, but yet when i start driving the tempeture goes up and down and the heat gets kind of cool not all
poor coolant flow water pump? air lock in system? bring to operating temp shut down than open air bleed screws.
Jan 02, 2014 | 1997 Pontiac Sunfire
What tempeture do you fry a 14 pound turkey?
First off make sure that the turkey is completely thawed and that there is no excess water on it before placing it in the hot oil....
The temperature should be around 350....
Cook the turkey till the meat starts to pull back from the ends of the drumsticks...
heatman101
Nov 25, 2010 | Masterbuilt Turk-'N'-Surf's Turkey Fryer
GE GSS25LGMA refrigirator/freezer refrigirator side is freezing
There is an electrically activated air dampener in the upper left back side of the refrigerator section which most likely has broken (in the open position), allowing cold air from the freezer to continue to enter the fresh foods section. Replace the dampener assembly.
Mar 29, 2010 | Refrigerators
Ext tempeture on a/c display show exterior tempeture at 50 degree;s but it is in the 90's
in the grill area is a sensor it is very comon for the sensor to go bad ,check it to make sure it is clean of debrie (bugs) un plug the sensor see if the temp changes if it does thats most likly your problem, you can test the sensor with a ohm meter by warming it up while reading the resistance
Jun 12, 2009 | 2003 Chevrolet TrailBlazer
2000 daewoo lanos where is located the tempeture sensor?
On my 1999 it is located near fan has 2 wires almost looks like a o2 sensor
Feb 09, 2009 | 2002 Daewoo Nubira
Westinghouse fj383
I have a Westinghouse upright freezer FJ383M-R. The red light was on bright and the top half of freezer was not working. Turns out it was a switch that turns the defrost cycle on was faulty. Serveman replaced borken part. Now it is fine. Was much cheaper than replacing freezer.
Nov 28, 2007 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Meat probe button on control pad
there is no real way to reset it you reset it when you turned the breaker off, It sounds like the EOC (electronic oven control) is faulty. I would just keep reset it and keep doing that to bake the turkey how hot will it get before it buzzes? is it showing any error codes?? F1, F2, F3 etc.....
Sep 30, 2007 | Jenn-Air JES9860 Electric Kitchen Range
Oregon Scientific aw131 aw131 Logo
Top Oregon Scientific Measuring Tools & Sensors Experts
Lawrence Oravetz
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
